I love Russell #229208
03/01/11 07:13 PM
03/01/11 07:13 PM
Central Coast NSW Australia
TonyJ Offline OP
TonyJ  Offline OP
Despite the mishap at the nationals, Russell is progressing slowly. Each week we tinker a little bit and get him sorted out.
I am tempted to adjust spreader rake, mast rake ect, but I am still fine tuning all the running gear, placement, strengthen ect. We seem a little bogged down up wind, even struggling to get 2 on the wire, but down wind were getting a combination happening, with a measurable improvement against the A's at my club.
Teach them how to think. Not what to think. Aus Blade 002
Re: I love Russell [Re: TonyJ] #229209
03/01/11 07:22 PM
03/01/11 07:22 PM
TonyJ Offline OP
TonyJ  Offline OP
The ute is on loan from a friend of mine who sells them. I enjoyed the drive, she enjoyed the sail. A fair deal...
Re: I love Russell [Re: TonyJ] #229210
03/01/11 07:26 PM
03/01/11 07:26 PM
TonyJ Offline OP
TonyJ  Offline OP
A couple more shots
Re: I love Russell [Re: TonyJ] #229211
03/01/11 07:28 PM
03/01/11 07:28 PM
TonyJ Offline OP
TonyJ  Offline OP
The repaired carbon mast is quite likely the stiffest part of the boat. I am sure it's part of my up wind problem.
Re: I love Russell [Re: TonyJ] #229214
03/01/11 10:28 PM
03/01/11 10:28 PM
How far north of Sydney are you? Nice looking boat!
Re: I love Russell [Re: Timbo] #229217
03/02/11 03:30 AM
03/02/11 03:30 AM
TonyJ Offline OP
TonyJ  Offline OP
From the airport it,s about 1hr & 45 mins north.
Re: I love Russell [Re: TonyJ] #229283
03/03/11 05:59 AM
03/03/11 05:59 AM
Tornado_ALIVE Offline
LOL..... Love it. May stand out on the start line though.
Re: I love Russell [Re: Tornado_ALIVE] #229284
03/03/11 06:20 AM
03/03/11 06:20 AM
Wouter bought a Blade?
Re: I love Russell [Re: TonyJ] #229286
03/03/11 07:22 AM
03/03/11 07:22 AM
pgp Offline
pgp  Offline
Is this a home build?
Pete Pollard
Blade 702
Re: I love Russell [Re: pgp] #229312
03/03/11 10:17 PM
03/03/11 10:17 PM
TonyJ Offline OP
TonyJ  Offline OP
Yes Russell is a ply wood home build.
Re: I love Russell [Re: TonyJ] #229320
03/04/11 07:59 AM
03/04/11 07:59 AM
pgp Offline
pgp  Offline
Any pictures of the process?
Pete Pollard
Blade 702
Re: I love Russell [Re: pgp] #229671
03/13/11 05:12 AM
03/13/11 05:12 AM
TonyJ Offline OP
TonyJ  Offline OP
There are plenty of photos of Russell being built on this forum. But you have to go and look for them.
Here are a few I can still find at home.
Bows with bulkheads and foam cut in for added strength.
Re: I love Russell [Re: TonyJ] #229672
03/13/11 05:19 AM
03/13/11 05:19 AM
TonyJ Offline OP
TonyJ  Offline OP
Another angle showing where the bridle attaches, and bulkheads, You can see the cedar templates for the deck supports.
Re: I love Russell [Re: TonyJ] #229673
03/13/11 05:24 AM
03/13/11 05:24 AM
TonyJ Offline OP
TonyJ  Offline OP
More bulkheads and deck fittings. You can just make out the center board casing.
The bow needed to be extended because there wasn't enough ply. Just scraps glued together and glued on. The glass on the bow before the join had to be cut to allow for the bend.
Re: I love Russell [Re: TonyJ] #229674
03/13/11 05:29 AM
03/13/11 05:29 AM
TonyJ Offline OP
TonyJ  Offline OP
The fairing had begun. With out a doubt the hardest part of the build. It took months to get it even close to good enough.
The bottom photo shows the foam bulkhead I put in as bouncy.
I had foam bulkheads cut out, but I took them out and decided to have two bouncy tanks. A problem if a direct hit.
Re: I love Russell [Re: TonyJ] #229675
03/13/11 05:31 AM
03/13/11 05:31 AM
TonyJ Offline OP
TonyJ  Offline OP
The rear beam landings and a cedar strip on the stern to take the redder gudgeon.
Re: I love Russell [Re: TonyJ] #229676
03/13/11 05:37 AM
03/13/11 05:37 AM
TonyJ Offline OP
TonyJ  Offline OP
Rear beam landings, I glued some foam blocks on and shaped them so they are more stream lined. I like the lookk of them and they seem to work fine.
Re: I love Russell [Re: TonyJ] #229677
03/13/11 05:40 AM
03/13/11 05:40 AM
TonyJ Offline OP
TonyJ  Offline OP
Looking towards the fore deck. I built up around the fore beam landing as well. Plenty of faring here as well. The last 45cm is another foam block glued on and sanded to shape and glassed over. I was very happy with shape.
Re: I love Russell [Re: TonyJ] #229678
03/13/11 05:46 AM
03/13/11 05:46 AM
TonyJ Offline OP
TonyJ  Offline OP
Here I was getting ready to mould up the beams. It took a fair while to get everything straight. I then strapped it to the floor. You can see the tool tech on the beams which allowed me to use the filler and not have the beams glued in.
Re: I love Russell [Re: TonyJ] #229679
03/13/11 05:52 AM
03/13/11 05:52 AM
TonyJ Offline OP
TonyJ  Offline OP
Rigging up the spinnaker before using it. The pole is a fiberglass two piece wind surfer mast. I use a thicker section for the boom. They both work fine.
0 registered members (), 480 guests, and 514 spiders.
