| Main traveler rail #231809 05/03/11 07:41 AM 05/03/11 07:41 AM |
Posts: 5,525 | It has pulled loose. First, a loud bang, then the head of the screw protruded so the car could not travel.
Fixes anyone?
Pete Pollard Blade 702
| | | Re: Main traveler rail
[Re: pgp]
#231810 05/03/11 08:34 AM 05/03/11 08:34 AM |
Posts: 6,049 Sebring, Florida. | I removed my old one after it broke when a couple rivets pulled up, and replaced all the rivets with stainless screws. It was quite a project because it's a bitch trying to get the nut on the back of the screw, using a small wrench taped to the end of a long batten, slid inside your beam, and it takes two people to do it. It took me and my daughter about 3 hours each, on two afternoons, to get them all done.
If you only have to do a few rivets, just drill them out and replace with screws asap, before they pull all the way out and the track breaks, or you might lose your traveler car balls...
Blade F16 #777
[Re: Timbo]
#231812 05/03/11 08:55 AM 05/03/11 08:55 AM |
Posts: 5,525 | Mine are machine screws and that's what I'll replace them with.
It's worth mentioning this is the first failure I've had and the boat is five years old.
[Re: sail7seas]
#231816 05/03/11 09:29 AM 05/03/11 09:29 AM |
Posts: 5,525 | "I through bolted two, four inch (4") long stainless steel in the center"
There's an idea! It would be a lot easier for one person working alone.
Chris, are you coming to KPRR?
[Re: pgp]
#231819 05/03/11 12:03 PM 05/03/11 12:03 PM |
Posts: 1,382 Essex, UK | "I through bolted two, four inch (4") long stainless steel in the center"
If you're going to do that (I wouldn't) make sure you cut to exact length and fit a couple of spacer tubes to prevent the beam crushing.
John Alani ___________ Stealth F16s GBR527 and GBR538 | | | Re: Main traveler rail
[Re: Jalani]
#231820 05/03/11 12:09 PM 05/03/11 12:09 PM |
Posts: 5,525 | I was planning on using the tubes, like the internal downhaul.
Any other concerns?
[Re: orphan]
#231834 05/03/11 03:06 PM 05/03/11 03:06 PM |
Posts: 5,525 | Yes.
Unless I hear a compelling argument against the through bolt, I'll do that.
[Re: pgp]
#231838 05/03/11 03:58 PM 05/03/11 03:58 PM |
Posts: 548 MERRITTISLAND, FL | Yes.
Unless I hear a compelling argument against the through bolt, I'll do that. The whole reason to thru bolt is to be able to do solo. Add compression tubes and now you have a 2 man job again lining up things through the tube ends. Plus you have double the holes in the beam and fasteners under the beam to now catch on stuff. | | | Re: Main traveler rail
[Re: orphan]
#231872 05/04/11 07:43 AM 05/04/11 07:43 AM |
Posts: 5,525 | Not to hijack my own thread, but do any of these techniques make the beam stiffer?
[Re: pgp]
#231874 05/04/11 07:55 AM 05/04/11 07:55 AM |
Posts: 4,119 Northfield Mn | Orphan- I get it, I wasn't being a dick, its probably the easiest, and strongest solution.
Pete- I doubt any of these would have a significant impact on rigidity one way or another. I don't like the through bolting just because you're making another spot for corrosion and electrolysis to go to work. Plus having one more thing for lines, sheets, and bungee to potentially get caught on, and it only happens at the worst time....
[Re: orphan]
#231905 05/04/11 01:12 PM 05/04/11 01:12 PM |
Posts: 4,119 Northfield Mn | Is there a reason why no one uses a cross bar with an integrated track? Like the tornado. AHPC beams are basically a Tornado shape, and have the track moulded in. I scored a Tiger rear beam that I'll be using if I ever do a home build, which is similar.
298
guests, and 48
