| NACRA 5.0 hull repair (structural?) #234979 07/19/11 09:14 PM 07/19/11 09:14 PM |
Joined: Sep 2009 Posts: 11 Corpus Christi Bay, TX ccmac OP
Posts: 11 Corpus Christi Bay, TX | (re)broke my hull just below the aft crossbeam last week--not sailing hard, just 15kts & smooth water. It's a well-used '83 nacra 5.0 in Corpus Christi, TX, but the hulls are otherwise OK. I paid a "pro" to repair a nearly identical crack last summer, but then only got a few months of sailing out of it before it came back. To my untrained eye, this looks like a long history of sloppy repairs. Without any experience with fiberglass work, I'm hesitant to tackle a job where others have failed. I'd be more willing to experiment if it were a more vanilla hull puncture, but this looks structural. Any suggestions, or is it time to part the old girl out on craigslist?
Josh
[img]http://www.flickr.com/photos/12713306@N02/5952705329/[/img] [img:left]http://www.flickr.com/photos/12713306@N02/5956037171[/img]
Josh '83 Nacra 5.0 - 1075
| | | Re: NACRA 5.0 hull repair (structural?)
[Re: ccmac]
#235008 07/20/11 06:04 PM 07/20/11 06:04 PM |
Posts: 757 japan | that is a highly stressed area, but it should be possible to rebuild it as strong is enough overlapping glass is used inside.....................but you'll need a structural repair, not a cosmetic repair
any pics of the inside?
were you aware that the "chip" on the strap is upside down and backwards? that would have a tiny effect on how the bolt worked the captive nut....
[Re: erice]
#235010 07/20/11 08:42 PM 07/20/11 08:42 PM |
Posts: 11 Corpus Christi Bay, TX | http://www.flickr.com/photos/12713306@N02/5955981911 http://www.flickr.com/photos/12713306@N02/5956037171
Here are two photos from the interior.
I had no idea about the chip upside down and backwards--it was like that when I bought it two years ago. How should it be oriented?
How would you describe the difference between structural and cosmetic repairs?
Josh
[Re: ccmac]
#235023 07/21/11 09:07 AM 07/21/11 09:07 AM |
Posts: 35 Lake Norman. NC | How would you describe the difference between structural and cosmetic repairs?
If you can fix it with less than one roll of duct tape, it's a cosmetic repair. Any more than one roll, it's structural. | | | Re: NACRA 5.0 hull repair (structural?)
[Re: erice]
#235028 07/21/11 10:05 AM 07/21/11 10:05 AM |
Joined: Jun 2001 Posts: 890 Dunedin Causeway, FL David Parker
Posts: 890 Dunedin Causeway, FL | were you aware that the "chip" on the strap is upside down and backwards? that would have a tiny effect on how the bolt worked the captive nut.... I disagree. It looks like the curved edge of the "chip" is down and toward the strap so the strap follows the gentle curve of the chip rather than its sharp corner. The old 1985 Nacra manual says, "Be sure the curved edge of the black chip is down so that the strap takes the same curve as the black chip." There is a round edge on both ends so you have to look closely. I think he has it right. However, I doubt that this caused the hull to fail. The cool thing about fiberglass is that if you think large you can cut open the hull, lay down significant glass and resin, put in a new backing plate for the bolts, and then do a good gel coat repair. It will be as good or better than new. You just have to think major and not think just skin repair. It's not hard work, you just have to be committed to the bigger fix and be willing to get out the chain saw for that first cut. After that it's play dough and paint. Don't abandon the boat over this. | | | Re: NACRA 5.0 hull repair (structural?)
[Re: David Parker]
#235047 07/21/11 05:16 PM 07/21/11 05:16 PM |
Posts: 757 japan | - as long as a curved face of the chip is against the curve of the strap then it's right, think my 1982 chips have only 1 curved edge, but if these chips have 2 that would explain why you can see 1 of them NOT against the curve of the strap...
- i would define a cosmetic repair as 1 where someone with next to no knowledge of frp structures went in to "make it look like new" (like maybe a car repair shop worker) and a structual repair as 1 where someone who had a reasonable sense for frp and beam loads on a beach cat when in to "make it stronger than before"
- the pics of the inside look pretty ugly to me, ie cosmetic repair was done by someone with no real idea of frp repairs
- repairing a botched repair is harder than simply repairing a break/crack so if i were you i would be asking around at boat shops for someone who builds or repairs boats to have a look at you hull and quote a repair.....with only a basic understanding myself i would think you need at least 3 overlapping layers of woven cloth on the inside and maybe the same on the outside, which would take a lot of finishing...
[Re: David Parker]
#235048 07/21/11 05:37 PM 07/21/11 05:37 PM |
Posts: 11 Corpus Christi Bay, TX | How large should I think here? Am I looking at cutting out an inch or two around the fissure, or should it be a basketball-sized hole to fill in and mold?
Is there anything you can see in the pictures to suggest what mistakes were made in the earlier repair attempts? Any speculation? I'd be more comfortable tackling the project if I knew what NOT to do.
Thanks for all the wisdom and encouragement, Josh
[Re: ccmac]
#235050 07/21/11 07:28 PM 07/21/11 07:28 PM |
Posts: 757 japan | hopefully someone more knowledgeable will step in...until then
- the internal pics seem to show a putty/cosmetic repair and not a woven cloth/structual repair
- you want to aim for something like 1. cleaning out the previous repair's? bondo and getting down to woven glass on both sides...this will be easy on the outside and difficult on the inside
2. putting a small patch of woven glass over the bare crack that overlaps all areas by about 2 inches
3. putting a 2nd patch on top that overlaps by about another 2inches
3. putting a 3rd patch over that with another 2 inch overlap
4. let set, fill crack void on other side with chopped up glass and resin, let set, grind flat
5. repeat 3 layer repair on other side, let set
6. fair outside repair with filler
7. brush over white gelcoat
[Re: erice]
#235103 07/22/11 05:50 PM 07/22/11 05:50 PM |
Posts: 1,307 Asuncion, Paraguay | hopefully someone more knowledgeable will step in...until then
7. brush over white gelcoat Use structural epoxy, not polyester resin.
Luiz
[Re: ccmac]
#235152 07/24/11 04:37 PM 07/24/11 04:37 PM |
Posts: 11 Corpus Christi Bay, TX | Here's a peek at the teardown process including some good profile views of what the last repair was like. Plenty of glass there, but it looks like they layed it down in 2-3 separate panels with few if any sheets making the turn THROUGH the corner...mostly just lots of bulk epoxy in the joint that had started crumbling. http://www.flickr.com/photos/12713306@N02/5971258523 http://www.flickr.com/photos/12713306@N02/5971820112 http://www.flickr.com/photos/12713306@N02/5971817742 -Josh
[Re: ccmac]
#235163 07/24/11 08:34 PM 07/24/11 08:34 PM |
Posts: 757 japan | looks like you've got the idea. what you need is LOTS of glass fibers running ACROSS the break and then solidly bonding to good glass over a wide area. try not to cut the cloth for the patches so that only 1 weave will cross the break. turn the cloth diagonally and cut it so both weaves cross the break. bi-axial. again, the 1st patch could cover the entire crack by 2inches and be bonded to nicely roughed up glass. the 2nd patch goes over the 1st patch while it is still wet and overlaps it by another 2" and is bonded onto a new area of lightly ground off glass. 3rd patch etc.
if it looks like getting 3 good patches down inside the hull is going to be next to impossible you could beef up the repair by adding a 4th layer to the outside.
for the strongest repair you'll want to use the heaviest cloth that will make the bends. this may mean laying some plastic film over each layer and taping it down until it has hardened enough to keep it's shape. then peeling off the plastic while the resin is still tacky and laying the next layer on top etc.
[Re: erice]
#235810 08/07/11 05:15 PM 08/07/11 05:15 PM |
Posts: 11 Corpus Christi Bay, TX | After finishing up the sanding & grinding, I created a backing piece to glue onto the inside of my gap. I molded cardboard and covered it with plastic packing tape to match the interior profile of the hull corner. I laid two pieces of wet-out 6oz fiber cloth onto the mold, and peeled it away when cured. The backing piece glued almost perfectly into the hull's interior with some ketchup-y resin+colloidal silica. I filled the low spots above the backing piece with filler & now I'm ready to start laying glass inside and out--hopefully three more layers inside and at least three on the outside. http://www.flickr.com/photos/12713306@N02/6019754000
[Re: ccmac]
#235817 08/08/11 03:16 AM 08/08/11 03:16 AM |
Posts: 757 japan | repair all looks good
that 2nd inspection hatch, which i think someone has put in forward of the beam, could cause problems down the track though...
[Re: ]
#235853 08/08/11 01:55 PM 08/08/11 01:55 PM |
Joined: Feb 2009 Posts: 678 Palm Beach County TheManShed
Posts: 678 Palm Beach County | OK here is my 2 cents worth: I've made repairs like this before and an outside patch will work for a while as evident with the last fix. But to make a strong fix cut a hole in the inside of the hull as an access port so you can get in and fix the area from the inside. Then fix it from the outside. The last step will be to fix your access hole. Here is a link to the type of repair I'm talking about: http://themanshed.net/archived-projects/g-cat-catamaran/?g2_page=2Few other things I’ve learned from experience use epoxy not a poly resin it just holds better and don’t use Bondo or plastic filler it will swell and absorb water. Do not use any fillers where your cross beam touches the fiber glass. The lay-up under the cross beam should be long pieces – no seams. Remember Mat has no strength. I use a woven biaxial or triaxial. Budweiser or Rum usually helps with the fiberglass itch if taken early enough.
Mike Shappell www.themanshed.comTMS-20 Builder G-Cat 5.7 - Current Boat NACRA 5.2 - early 70's | | | Re: NACRA 5.0 hull repair (structural?)
[Re: erice]
#235934 08/09/11 12:26 AM 08/09/11 12:26 AM |
Posts: 11 Corpus Christi Bay, TX | Erice, What kind of problems are you imagining for the inspection hatch? I already poked my boney butt through one on the opposite hull about a year ago, but that was an easy replacement.
Outside is glassed over with at least three layers of 60oz biaxial cloth all over & up to 6 or seven around some of the corner areas. Next up I'll be laying a similar mess on the inside corners. http://www.flickr.com/photos/12713306@N02/6024347439
[Re: ccmac]
#235939 08/09/11 07:00 AM 08/09/11 07:00 AM |
Posts: 757 japan | i think the hatches on the 5.0 should be like the 5.2
1 behind the aft beam
and 1 behind the main beam
your early series of photos show what look to be the inside of the hull forward of the beam, presumably your lowered your camera through a hatch forward of the beam
your later photos also seem to show a hatch forward of the beam
the factory presumably doesn't put hatches there as it is 1 of most highly stressed hull areas. there are huge loads in all directions from those long unsupported bows which is why when you see photos of collapsed cats it is usually the bows that have snapped off just forward of the main beam
you might get away with simply monitoring that area very closely or it might be better to remove the non-standard hatches there and glass in the holes
1 registered members (WorrellGal50),
427
guests, and 91
