Stainless Tools #235009
07/20/11 07:54 PM
07/20/11 07:54 PM
Lake Lanier, Georgia
hobiesailor Offline OP
Anyone have a good source for a 17mm Stainless wrench? I've found some standard ones but no metrics. At this point I'm leaning to get a craftsman one and just plan to replace it once a year or so when it rusts.
This is for a Infusion diamond adjuster.
What do other people use?
Re: Stainless Tools [Re: hobiesailor] #235027
07/21/11 10:03 AM
07/21/11 10:03 AM
It still works when it's rusty.
Re: Stainless Tools [Re: Jake] #235029
07/21/11 10:11 AM
07/21/11 10:11 AM
Dunedin Causeway, FL
David Parker Offline
Hmmmm....what is the best smart-a$$ comment to this loaded line?
Re: Stainless Tools [Re: hobiesailor] #235033
07/21/11 11:27 AM
07/21/11 11:27 AM
Houston
carlbohannon Offline
Houston
I have the same problem with a Marstrom and my home built.
There are stainless metric wrenchs available but they are not cheap. You are looking at $50-80.
For high quality, try:
http://www.steritool.com/tools/open_end_wrench.htm
China is starting to sell Cu-Be and soft stainless wrenchs
http://www.aliexpress.com/store/200...rench-DIN-Standard-Aluminium-Bronze.html
These are 304 SS which are really too soft for wrenchs and Cu-Be is toxic.
You can also try eBay for direct sales from China
I personally use some SK wrenches from the local auto parts store, marked "Rust resistant, triple plated" that I sprayed with bake on type cold galvenize. They rust a little They rust a little but, I will probably lose it over the side before it becomes unusable.
Re: Stainless Tools [Re: hobiesailor] #235038
07/21/11 01:25 PM
07/21/11 01:25 PM
F18_VB Offline
F18_VB  Offline
I don't have one, but you might want to look at McMaster-Carr part 6795A28. It is a 15mm / 17mm ratcheting, stainless, open wrench for $18.
Re: Stainless Tools [Re: F18_VB] #235041
07/21/11 01:55 PM
07/21/11 01:55 PM
brucat Offline
brucat  Offline
Just out of curiosity, why does it need to be stainless? Are you really taking it on the water to adjust diamond tension?
Re: Stainless Tools [Re: brucat] #235042
07/21/11 02:14 PM
07/21/11 02:14 PM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
yep
F18 USA 242
http://www.solarwind.solar
Re: Stainless Tools [Re: brucat] #235044
07/21/11 03:27 PM
07/21/11 03:27 PM
yepers
Re: Stainless Tools [Re: Jake] #235051
07/21/11 07:53 PM
07/21/11 07:53 PM
Williamston, sc
h18catsailor Offline
Williamston, sc
just a thought, what if you used a cheap wrench, spray it with WD40 and put in a ziplock.
David Strickland
Hobie 18
HEAVY air crew on a J22
Re: Stainless Tools [Re: h18catsailor] #235053
07/21/11 10:15 PM
07/21/11 10:15 PM
mikekrantz Offline
mikekrantz  Offline
Do like Mr Lennard did for us - make a titanium 17mm set wrench, light and rust free
Re: Stainless Tools [Re: mikekrantz] #235058
07/22/11 07:21 AM
07/22/11 07:21 AM
tampa, fl
K
ksurfer2 Offline
ksurfer2  Offline
K
tampa, fl
Is there anything Dave Lennard can't do? He's like the Chuck Norris of cat sailing!
Re: Stainless Tools [Re: mikekrantz] #235059
07/22/11 07:28 AM
07/22/11 07:28 AM
Clermont, FL, USA
Clermont, FL, USA
Brilliant! I'll get that on my crew's todo list... that's crew work right?
F18 USA 242
Re: Stainless Tools [Re: David Ingram] #235060
07/22/11 08:03 AM
07/22/11 08:03 AM
JACKFLASH Offline
JACKFLASH  Offline
I purchased a cobalt brand wrench from Lowes. It has a ratchet end that swivels which makes it easier on the knuckles. I also drilled a hole in the handle and used a thin line to secure it around the post the mast ball sits on. A fresh water bath after races and a shot of Boeshield in the ratchet mechanism and it is going strong. The string is long enough to allow us to store in the tramp with the righting line and to use it without untieing anything.
Collin Casey
Re: Stainless Tools [Re: hobiesailor] #235061
07/22/11 08:06 AM
07/22/11 08:06 AM
srm Offline
srm  Offline
Go with the Craftsman - unconditionally guaranteed for life.
Personally, I'd me more concerned about dropping an expensive tool in the drink than I would be about a little rust.
sm
Re: Stainless Tools [Re: David Ingram] #235063
07/22/11 08:51 AM
07/22/11 08:51 AM
I thought you just made your crew use their fingers...
Re: Stainless Tools [Re: srm] #235073
07/22/11 10:46 AM
07/22/11 10:46 AM
Houston
Houston
sm
In my experience the issue is not rust, it will rust. The real issue is finding a big rust stain on your hulls, tramp, or sails. My wrench rusts away happily in a Vinyl pouch along with some rusty pliers and some spare parts. For several years, the ghost of a big rust stain reminded me to always put it back and never leave wet sails laying on it.
I asked the experts at work and they are now using polymer coatings for salt water. They have never tried it but they said there are do it yourself systems like DuraCoat.
Does anyone have any experience with this?
Re: Stainless Tools [Re: carlbohannon] #235075
07/22/11 11:27 AM
07/22/11 11:27 AM
no experience with coatings - but I leave the tools in the trapoline pouch where they only have access to stain my righting line or an empty water bottle or two.
Re: Stainless Tools [Re: David Ingram] #235079
07/22/11 01:03 PM
07/22/11 01:03 PM
2017 F18 Americas Site
Dan_Delave Offline
Dan_Delave  Offline
I would love to see a picture of it and know how he made it. I need one!
Right now I use a Craftsman Pro 17mm which I drilled a hole in to attach a line. It is working but rusting. I would love to have a clean rust-free tool while out on the water.
Dan
Re: Stainless Tools [Re: Dan_Delave] #235087
07/22/11 02:05 PM
07/22/11 02:05 PM
Dan
a 2" x 12" titanium plate is something like $80.
Re: Stainless Tools [Re: Jake] #235094
07/22/11 02:57 PM
07/22/11 02:57 PM
TeamChums Offline
TeamChums  Offline
Just make one out of wood and be done with it.
Lee
0 registered members (), 2,631 guests, and 406 spiders.
Yesterday at 10:10 AM
