Any Info? #226897
01/17/11 06:50 AM
01/17/11 06:50 AM
Live in Germany, House in UK, ...
DanTnz Offline OP
DanTnz  Offline OP
Hi All,
This class looks like a great concept, I'll be looking to build one of these for my son in a couple of years time.
I was just wondering, google search doesn't reveal a class association website or anything. Have I missed it?
Also, is there a definitive set of rules available? I note that there is already mention of some rules being changed already from the rules sticky'ed above - like pocket sails not having stays.
Grateful if anyone can point me in the right direction.
Re: Any Info? [Re: DanTnz] #226901
01/17/11 07:54 AM
01/17/11 07:54 AM
Kingston SE South Australia
JeffS Offline
JeffS  Offline
G'day DanTzn I modified the rules so what you see at the top of the page is the rules, you havn't missed anything the class was started on this forum and is still going please keep us up to date with your progress
regards Jeff
Jeff Southall
Current boats
Nacra 5.8 1667 Ram Raider
Nacra 18 Square
Arrow 1576
Re: Any Info? [Re: JeffS] #226903
01/17/11 08:44 AM
01/17/11 08:44 AM
DanTnz Offline OP
DanTnz  Offline OP
Thanks Jeff, good to know that thems the rules.
I'll keep you up to date if there is any progress! Will be a couple of years before I'll attempt it and before the boy will be big enough to sail it. Cheers, Dan.
Re: Any Info? [Re: DanTnz] #226933
01/17/11 03:13 PM
01/17/11 03:13 PM
Scarecrow
Scarecrow
Another DS being built in Finland.
Re: Any Info? [Re: ] #227051
01/19/11 09:55 AM
01/19/11 09:55 AM
Finland
Gato Offline
Gato  Offline
Finland
Nice, any other DS12 sailing?
Re: Any Info? [Re: Gato] #227061
01/19/11 01:41 PM
01/19/11 01:41 PM
DanTnz Offline OP
DanTnz  Offline OP
Guys, while I'm on the topic - whats the consensus on rigs?
I was thinking of a two piece round section carbon mast with a pocket luff sail. Simple, light, pretty cheap and easily transportable. But that was until read the rules more closely and worked out that the sail had to be able to be lowered at sea. I couldn't figure out a way of getting the spreaders and stays onto the mast and being able to lower the sail.
I see that Vudu looks to have a pocket sail and spreaders & stays, so there must be a way.
I was thinking the simplicity of the rig would outweigh any performance gained from a wing section mast - and mean one less control line (mast rotation).
Anyone put any thought into this? Dan
Re: Any Info? [Re: DanTnz] #227075
01/19/11 04:23 PM
01/19/11 04:23 PM
Scarecrow
Scarecrow
Gato no more sailing but a few in build.
DanTnz visit Gato's website www.gust.ax to see the carbon masts we are doing for the DS12s. The drawings for the DS have the spanner tieing off to the tramp. The idea is to set it on the beach and then go sailing. This gives more adjustablity than the H16 style stops on the mast step but still simplifies sailing for kids. I suspect that as kids get a little older and more experianced the means to adjust will be added.
Re: Any Info? [Re: ] #227139
01/20/11 03:36 PM
01/20/11 03:36 PM
DanTnz Offline OP
DanTnz  Offline OP
Nice one, thanks for that, excellent series of photos. Where did the bolt rope insert come from?
Re: Any Info? [Re: DanTnz] #227149
01/20/11 05:33 PM
01/20/11 05:33 PM
Scarecrow
Scarecrow
Gato made it. You could get away with a single bigger tube which could be more easily made.
Re: Any Info? [Re: ] #227645
01/27/11 11:53 AM
01/27/11 11:53 AM
Finland
Gato Offline
Gato  Offline
Finland
Scarecrow is righ, a lot less work and you can also make a tube that is not round if you do it yourself.
Re: Any Info? [Re: Gato] #228423
02/09/11 09:33 AM
02/09/11 09:33 AM
DanTnz Offline OP
DanTnz  Offline OP
Guys, thanks for the info. My aim is to be able to car top, mainly because I have to take a ferry to get on and off the Island, so trailer or overhangs = more dollars.
In theory, could such a mast be made two piece? My ideal would be a slightly shorter version of the Weta mast.
Has anyone put any thought into an unstayed mast? I would have thought previously that it wouldn't be stiff enough for the righting moment of a cat - or to trap off. But the Devoti One is carrying 11m2 and a 15m2 kite with no stays and designed for heavyweight crews, so it could be a possibility. It would be great just to able to drop the mast in and go.
Re: Any Info? [Re: DanTnz] #228438
02/09/11 12:48 PM
02/09/11 12:48 PM
Finland
Gato Offline
Gato  Offline
Finland
I started to make a mast in two pieces, but I did not complete it, I could still do it, I don't think there is a problem doing it. It will be a little heavier thats all.
There has been talk about an unstayed mast, but so far not interest enough to do one.
Re: Any Info? [Re: DanTnz] #228472
02/10/11 07:29 PM
02/10/11 07:29 PM
Asuncion, Paraguay
Luiz Offline
Luiz  Offline
Asuncion, Paraguay
Wouter Hijink proposed this setup. He participates in this forum, just write to him.
All the best,
Luiz
Re: Any Info? [Re: Luiz] #228508
02/12/11 02:31 AM
02/12/11 02:31 AM
DanTnz Offline OP
DanTnz  Offline OP
Thanks, just found the earlier thread that included what I wanted to know om Wouter's proposal.
I'll have to put some more thought into that - hadn't factored in the effect a trapeze could have on sail shape on an unstayed mast.
Re: Any Info? [Re: DanTnz] #228537
02/13/11 10:35 AM
02/13/11 10:35 AM
Asuncion, Paraguay
Luiz Offline
Luiz  Offline
Asuncion, Paraguay
I was told that the trapeze lines would be attached to tape reinforcements sewn to the sail sleeve. Use of the trapeze bends the mast to windward and back and this must be considered when making the sail.
Luiz
Re: Any Info? [Re: Luiz] #228549
02/14/11 05:42 AM
02/14/11 05:42 AM
DanTnz Offline OP
DanTnz  Offline OP
I'm really attracted to a freestanding rig, I can't think of an elegant solution for the mast base. Wouter's solution would work fine but I think it would get in the way while sailing. Will have to get the calculator out for some other solutions. Countering the fore and aft loads seems to me to be the biggest problem.
Re: Any Info? [Re: DanTnz] #228565
02/14/11 12:37 PM
02/14/11 12:37 PM
Asuncion, Paraguay
Luiz Offline
Luiz  Offline
Asuncion, Paraguay
Another solution was proposed by PHil Brander that uses a hollow dolphin striker. Wouter's solution is structurally better, it is already used in a small Hobie and other boats.
Luiz
Re: Any Info? [Re: Luiz] #228587
02/15/11 04:14 AM
02/15/11 04:14 AM
DanTnz Offline OP
DanTnz  Offline OP
I didn't realise Hobie did a freestanding rig, thanks for the tip - found it on their site: http://www.hobiecat.com/sailboats/bravo/
It's not the most elegant of solutions!
I thought of a hollow drop in tube down thru the beam onto a dolphin striker. I ruled it out as I was trying to avoid having a dolphin striker at all. I also thought it would have to be really big to take the fore and aft loads without any additional fore and aft bracing - then the solution is to have a kind of diagonal dolphin striker. But then the design is getting more and complex and the idea of the freestanding mast was simplicity.
So now I am back to square one in my reasoning - a conventional stayed rig might be simpler all round. It may be better to think of rapid rigging systems.
Re: Any Info? [Re: DanTnz] #228595
02/15/11 09:05 AM
02/15/11 09:05 AM
Finland
Gato Offline
Gato  Offline
Finland
With the present solution it takes about 15 min from cartop to sailing.
Btw. in Finland the mast is ok on top of the car.
Re: Any Info? [Re: DanTnz] #228646
02/15/11 08:42 PM
02/15/11 08:42 PM
Asuncion, Paraguay
Luiz Offline
Luiz  Offline
Asuncion, Paraguay
I didn't realise Hobie did a freestanding rig...
It is quite elegant in terms of structural stresses.
I must agree that engineers are the only ones to consider efficient solutions inherently beautifull, though.
Luiz
0 registered members (), 696 guests, and 108 spiders.
Posts267,056
