Re: uni fest [Re: tback] #227233
01/21/11 04:39 PM
01/21/11 04:39 PM
Originally Posted by tback
Originally Posted by Timbo
I need dates. Pete, when is the GYC A-F16 regatta (or what ever they are calling it this year) and when is Spring Fever Thanks.
You can find dates [HERE]
It is also locked as a link at the top of the Open Forum
Thanks Terry, and thanks for that great dinner too!
Has Chris recovered yet?
Re: uni fest [Re: TEH] #228086
02/03/11 09:03 AM
02/03/11 09:03 AM
Annapolis Md.
LuckyDuck Offline
LuckyDuck  Offline
Annapolis Md.
Tom thanks for the idea of using these on the jib track. I've been hesitant to install the track on the Falcon because this type of track leaves the tabs on the beam when the track is removed and the tabs by themselves look painful. Ed
F-16 Falcon #212
Re: uni fest [Re: LuckyDuck] #228097
02/03/11 02:13 PM
02/03/11 02:13 PM
Maryland
Kris Hathaway Offline
Maryland
I have been thinking about them also. I've been racing with the jib track removed but with the tabs riveted in. Though it looks menacing with the bare tabs, it has never been an issue. The tabs are close enough to center that I do not pass over them while climbing back on board nor do they interfere with any rigging.
Can't wait to see your install Ed. Do you even have a jib and crew yet? (Vic is unavailable for the Nationals wink ).
Kris Hathaway
Re: uni fest [Re: Timbo] #228098
02/03/11 02:18 PM
02/03/11 02:18 PM
I am going to try the old 10mm wrench taped to the end of the batten...again...but last time it took me forever just to get one in the middle of the track, so I don't know how long it will take to do 20 of them!
Double sided tape, the right angle on the bolts/beam and practice..
Be happy that F16s are only 2.5 meters wide and have a beer.
Re: uni fest [Re: Kris Hathaway] #228099
02/03/11 02:20 PM
02/03/11 02:20 PM
Maryland
Maryland
BTW, stainless or aluminum (paper or plasic) rivnuts?
My understanding is that aluminum is prefered to minimize corrosion if strong enough for the application. I believe it should and that you would not have to use SS in this case. Yes?
Kris Hathaway
Re: uni fest [Re: Kris Hathaway] #228111
02/03/11 04:42 PM
02/03/11 04:42 PM
Scarecrow
Scarecrow
If you're using rivnuts to enable you to regularly add and remove a fitting don't use ali. It is too soft and the threads won't last. Go with Stainless or even better Monel. A bit of Tefgel will handle corrosion
Re: uni fest [Re: Kris Hathaway] #228134
02/03/11 08:08 PM
02/03/11 08:08 PM
Chicago, Illinois USA
TEH Offline
TEH  Offline
Falcon must have a different track setup. All Karl had on his Viper was a nice neat row of the rounded head nuts screwed into the rivnuts.
I suppose you could have two rivnuts for each tab.
Blade F16 USA 725
Re: uni fest [Re: Kris Hathaway] #228198
02/04/11 06:22 PM
02/04/11 06:22 PM
I used stainless. It good to coat them with Duralac or something similar when installing. A bit of grease on the threads probably wouldn't hurt either.
Re: uni fest [Re: Karl_Brogger] #228204
02/04/11 10:37 PM
02/04/11 10:37 PM
pgp Offline
pgp  Offline
Karl was on fire in the last race this afternoon! He did well all day but in the last race he ran away from everyone.
The uni guys need to coax the details out of him.
Pete Pollard
Blade 702
Most Online22,490
Yesterday at 08:14 AM
