| Re: Poling out Jibs
[Re: Dennis]
#23162 08/11/03 11:44 PM 08/11/03 11:44 PM |
Posts: 778 Houston | Is this the theory behind the Prindle MX pole? The MX pole is really to just move the jib tack down. This is more like flying a staysail spinnaker on a cat. Keep in mind this is an experiment. Start small and be prepared. For example, it looks like the Wave turns downwind instead of into the wind when you right it with the jib on a pole. Think of this as something to try when the wind is blowing 5-10. If it works you can try it in heavier air. | | | Re: Poling out Jibs
[Re: carlbohannon]
#23163 08/12/03 11:03 AM 08/12/03 11:03 AM |
Posts: 1,253 Columbia South Carolina, USA | On the Supercat the jib is extremely high. They use a pole that they call a pelican striker. It does the same thing, move the tack down. Clean and simple.
David Mosley
425
guests, and 30
