| Re: Jib Getting Caught up
[Re: flounder]
#22889 08/04/03 10:42 PM 08/04/03 10:42 PM |
Posts: 170 Australia | Hi well i've got a 1986 model hobie 16 and trust me when i say it my batterns were long and slow. I cut them down to fit better and still had the same problem. Since i sail in a place where theres isn't much wind and when there is thers alot of it, i noticed it went past with out trying when the winds pick up. Its just that when there is no wind its a bitch to fix. Heres a list which should help. * Cut the batterns down (If new jib make sure you leave space for the jib to spread. * You can put a plastic strip over and along the out side of the sail which covers the battern ( i heard this helps a heap) * If you have the wire system its alot stiffer but the rope lets it fly past easyer but the rope isn't as strong * tecnique!!!! Sorry but its all i can think of till i get my new boat. Have fun!!
From Julian
Jules_topcat
[Re: River_rat]
#22892 08/06/03 05:47 AM 08/06/03 05:47 AM |
Posts: 11 New Zealand | Thanks for the advice, it is definately the jib halyard that the battens are getting caught on because the pulley is out from the mast. THe idea of attaching the wire in close to the mast sounds good. Maybe because it is winter here and the breeze is light i will continue to get caught up. Spring is not far away and the afternoon sea breeze will kick in regularly. I'm just keen to get out there. Until spring i will continue to blow the ice off the tramp on the way to the beach. Cheers again Daveb | | |
361
guests, and 45
