Page 1 of 3 1 2 3
tradewinds wind #227105
01/20/11 10:33 AM
01/20/11 10:33 AM
pgp Offline OP
pgp  Offline OP
Rick: As usual I was lost and carried starboard tack much further upwind than the front runners. (no it didn't occur to me to just follow them) Then when I flopped over to port, I was much further below the mark than I'd expected to be. The top guys seemed to be sailing in the middle of the course.
What did they see that I missed?
Inquiring minds and all that...
Pete Pollard
Blade 702
Re: tradewinds wind [Re: pgp] #227108
01/20/11 10:57 AM
01/20/11 10:57 AM
Wilmington,NC
Dlennard Offline
Dlennard  Offline
Wilmington,NC
Pete,
We found if you stayed on starboard tack all the way to the lay line or even a little past you would be headed at the end of your starboard run but lifted on port when you tacked. The port tack would lift you all the way to the mark with a little header at the end if you tacked early on starboard it seemed like you would sail more of a header on port.
Re: tradewinds wind [Re: Dlennard] #227109
01/20/11 11:22 AM
01/20/11 11:22 AM
pgp Offline OP
pgp  Offline OP
Hmm.. now I'm really lost!
I carried starboard a long way and thought I carried it too far but apparently not because I never got the lift.
In any case, most of the F16s seemed to be tacking to port fairly early and working that side of the course. It worked for the leaders, I just never picked up any clear signal that it was time to tack.
Pete Pollard
Blade 702
Re: tradewinds wind [Re: pgp] #227110
01/20/11 11:48 AM
01/20/11 11:48 AM
MERRITTISLAND, FL
Matt M Offline
Matt M  Offline
MERRITTISLAND, FL
When all the leaders take off the other way - How much clearer of a signal do you need? laugh
Re: tradewinds wind [Re: pgp] #227112
01/20/11 11:54 AM
01/20/11 11:54 AM
we went to the right on day 3 almost every race (mainly due to crappy starts and needing to get some clean air). didn't pay off frown
Re: tradewinds wind [Re: PTP] #227113
01/20/11 12:12 PM
01/20/11 12:12 PM
Fundamentals - get to the race area early, sail part of a beat, see what's going on. At the very least, you can watch as others do this and see which side is favored.
Failing that, keep an eye on the competition like Matt suggests. Every once in a long while, leverage pays out; most of the time, though, if you're headed to a private corner and you don't know if it is favored, it probably isn't.
Re: tradewinds wind [Re: Dlennard] #227114
01/20/11 12:35 PM
01/20/11 12:35 PM
Orlando, FL
tback Offline
tback  Offline
Orlando, FL
Originally Posted by Dlennard
Pete,
I did this and found that I was getting bad air off the fleet of F18 that would continue on Starbord Spi run rounding the offset.
USA 777
Re: tradewinds wind [Re: tback] #227117
01/20/11 01:05 PM
01/20/11 01:05 PM
On day 1 (Friday) the wind was going right all day, you'll recall the RC reset the course after we could one-tack A mark on Stbd. When the wind is going right, you want to get right asap and ride the lift into A mark.
On day 2 it was still going right, just not nearly as much, and occilating more, but you had to decide if you were going to go right early to avoid the F18 spinnaker parade (and resultant bad air) or if you were going to hit the left corner to avoid same.
On day 3 it was light and fluky, you really had to watch out for the holes going upwind, and try to stay in the puffs downwind, hope for the best on the gate laylines.
Re: tradewinds wind [Re: Timbo] #227119
01/20/11 01:13 PM
01/20/11 01:13 PM
Punta Gorda, FL
jkkartz1 Offline
jkkartz1  Offline
Punta Gorda, FL
Pete,
You should get a good book on strategy & tactics. The old Stuart Walker and Eric Twiname books helped me alot.
Re: tradewinds wind [Re: Matt M] #227120
01/20/11 01:15 PM
01/20/11 01:15 PM
pgp Offline OP
pgp  Offline OP
I know. But without picking up on the physical signs i.e. a shift or change in pressure I'd just be following. I'm still trying to figure out what they saw and felt that I missed.
Jack- reading and understanding are not the same. If anything I've read too much. I think I'm fixated on some old habit that I still haven't identified.
In any case we had the best weather we've had in at least three years and I'd rather sail in the Keys than any place I know.
I'm about thirty miles south of Charlotte Harbor and the weather today is absolutely gorgeous. Just in case any of you are thinking about coming down.
Pete Pollard
Blade 702
Re: tradewinds wind [Re: pgp] #227122
01/20/11 01:35 PM
01/20/11 01:35 PM
RickWhite Offline
RickWhite  Offline
Hi Pete,
Two rules for sailing upwind
*If oscillating wind, tack on the headers and hold the lifts
*If persistent, go the direction the shifts are going.
Almost every day saw persistent shifts going right, and almost entirely the right side was favored.
On the Orange course it was even more so, as we were closer to land.
So, another little big of lore: If land on the right and water to the left(as it was), go to the right.
When you were at my seminar I think you quit midweek before we got to the tactics and windshifts, as I recall.
However, in the magazine I do a tactics column and much of it is about this sort of thing
Rick White
www.onlinemarinestore.com
Re: tradewinds wind [Re: RickWhite] #227126
01/20/11 01:57 PM
01/20/11 01:57 PM
pgp Offline OP
pgp  Offline OP
I did leave mid week, but what I got was enjoyable. And I always read your column.
Pete Pollard
Blade 702
Re: tradewinds wind [Re: pgp] #227137
01/20/11 03:15 PM
01/20/11 03:15 PM
Pete, your next move (assuming you've read enough Stuart Walker), in regards to "seeing" what the wind is doing, would be to get some type of compass, a speed puck or tactic, onto your spin pole, and learn how to use it to identify shifts, both persistant and occilating.
We didn't need a compass because we had the land (as well as other boats) as a backdrop to see what was happening, ie. lifted or headed.
Re: tradewinds wind [Re: pgp] #227140
01/20/11 03:46 PM
01/20/11 03:46 PM
My approach was:
A) get a clean start - find favored end. After day 1, throw everything away if needed to prevent Trey from banging out a port tack start because whether or not it was part of my game plan, the F18 fleet (who was watching everything waiting for their start) was going to give me another load of crap about it.
B) wind was supposed to work it's way to the right every day. When in doubt, or especially if you find yourself in trouble getting washed/dirty air, go right.
C) there usually was better pressure but worse angle to the left (starboard beat) and patchy pressure to the right. If you worked the middle, you could usually find a better angle and more consistent pressure. When in doubt, refer to B and plan to shift gears often.
D) If you find yourself completely screwed (capsized, way late to the start, mechanical issue, etc) bang hard left to perform an unlikely "Hail Mary".
Re: tradewinds wind [Re: Jake] #227142
01/20/11 03:58 PM
01/20/11 03:58 PM
pgp Offline OP
pgp  Offline OP
You guys are making my head hurt! smile But thanks for your input. It seems like following is the easiest solution. I'll worry about the rest if I ever catch up.
Pete Pollard
Blade 702
Re: tradewinds wind [Re: Jake] #227143
01/20/11 04:00 PM
01/20/11 04:00 PM
M
MN3
MN3
M
Originally Posted by Jake
My approach was:
What do you do after Mary shows up?
Re: tradewinds wind [Re: pgp] #227144
01/20/11 04:02 PM
01/20/11 04:02 PM
RickWhite Offline
RickWhite  Offline
Just a tip: always keep asking yourself if you are sailing a header or lift. And always know. Headers are your friend.., after you tack it becomes a lift.
Another off the cuff: after rounding C, is the angle to mark more or less than 45-degrees? Less is good.
Rick White
Re: tradewinds wind [Re: pgp] #227145
01/20/11 04:17 PM
01/20/11 04:17 PM
tampa, fl
K
ksurfer2 Offline
ksurfer2  Offline
K
tampa, fl
Stay away from the corners (unless your hoping for Mary to show up). Once you get to a layline, you're out of options.
Re: tradewinds wind [Re: ] #227146
01/20/11 04:36 PM
01/20/11 04:36 PM
Jump for Joy.
Re: tradewinds wind [Re: John Williams] #227148
01/20/11 05:21 PM
01/20/11 05:21 PM
pgp Offline OP
pgp  Offline OP
Thanks again everyone. This is all good stuff.
Pete Pollard
Blade 702
Page 1 of 3 1 2 3
0 registered members (), 16,728 guests, and 1,093 spiders.
Most Online22,490
Yesterday at 08:14 AM
