| Daggerboard position? #232911 05/28/11 09:27 PM 05/28/11 09:27 PM |
Joined: May 2006 Posts: 1,383 Kingston SE South Australia JeffS OP
Posts: 1,383 Kingston SE South Australia | G'day I need to finish of some new hulls for a Mozzie and am wondering if there is a set position where the trunk has to be on the hulls or if there is an optimum position for it to be sailed by one 70kg teenager or 130kg with crew? If we were to play around with square top sails for our club sailing would that change the position of the trunks? Are the boards straight down or slightly cantered? regards Jeff
| | | Re: Daggerboard position?
[Re: JeffS]
#232917 05/29/11 02:09 AM 05/29/11 02:09 AM | thricebitten
| thricebitten
Unregistered | Hi Jeff, these days everybody seems to put them at the maximum distance aft, there is a measurement on this. Also most are put in with maximum angle aft as well, this is also in the Measurement Rules. I put mine in straight, to try and get more lift. But I don't think it makes a lot of difference for an old boat, probably better to angle them back to avoid weather helm for a less experienced sailor. Wouldn't bother with the Square Top, the one we experimented with we couldn't get to go any faster than standard sail  . Also square top just makes the bows easier to bury. After all Mossie is fast enough as is  .
[Re: ]
#232919 05/29/11 05:52 AM 05/29/11 05:52 AM |
Posts: 1,383 Kingston SE South Australia | Thanks Gary that helps a lot. I'll go with the rules. The square top is just a thought to try to get more of the juniors on a mozzy at club level. We had two F16 Blades at our race and we have 4 more juniors that want them but no one will pay for them, so just thinking outside the square.
[Re: JeffS]
#233220 06/04/11 07:06 AM 06/04/11 07:06 AM |
Posts: 92 South Oz | Jeff, Aft edge of centre board case opening is max 3353mm measured from the bow along the centre line of the hull. If the hulls are beamed take care tape measure is straight. Max rake (aft) of centre board is 10degrees. I measure this using a straight edge on top of the two beams, centreboard raised up above the straight edge, measure the angle between the straight edge and the forward edge of the centreboard (usually a straight edge also). I also check the centreboard cannot be swung forward/aft within its case during sailing thus increasing this rake angle. Phillip Pearce
Tortured ply is clearly beautiful. Mozzie Aldebaran VI 1827
[Re: Phillip]
#233222 06/04/11 08:42 AM 06/04/11 08:42 AM |
Posts: 1,383 Kingston SE South Australia | Thanks Phillip I've gone with nearly maximum aft
[Re: MD moz 1277]
#233351 06/08/11 05:08 PM 06/08/11 05:08 PM |
Posts: 1,383 Kingston SE South Australia | The juniors have already asked, if I get a chance to set a kite up before I take it to the Lake Eyre Yacht Club regatta in July, I'll have a go with her then, first I have to find an old spin the right size
[Re: dkd]
#233543 06/15/11 09:00 AM 06/15/11 09:00 AM |
Posts: 1,383 Kingston SE South Australia | Thanks DKD I now have a spin just need to get it all together and organise a snuffer etc
16,569
guests, and 1,002
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online22,490 7 hours ago | | |
