| Sail top opening up #233998 06/23/11 06:12 PM 06/23/11 06:12 PM |
Joined: Dec 2008 Posts: 329 Chicago, Illinois USA TEH OP
Posts: 329 Chicago, Illinois USA | I have learned a lot about keeping the boat down in higher winds from everyone here. I am still having some issues.
Recently when sailing and the wind got a little sporty, I looked up to see if my leech was opening. It was still very closed. I had pretty good downhaul on and was sheeted in. Maybe its not supposed to open up under such a tuning setup. Any comments...
Blade F16 USA 725
| | | Re: Sail top opening up
[Re: TEH]
#234001 06/23/11 08:10 PM 06/23/11 08:10 PM |
Posts: 439 Memphis, TN | It should open up...
Sometimes, it will look like it's not open, but it is. Let's say that it wasn't though, what about your rotation? Where was that? How windy was it?
Viper USA 132
1984 Hobie 18
[Re: mikeborden]
#234005 06/24/11 02:56 AM 06/24/11 02:56 AM |
Posts: 118 Pensacola, FL | http://4.bp.blogspot.com/-5lCkPjiew1o/TcCESQbQFuI/AAAAAAAAHNk/VQMGSkyI93E/s1600/AClassPeyron124.jpgI think this sail looks pretty good. If you look at the curve in the battens you can see he has it flat at the top but still full at the bottom. As you depower, watch the top battens. You want to see the top flatten. I would start with the rotation at the side stay. The top should flatten pretty quickly as downhaul and main are tightened because the mast is bendy on the narrow axis/unsupported at the top. Then bring the rotation back. When you see the top of the sail start to get fuller you have rotated too far back. The top of the mast is straightening out because it is stiff on the wide axis. You would like the sail to be flat and rotate back a lot but our mast does not support this.
Chris Trident F16
271
guests, and 60
