| Re: Big Guys and Wave Racing
[Re: BigWhoop]
#234078 06/27/11 08:13 AM 06/27/11 08:13 AM |
Joined: Aug 2007 Posts: 342 Indianapolis, IN - Midwest USA... IndyWave
Posts: 342 Indianapolis, IN - Midwest USA... | I put a tiller extension on mine, but I remove it when racing with IWCA. Locals don't know the difference.
A class-legal manueuver is to tie the bitter end of the mainsheet to a corner of the tiller crossbar, and tug to steer.
What most folks do when racing downwind is to simply lie face-down on the tramp (head foreward) and steer with your toes. There are lots of photos on this site of IWCA racers employing this technique.
What - Me Worry?
2006 Hobie Wave 7358 "Ish Kabibble"
[Re: IndyWave]
#234211 06/29/11 02:40 PM 06/29/11 02:40 PM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | Tiller extensions are not allowed and for a very good reason. Nor are any lines, bungees, or the like. You have to steer with your hands, feet or whatever other body part you feel will work. Hummm, that leaves a lot to the imagination. After 14 years of racing them we have all concluded that lighter sailors are faster off the wind. But, once we found that the taller, heavier people could get further forward than the little people, they did not gain as much distance. If they had extensions, you would automatically lose all bigger sailors in the class. There may be many other factors to your problems. Several of us tried Whirlwind and made suggestions to Chip to get them faster, but he didn’t particularly want to work with to get them faster. For your weight you will need a fuller sail than your smaller competitors. At this point the best sailmakers are Calvert (sold on this site) and Bossset North Sails (NJ somewhere). I am playing with a Dacron Calvert that is very full – I was 235, but now down to 192. Next there is the rigging. The hot setup is to use a 10 hole adjuster on the forestay and have slack sidestays. Mine were so slack I took the adjusters off and just use shackles. As you found out weight distribution is paramount. | | | Re: Big Guys and Wave Racing
[Re: RickWhite]
#234219 06/30/11 07:05 AM 06/30/11 07:05 AM |
Joined: Jun 2006 Posts: 41 Ottawa, Canada BigWhoop OP
Posts: 41 Ottawa, Canada | Thanks, Rick. I read somewhere, a back issue of the print edition I think, about techniques for us bigger guys to keep up. I was hoping for a magic bullet. It was up to 25 knots last night and it was a hoot! What a great boat! But, unfortunately for me, I still have a similar speed disadvantage. 50 yards at A, 300 or 400 at the finish. I'm using the 10 hole adjuster and really sloppy, hand can turn at least 45 degrees, stays. I don't believe that a $1000 sail is going to be 400 yards faster.
Discouraged.
Except for the fun of sailing the boat in that much breeze. | | | Re: Big Guys and Wave Racing
[Re: BigWhoop]
#234220 06/30/11 07:27 AM 06/30/11 07:27 AM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | The Dacron Calvert sail is priced pretty fairly at $588 and is definitely faster than Whirlwind. Here is the link: https://store.catsailor.com/pc/viewPrd.asp?idproduct=30719&idcategory=257As I said the one I have is full, so I max out the downhaul and sheet really hard, hooking up the sheet as far forward as I can go, and that flattens it out pretty well. In light air, just ease it off. Rick | | | Re: Big Guys and Wave Racing
[Re: BigWhoop]
#234356 07/04/11 10:58 PM 07/04/11 10:58 PM |
Posts: 61 Albenarle NC | Make sure the mast takes the slack out of the sidestays. I can't get my boat going with too much rake like the other sailor do. Get the boat to go on all points of sail if you have to give up somewhere. Good Luck
[Re: RickWhite]
#234445 07/06/11 08:07 AM 07/06/11 08:07 AM |
Posts: 41 Ottawa, Canada | Well, Rick, I've cleverly arranged for my boat to be deeper in the water, by a 1/2 " or so, to provide more resistance to leeway. So I should need to rely less on the rudders, right?
You know I could do some math, each hull is about 10.25 sq. ft. in area. Mine displaces about 100 pounds more water than yours, or 1.5 cubic feet, so I push the boat .14 inches deeper in the water. Call it an 1/8". Wait ... there's two hulls. So now we'll call it 1/16". Crap. It's hard for me to imagine that little bit of extra wetted surface makes any difference at all. Unless there's something I'm missing. I should quit whining and learn to sail.
Crap. Nut on the end of the tiller again. | | | Re: Big Guys and Wave Racing
[Re: BigWhoop]
#234448 07/06/11 09:39 AM 07/06/11 09:39 AM |
Posts: 921 Alachua, FL | BW,
It sounds like you have a fleet. Y'all ought to come down to the Put-In-Bay Bay Week Regatta. We will have nearly 30 Waves.
August 5-8.
We can argue with Rick about tiller extensions.
I think we should have a minimum crew weight of 150# and anyone over 180# can have a tiller extension. That is just my opinion.
Jack Woehrle Hobie Wave #100, Tiger Shark III HCA-NA 5022-1 USSailing 654799E Alachua FL/Put-In-Bay | | | Re: Big Guys and Wave Racing
[Re: Mugrace72]
#234454 07/06/11 10:17 AM 07/06/11 10:17 AM |
Posts: 61 Albenarle NC | Check out the F18 YouTube on boat balance at the top of the page. Jack has a good idea. Come down to PIB and try out some other sails and see if your better. I'm sure you can If you get there a day or so early.
[Re: Mike Fahle]
#234555 07/08/11 09:22 AM 07/08/11 09:22 AM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | Your a tough-love coach, Mike!
Right on, Put in Bay is located on South Bass Island, probably the most fun island in North America. We have a strong fleet of racing sailors, including two world champs, 3 National Champs, and two North Americans. Plus for that regatta my son and daughter-in-law (she is two time national and one time NA)and he has been runner up to her most of those times. SO, there will be a lot of talent and all are willing to share their knowledge | | |
2,742
guests, and 379
