| Replacement Main Sail #233689 06/17/11 11:27 PM 06/17/11 11:27 PM |
Posts: 3 Waco, TX | I am looking at a decent used Wave on a trailer for $2000 or probably a little less. Problem is that it has a trashed main sail and am trying to figure out how much a main sail will cost me to determine if the boat makes any sense price wise.
I saw a couple brand new Hobie factory Wave mains sold on the secondary market (ebay etc) for about $550, but the two I knew about a couple of weeks ago have sold and no others have surfaced on these markets.
I see the following after market sails available:
Calvert High Modulus Cross-Cut 5 oz. White Dacron Sail for $ 588.00, including battens
Calvert TriRadial Cut Pentex Sail for $940, including battens
Calvert Color Load Path Technology Design $1.045, including battens
Others for about $600 in white or solid colors.
I really wanted a nice brightly colored sail, instead of white, but the new Hobie factory colored sails from my dealer are pretty pricy, as are the Calvert colored sails. I know we used to think that plain white sails kept their shape better than colored sails, especially multi-colored sails, but I’m guessing material technology has caught-up some here.
I expect I will be sailing the Wave primarily solo here in central Texas where our summer winds are usually light, but spring and fall winds can be much heavier.
My use will primarily be day sailing, but I would hate to rule out an occasional class race by buying a sail not legal for class racing. It seems after market sails of standard dimensions are OK at some regatta’s, but maybe not all?
If anyone knows where a good used Wave sail could be purchased for a reasonable price, please point me that direction.
I want to make a decision ASAP so I can get to sailing and I’m concerned that the usual 6-8 weeks wait for made-to-order sails will eat-up too much of my sailing season, so quick delivery is an issue also.
Help me make a good decision. | | | Re: Replacement Main Sail
[Re: sbmcruise]
#233764 06/20/11 07:38 AM 06/20/11 07:38 AM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | You do not have to have a Hobie sail to be class legal, since all of the racing of Waves is un IWCA, which allows any sailmaker. The sail has to measure in , but you can have any sailmaker's sail. On our store we have several sailmakers: Calvert, Whirlwind, Super Sails and SLO. Whirlwind has colored Wave Sails. Rick | | | Re: Replacement Main Sail
[Re: sbmcruise]
#233980 06/23/11 10:42 AM 06/23/11 10:42 AM |
Posts: 778 Houston | I can't help you on used sails but I need to point out something. You may already know that you are on the south edge of one the last Hobie Fleets left, Fleet 23 in Dallas. If you are planning to race in any of their events, you need to check with them and find out if they race Waves under IWCA or HCA rules or if they even care. The last time I checked Mid Americas was under HCA rules.
If you go in any other direction(Austin, Houston, Louisiana) you are welcome under any rules. To tell the truth, since it's a Wave, you could show up with anything short of a rigid wing and nobody would know the difference.
I sause a Calvert Load Path becuse I have found that type of sail lasts longer in the weekly racing I do. While I like the sail, I will probably go with a local sailmaker for my next oneI have 3 1st class lofts in my area and having the sailmaker put the sail up and show you what they designed it to look like is worth weeks of work.
From my experience for a avaialble sail, I would try Rick's, the Boaters Resale shops, then Hobie dealers like KO in Houston and if they can't help, try Bank's Sails in Houston. I have talked to Bank's about building a Wave sail and they have measurements. | | | Re: Replacement Main Sail
[Re: RickWhite]
#234860 07/14/11 11:28 AM 07/14/11 11:28 AM |
Posts: 1,252 California | You do not have to have a Hobie sail to be class legal, since all of the racing of Waves is un IWCA You might be closer to reality by saying "most"... likely just "many", but certainly not "all" Wave races are IWCA. Maybe... "all IWCA races are under IWCA rules". The Hobie Class Association does offer events for Waves which are under IHCA rules requiring a Hobie Class approved sail. I have personally sailed in HCA Wave events over here on the West Coast, a number of times. Fyi... the HCA events that I have sailed have been focused on entry level and youth. I sailed those events with my son. Note that the standard and class-approved sails from Hobie Cat are sometimes the less expensive option as well. Some of the custom sails being pushed are not cheap. | | |
3,833
guests, and 693
