| Re: Extreme sailing!!!
[Re: Joanna]
#231169 04/15/11 09:35 AM 04/15/11 09:35 AM |
Posts: 1,152 tampa, fl | Wow......lucky that no one was hurt.
If your havin girl problems i feel bad for you son I got 99 problems but my beautiful wife ain't one | | | Re: Extreme sailing!!!
[Re: ksurfer2]
#231172 04/15/11 09:54 AM 04/15/11 09:54 AM |
Joined: Jun 2009 Posts: 524 Petten Netherlands northsea junkie
Posts: 524 Petten Netherlands | Very basic sailing error.... When you have not enough speed after a manoeuvre but with full sail tight-in, the sailforce will push you over the diagonal because it's not compensated by the forces on the boat.
This particular case is one of the basic differences with a monohull!! Because the last will flip and turn in the wind.
ronald reeder
ronald RAIDER-15 (homebuilt)
[Re: Joanna]
#231173 04/15/11 10:20 AM 04/15/11 10:20 AM |
Posts: 12,310 South Carolina | Wow. Amazing that nobody was hurt. If you watch the slow mo closely, you can see the guy that is clinging to the trampoline at the rear stick his head into the **** in the hull as the mast collapses and the hulls come crashing down - that probably saved him from having the hull pile-drive him into the sail. I couldn't figure out how he didn't get hurt initially.
Jake Kohl | | | Re: Extreme sailing!!!
#231195 04/16/11 01:30 AM 04/16/11 01:30 AM |
Posts: 6,049 Sebring, Florida. | Did I read that right?
I thought it said one of them had 4 capsizes in one day?!
Are they slow learners or what?
Blade F16 #777
#231203 04/16/11 08:57 AM 04/16/11 08:57 AM | MN3
| MN3
Unregistered | | | | Re: Extreme sailing!!!
[Re: ]
#231244 04/18/11 08:31 AM 04/18/11 08:31 AM |
Posts: 186 Chattanooga, TN | The video makes it look like the redbull cat was almost righted by the crew. There had to be some outside help right? OR do they have some special righting system for the crew to use?
Jody
Blade F16 724
Plays with Sharp Objects
[Re: jody]
#231250 04/18/11 09:34 AM 04/18/11 09:34 AM |
Posts: 12,310 South Carolina | The video makes it look like the redbull cat was almost righted by the crew. There had to be some outside help right? OR do they have some special righting system for the crew to use? I'm pretty sure the rib was pulling a line from over the top hull.
#231252 04/18/11 09:51 AM 04/18/11 09:51 AM |
Posts: 6,049 Sebring, Florida. | In the video it looked like Muscat would have been ok to re-right...until those two guys landed on the mast and snapped it. The 3 others masts all seemed to hold up, except the one that turtled, how did they right that? I was surprised at how quickly they seem to bury a bow and go over though, and how slowly they were to dump the mainsheet and traveler.
I guess it's probably wrapped around a winch drum so they can't quickly release it all, before things get too sideways?
I wonder how fast the ones that stayed upright were going on the downwind legs.
Now you know why most fat old guys sail monohulls!
Blade F16 #777
| | | Re: Biggest Extreme 40 crash ever?
[Re: Jalani]
#232879 05/27/11 11:45 AM 05/27/11 11:45 AM |
Posts: 1,152 tampa, fl | That was ALMOST a brilliant move. Had Alinghi actually pulled off saiing under the startboard tack boat, it would have been the move of the century!
440
guests, and 92
Mod | | Forums26 Topics22,404 Posts267,055 Members8,150 | Most Online2,167 Dec 19th, 2022 | | |
