| Re: P18-2 would take a spi?
[Re: Andinista]
#229454 03/08/11 10:36 AM 03/08/11 10:36 AM |
Posts: 2,844 42.904444 N; 88.008586 W | The P18-2 has some descent bouyancy up front, but as you know ANY boat will pitchpole. It has diamonds on the mast. It comes with a rather large jib and a '4-way' jib system. I woned one for about 10 years, #5 it was. (fifth production boat made.)
A spin sould be done. If you don't drive it too hard, you'd be OK.
F-18 Infusion #626- SOLD it!
[Re: Todd_Sails]
#229458 03/08/11 11:53 AM 03/08/11 11:53 AM |
Joined: Apr 2006 Posts: 699 SE Pa. or Chesapeak Bay HMurphey
Posts: 699 SE Pa. or Chesapeak Bay | As the P18-2 is just a slightly smaller P19 .... you could look to the P19's for ideas/concepts. The P18-2 is a sweet boat w/ a min crew wieght of 275lbs(?) vs the P19 at 325lbs ...
(If you have a P19 and a P18-2 sitting on a beach, slightly apart from each other and no "references" to judge/measure size against ... you would think you are looking at the same boat ...)
... and yes, ... you can pitch-pole a P19, on it's nose/bows, mast tip laying on the water .... been there, done that, have the T-Shirt ....
Harry H18Mag/P19MX
[Re: HMurphey]
#229460 03/08/11 12:52 PM 03/08/11 12:52 PM |
Posts: 1,203 uk | You should be able to get hold of a used f18 spinny kit that would fit nicely
A pair of F18 daggerboards wouldn't be too hard to fit either!
282
guests, and 50
