At the just past Tradewinds regatta, there were a couple races where we had pretty good wind going downhill, and I found on my US Blade, it was much faster to stay flatter, saling on two hulls and keep the bows up, not for risk of picthpole, wich is always a factor on the US Blades, but for speed.
To keep the front beam from stuffing into the wave tops as we went up and over them it was easier on two hulls. If you go high on one hull, that hull will be deeper in the water, obviously, and the front beam will dig in and really slow you down with each wave top as you climb up over.
We kept it on two hulls, usually, and kept the bows up. It was much faster than constantly stuffing the beam into the wave when on one hull.
All of the other F16 designs (except the Taipan 4.9)have more volume in the bows, so they are more apt to do better on one hull.
