what to wear under drysuit #226640
01/11/11 05:56 PM
01/11/11 05:56 PM
PTP Offline OP
PTP  Offline OP
never sailed in a true drysuit before and was wondering what people would wear under one for something like tradewinds this weekend. I don't want to have to check any bags for the flight so was hoping to keep things to a minimum.
Re: what to wear under drysuit [Re: PTP] #226645
01/11/11 07:41 PM
01/11/11 07:41 PM
You want something insulating, but not bulky. You also want something that will wick the perspiration away.
I wear one or two layers of Patagonia polypropylene underwear under mine. I also have a Magic Marine one piece fleece suit when it gets really cold.
Re: what to wear under drysuit [Re: PTP] #226646
01/11/11 07:54 PM
01/11/11 07:54 PM
birthday suit. be careful with the zipper - it's a duzy.
Re: what to wear under drysuit [Re: Jake] #226653
01/11/11 08:55 PM
01/11/11 08:55 PM
Hobart, Tasmania, Oz.
Dazz Offline
Dazz  Offline
I used to wear my high school uniform:) back in the day we would knock off school walk across the road and go windsurfing.
C2 AUS 222 by Goodall design
"Darph Bobo"
Re: what to wear under drysuit [Re: Dazz] #226656
01/11/11 09:21 PM
01/11/11 09:21 PM
Anacortes
Sloansailing Offline
Anacortes
Isn't Tradewinds in Key Largo? And you are going to wear a drysuit!?! LOL when I did steelechase everyone couldn't believe we only wore shorts and rash guards, but it felt great compared to the 48 degree water we sail in year round!
Anacortes Rigging.com
Rigging and Yacht Services
Re: what to wear under drysuit [Re: PTP] #226658
01/11/11 09:46 PM
01/11/11 09:46 PM
Key Largo
barbshort Offline
barbshort  Offline
Key Largo
I was once told to dress under the drysuit in the fashion that would keep you warm on shore. That rule of thumb worked back when I used to wear a drysuit. Definitely wicking and layers. It's only supposed to be in the 60s this weekend here so northerners should find it balmy.
Re: what to wear under drysuit [Re: barbshort] #226662
01/11/11 10:50 PM
01/11/11 10:50 PM
Atlanta, Ga
BLR_0719 Offline
BLR_0719  Offline
Atlanta, Ga
Simple base layer.
Re: what to wear under drysuit [Re: BLR_0719] #226664
01/11/11 10:56 PM
01/11/11 10:56 PM
Originally Posted by BLR_0719
Simple base layer.
Dang, Brad, you've been working out!
Re: what to wear under drysuit [Re: Jake] #226672
01/12/11 06:31 AM
01/12/11 06:31 AM
Orlando, FL
tback Offline
tback  Offline
Orlando, FL
Depends on the weather ... I usually just have shorts and a T-shirt under my drysuit ... unless the weather is really cold (ie <50 degrees) and then I'll go to the base layer that was posted by BLR.
USA 777
Re: what to wear under drysuit [Re: tback] #226729
01/13/11 08:21 AM
01/13/11 08:21 AM
Netherlands
DennisMe Offline
DennisMe  Offline
Netherlands
I usually only wear one wicking under layer. A dry suit with nothing under it will kill you when you fall into the water (due to its enormous thermal conductivity). In that case its much safer to wear a wetsuit.
When it gets down to around 10-15 degrees celcius (50-60F) I usually pop on a moderately tight fleece sweater (too loose and the inevitable folds get in the way).
Dennis
PS: there's lots of dry-suit weather here in the Netherlands...
Re: what to wear under drysuit [Re: DennisMe] #226742
01/13/11 03:26 PM
01/13/11 03:26 PM
uh, the highs for the weekend will be in the mid-upper 70s, so I presume the day will be in the mid 60's. You need a drysuit for that?
0 registered members (), 510 guests, and 40 spiders.
