Tramp removal #229710
03/13/11 11:12 PM
03/13/11 11:12 PM
South Louisiana, USA
Clayton Offline OP
Clayton  Offline OP
I need to remove the tramp from my Nacra 5.2. Its a one piece tramp. There must be some trick to it but I don't know it. Tried a search to no avail. Little help here?
Thanks,
Clayton
Re: Tramp removal [Re: Clayton] #229712
03/14/11 12:47 AM
03/14/11 12:47 AM
Y
yurdle Offline
yurdle  Offline
Y
Untie it at the rear beam and it will slide up the tracks to the main beam. Disconnect the main beam from one hull and slide the tramp out.
Re: Tramp removal [Re: Clayton] #229719
03/14/11 07:37 AM
03/14/11 07:37 AM
Thanks,
Clayton
It's reconnecting that main beam to the hull that's so much fun! Clayton got it right though...and if you still have the center bar, aka "knee knocker", it should slide off the castings without drilling out rivets but if it's stuck, you may have to drill out one of the rivets holding the casting to one of the beams.
Re: Tramp removal [Re: Jake] #229733
03/14/11 09:27 AM
03/14/11 09:27 AM
Clayton Offline OP
Clayton  Offline OP
The tramp is too tight to just slide out. It looks like detaching the main beam involves dismantling the striker assy too, at least one side. It is riveted to the beam and I think a bracket is riveted to the hull. I don't remember if the two are attached or will just separate. I'll have to look next time.
C
Re: Tramp removal [Re: Clayton] #229734
03/14/11 09:39 AM
03/14/11 09:39 AM
Maryland
Kris Hathaway Offline
Maryland
Nacra 5.2 & 5.5 Manual This should help. You should not have to dismantle the striker. This version does not have the knee knocker but as Jake said, it should release when the beam is pulled off the hull.
Kris Hathaway
Re: Tramp removal [Re: Kris Hathaway] #229741
03/14/11 11:21 AM
03/14/11 11:21 AM
Clayton Offline OP
Clayton  Offline OP
Excellent! I started on the right track, just stopped short. I'll need to send the tramp off to be inspected and re-stitched. I have teenagers that think the Stiletto is too slow!!! (What would they expect with 14 of their friends on board!) They keep saying something about needing new harnesses for their friends to try... this might work!
C
Re: Tramp removal [Re: Clayton] #229751
03/14/11 01:35 PM
03/14/11 01:35 PM
I remember there are little stainless 'tangs' on the main beam that bump into the hull there - they are only there to establish the initial hull position when reassembling...they're not actually attached to the hull.
BE SURE you have the boat out in the sun on a warm sunny day when trying to reinstall...it's hard to get the hulls back in position with a new trampoline. I tried putting my trampoline in the drier to loosen it up some but I could never keep it warm by the time I got it to the boat...had to wait for sunny day.
Re: Tramp removal [Re: Jake] #229794
03/15/11 10:56 AM
03/15/11 10:56 AM
Clayton Offline OP
Clayton  Offline OP
Thanks Jake, I did see those tangs. Good point about the sun. I think we'll have enough here to warm it good enough.
Should have it off this weekend.
C
Re: Tramp removal [Re: Clayton] #229853
03/16/11 09:40 PM
03/16/11 09:40 PM
South Florida & the Keys
arbo06 Offline
arbo06  Offline
When I need to remove a tramp from my boat I just move the cooler to someone elses boat. It usually works.
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Tramp removal [Re: arbo06] #229855
03/16/11 10:48 PM
03/16/11 10:48 PM
Clayton Offline OP
Clayton  Offline OP
But what if she's good crew??? ;-)
Re: Tramp removal [Re: Clayton] #229974
03/20/11 02:00 PM
03/20/11 02:00 PM
Netherlands
DennisMe Offline
DennisMe  Offline
Netherlands
What I do is loosen the rear lacing.
Pull behind the main beam on alternating sides, no more than about four inches a time until a sort of pocket forms.
Then when the last inch pops out of the track, remove the main beam and slide the tramp off. Mounting is the reverse operation.
Re: Tramp removal [Re: DennisMe] #229984
03/20/11 09:16 PM
03/20/11 09:16 PM
Clayton Offline OP
Clayton  Offline OP
Unbolted the hull from the beams, tramp slid right out. I'll keep in mind having it in the sun to put it back on. Now, who to send it to for re-stitching?
1 registered members (vasil), 372 guests, and 39 spiders.
