| I 20 set up help #23266 08/14/03 10:34 AM 08/14/03 10:34 AM |
Joined: Jul 2001 Posts: 1,253 Columbia South Carolina, USA dave mosley OP
Posts: 1,253 Columbia South Carolina, USA | Just boat an I 20, need some basic help. What size/type/length line are you using for the snuffer halyard?
anyone have an upclose pic of your downhaul you are willing to share?
What about class/fleet membership or website.
Thanks, David Mosley
| | | Re: I 20 set up help
[Re: dave mosley]
#23267 08/14/03 11:57 AM 08/14/03 11:57 AM |
Posts: 5,590 Naples, FL | Sorry I don't have any pictures, Dave, but the halyard is the same size for both snuffer and pole applications. It comes with the boat, and I'm guessing it's in the 5/16" range.
And downhauls vary as much as sunglasses. I used to have double blocks attached to a hook on each side of the sail's grommet to achieve the rated downhaul purchase. I have since moved to a cascade system (same purchase ratio). Here's a brief description of setup.
I tied two blocks (about 29mm)to the main via a short stretch of spectra through the grommet, and these hang about 2" from the grommet's lower edge. I have another pair of smaller blocks (sized for your downhaul line) with short pieces of spectra that go on next. The line on the smaller block is routed through the larger blocks on the main, and then led to the front of the mast, where the two lines are tied together (it is best to pull the sail down a bit and tie securely to minimize slack). The downhaul line is then led through the system as follows (from one side to the other):
Downhaul line through pivot/cam block (backwards, of course). Next, run line up through smaller block and back down to center cheek block on the mast. Continue back up other side through smaller block and down through pivot/cam block (forward).
As you pull the downhaul, the line will pull the smaller block downward through the bigger block attached to the grommet. That's the cascade system. It sounds complicated, but if I have a picture of it in use, I'll try to attach it...
| | | And one more thing
[Re: waterbug_wpb]
#23268 08/14/03 12:00 PM 08/14/03 12:00 PM |
Posts: 5,590 Naples, FL | If that's Team Space Coast's old boat, it should be all ready to go with the halyard and downhaul. If I recall, that boat did sell to someone in SC...
In any case, congrats on your fine choice of boats.
Jay I-20 USA 501
| | | Re: And one more thing
[Re: waterbug_wpb]
#23269 08/14/03 01:31 PM 08/14/03 01:31 PM |
Posts: 1,253 Columbia South Carolina, USA | Youre right, Team Space Coast' boat. The halyard just seems a little large, especially for the lake wind. Hope to sail with you guys soon!
David
[Re: Dlennard]
#23271 08/14/03 03:42 PM 08/14/03 03:42 PM |
Posts: 1,253 Columbia South Carolina, USA | I wasnt sure about the bungee above the spreaders, but thats how I ran it. Just dumb luck I guess. I did make the mistake of attaching the staight pole(non-snuffer) halyard and raising the mast, only to find the snuffer spin had its own halyard. I used the old paperclip and masking tape trick to run the snuffer halyard up. Okay, now how do you sail this thing? JK David, are you going to be racing for the Alter Cup quailfier with us? David Mosley www.seacats.org
| | | Might I recommend....
[Re: dave mosley]
#23272 08/14/03 04:19 PM 08/14/03 04:19 PM |
Posts: 5,590 Naples, FL | Two resources (well, actually three) 1. Rick's book - Cat sailing for the 90's. Good fundamental info 2. Rick Bethwaite's "High Performance Sailing" - sort of a "all hail the Aussie 18", but jam packed with moderately technical information 3. A amature website laden with tips and good ole' smack-talk www.1design.net Predominantly I-20 sailors, you'll get candid advice from national champs and wanna-be's like me! And I think this site tells me where you live, so if we don't see that boat at next year's St. Augustine regatta, we'll all have to go up there and beat you! Jay
| | | Re: Might I recommend....
[Re: waterbug_wpb]
#23274 08/14/03 09:31 PM 08/14/03 09:31 PM |
Posts: 1,253 Columbia South Carolina, USA | waterbug, Read Ricks book, took his class, sailed against some great sailors(Nigel Dave lennard, Rick Harper-My heroes) and now I am ready to step it up a notch and see what the I 20 class can do for me. I see that the portsmouth number is pretty low, maybe I can bring it up a little(HAHA) David Mosley www.seacats.orgCount me in for the St Augustine Regatta
| | | Dave, be easy on me....
[Re: Dlennard]
#23275 08/14/03 09:33 PM 08/14/03 09:33 PM |
Posts: 1,253 Columbia South Carolina, USA | Can you make Rick buy an I 20? We might have a fleet of 20's if so. Rick, Are you listening? Do I need to call your insurance co. for you? BTW 2 I 20's preregistered. See you on the water soon, David Mosley
| | | Re: Dave, be easy on me....
[Re: dave mosley]
#23276 08/15/03 08:07 AM 08/15/03 08:07 AM |
Posts: 12,310 South Carolina | I still can't believe my club hung me out to dry. ...I buy a 6.0NA with chute last year and everyone buys I20s....geeeze. There's always portsmouth I guess.
Jake Kohl | | | Re: Dave, be easy on me....
#23277 08/15/03 09:56 AM 08/15/03 09:56 AM |
Posts: 1,253 Columbia South Carolina, USA | Its Cary's fault. Jake , we had a good meeting last night and planned alot of stuff. I will update the website tonight(possibly) but the gist is.. Canoe/kayak down the Saluda river wed the 27th 3pm(then every 4th wednesday of the month) Mountain biking every sat 7am, Harbison state park One Lap of Lake Murray sept 14. Hunting Island camping biking, canoeing October 17-19 We are traveling the group to Catfest sept 6,7th.
David
668
guests, and 112
