| Re: F16 spinnaker dimensions
[Re: David Parker]
#234145 06/28/11 09:39 AM 06/28/11 09:39 AM |
Posts: 5,525 | I can't find my cert.! If it shows up I'll send the dimensions.
Pete Pollard Blade 702
[Re: David Parker]
#234293 07/02/11 02:46 PM 07/02/11 02:46 PM |
Joined: Jan 2004 Posts: 196 Arkansas, USA CaptainKirt
Posts: 196 Arkansas, USA | If you can imagine, when we were first starting the class Greg Goodall wanted us to use 21sqm (same as F18!) as max spi area since it was the same "hit" under Texel I believe. Luckily saner minds prevailed but I do have one of those 21sqm spis- I run it on my Freedom 21 mono now and it works well there ;-)
Kirt
Kirt Simmons Taipan, Flyer
[Re: waynemarlow]
#234296 07/02/11 04:44 PM 07/02/11 04:44 PM |
Posts: 5,525 | Do you suppose a roller furling headsail would work? Not for racing, just for easier rigging and pleasure sailing.
[Re: pgp]
#234349 07/04/11 07:25 PM 07/04/11 07:25 PM |
Posts: 196 Arkansas, USA | That's basically Rick (White's) "Hooter" idea- very flat, even could be used upwind in light air, problem was the increased need for really tight luff tension. AHPC supposedly voided the warranty if you used them due to this issue. Now if you used a pole that had a striker so all the tension was on the pole and at the bow tangs it might be okay. Remember the American Tornado sailors in the last Olympics used the very flat Chupacabra spi- but it was a disaster vs the conventional spis on the course because the wind blew too hard to use it upwind and downwind it was slower- In the Worrell I ground crewed on we used too large a spi for our Taipan 5.7- the Nacras had larger, but flatter spis so could use at larger angles vs ours- definite advantage in distance racing. There was a boat with one of Rick's Hooters- they were newbies- sail did good reaching but couldn't match the larger spis at deeper angles.
Kirt
Kirt
20,023
guests, and 1,305
