| Repair, replace or enjoy as is? #23439 08/21/03 11:58 AM 08/21/03 11:58 AM |
Joined: Aug 2003 Posts: 43 Magnolia, Texas NacraMike OP
Posts: 43 Magnolia, Texas | Hi folks. New member of your forum here. It has been a pleasure lurking for a while. I have gained some great insight from your posts. My wife and I are long time beachcat sailors. We started in the early 70's sailing Solcats, Prindels and Zcats. We got away from sailing while we raised a family for a few years. Now we have jumped back in catsailing with both feet. We recently aquired a 88' Nacra 5.7 (for my wife) and a 80' Nacra 5.2 (for me). The 5.7 is a cherry. The 5.2 has a problem I need your advise on. The bottom of the port side hull, under the front cross tube, has a huge dent in it. I have thrown some photos on a web page if you would like to see the damage. Hull Damage Photos. The deck is flat, so it's not bent. just a huge dent. Any ideas about a fix. Can a replacement be found, or just sail with it. I await your expert advise. Best regards, Mike | | | Re: Repair, replace or enjoy as is?
[Re: NacraMike]
#23440 08/21/03 12:16 PM 08/21/03 12:16 PM |
Posts: 75 Jensen Beach, FL | Repairable........ Always use hull cradles on Nacra trailers.  Especially on the front. My boat has recieved similar damage but not quite as severe. Is the area soft? Or is it more of an impact damage?  AJ Nacra 6.0 Express | | | Re: Repair, replace or enjoy as is?
[Re: BlowMe]
#23441 08/21/03 12:26 PM 08/21/03 12:26 PM |
Posts: 43 Magnolia, Texas | The damaged area is hard as a rock. No softness. Must have been a collision with a slightly submerged object. I don't know for sure. I bought it that way (price was extreemly right). I'm 100% with you on the cradles. That will be my next investment for the boat. Does it look to you like a repair most any fiberglass boat repair shop can handle?
Regards, Mike
[Re: BlowMe]
#23443 08/21/03 03:18 PM 08/21/03 03:18 PM |
Posts: 43 Magnolia, Texas | Thats great news Mr. ME. I was expecting the worst. Thanks so much for the swift reply. I just hate riding around on a ugly boat. Off for repair quotes we go.  Best Regards, Mike | | | Re: Repair, replace or enjoy as is?
[Re: NacraMike]
#23446 08/22/03 09:23 AM 08/22/03 09:23 AM |
Posts: 12,310 South Carolina | dagger board case...
I had a Hobie 18 that had similar damage (I also had a 5.2 that I still regret selling). I would take some cardboard paper towel tubes and coat them with several layers of glass and epoxy. Once you have the damaged area pushed back out, I would put several layers of glass on the inside of the damaged area and use the tubes, trimmed to fit the sides and bottom, to brace the area to the upper sides of the hulls. It might be a good idea to put a brace between the two tubes forming sort of a v-shaped "H".
Jake Kohl | | | Re: Repair, replace or enjoy as is?
[Re: NacraMike]
#23448 08/22/03 01:23 PM 08/22/03 01:23 PM |
Posts: 12,310 South Carolina | hmmmm...I was assuming that since it pushed in that it would be possible to push back out. You are probably right though that it would be difficult to get it back into the proper shape. You could make that call after you put in the port though. Maybe?
Making a female mold of the starboard hull and then a cap from that sounds like the most precise, but time consuming, fix after considering that.
[Re: NacraMike]
#23450 08/25/03 02:09 PM 08/25/03 02:09 PM |
Posts: 217 | I did a repair very similar to this on a 5.2 of '76 vintage. First, I placed an inspection port on top side - note - cut the hole for the port, but do not put port in place till after all the bottom side work - you'll have a bigger hole to work in, and you won't gum up the new port. I cut out the damaged area & feathered the edges. I made an outside mold - low tech - waxpaper & tape. Then made one thin glass/resin layer on inside of hull, working through the porthole. Then took off "mold", and finished up the outside with another layer or 2 of glass/resin, and painted. It was very strong, and no more weight than original. Fiberglass work is very easy, if you use good materials, and aren't obsessed with weight or beauty.
Hull cradles - are very nice, but in my opinion, are not required to be as curved. I just use a 24" piece of 2x6 under each hull at each roller. The length of the board is aligned with hull, I have small cross-pieces on the bottom of the 2x6 to keep it from jumping off the roller. This wood keeps the weight of the boat distributed on a larger area of the hull ( 18-24 sq inches?) than just the intersection of the roller and hull (1 sq inch?).
2,837
guests, and 351
