| Re: Stainless Tools
[Re: hobiesailor]
#235027 07/21/11 10:03 AM 07/21/11 10:03 AM |
Posts: 12,310 South Carolina | Anyone have a good source for a 17mm Stainless wrench? I've found some standard ones but no metrics. At this point I'm leaning to get a craftsman one and just plan to replace it once a year or so when it rusts. This is for a Infusion diamond adjuster. What do other people use? It still works when it's rusty.
Jake Kohl | | | Re: Stainless Tools
[Re: hobiesailor]
#235033 07/21/11 11:27 AM 07/21/11 11:27 AM |
Posts: 778 Houston | I have the same problem with a Marstrom and my home built. There are stainless metric wrenchs available but they are not cheap. You are looking at $50-80. For high quality, try: http://www.steritool.com/tools/open_end_wrench.htmChina is starting to sell Cu-Be and soft stainless wrenchs http://www.aliexpress.com/store/200...rench-DIN-Standard-Aluminium-Bronze.htmlThese are 304 SS which are really too soft for wrenchs and Cu-Be is toxic. You can also try eBay for direct sales from China I personally use some SK wrenches from the local auto parts store, marked "Rust resistant, triple plated" that I sprayed with bake on type cold galvenize. They rust a little They rust a little but, I will probably lose it over the side before it becomes unusable. | | | Re: Stainless Tools
[Re: brucat]
#235042 07/21/11 02:14 PM 07/21/11 02:14 PM |
Posts: 3,906 Clermont, FL, USA |
| | | Re: Stainless Tools
#235051 07/21/11 07:53 PM 07/21/11 07:53 PM |
Joined: Sep 2003 Posts: 97 Williamston, sc h18catsailor
Posts: 97 Williamston, sc | just a thought, what if you used a cheap wrench, spray it with WD40 and put in a ziplock.
David Strickland Hobie 18 HEAVY air crew on a J22
| | | Re: Stainless Tools
[Re: mikekrantz]
#235058 07/22/11 07:21 AM 07/22/11 07:21 AM |
Posts: 1,152 tampa, fl | Is there anything Dave Lennard can't do? He's like the Chuck Norris of cat sailing!
If your havin girl problems i feel bad for you son I got 99 problems but my beautiful wife ain't one | | | Re: Stainless Tools
[Re: mikekrantz]
#235059 07/22/11 07:28 AM 07/22/11 07:28 AM |
Posts: 3,906 Clermont, FL, USA | Do like Mr Lennard did for us - make a titanium 17mm set wrench, light and rust free Brilliant! I'll get that on my crew's todo list... that's crew work right?
| | | Re: Stainless Tools
[Re: David Ingram]
#235060 07/22/11 08:03 AM 07/22/11 08:03 AM |
Posts: 291 | I purchased a cobalt brand wrench from Lowes. It has a ratchet end that swivels which makes it easier on the knuckles. I also drilled a hole in the handle and used a thin line to secure it around the post the mast ball sits on. A fresh water bath after races and a shot of Boeshield in the ratchet mechanism and it is going strong. The string is long enough to allow us to store in the tramp with the righting line and to use it without untieing anything.
| | | Re: Stainless Tools
[Re: David Ingram]
#235063 07/22/11 08:51 AM 07/22/11 08:51 AM |
Posts: 5,590 Naples, FL | Brilliant! I'll get that on my crew's todo list... that's crew work right? I thought you just made your crew use their fingers...
| | | Re: Stainless Tools
[Re: srm]
#235073 07/22/11 10:46 AM 07/22/11 10:46 AM |
Posts: 778 Houston | Personally, I'd me more concerned about dropping an expensive tool in the drink than I would be about a little rust. sm In my experience the issue is not rust, it will rust. The real issue is finding a big rust stain on your hulls, tramp, or sails. My wrench rusts away happily in a Vinyl pouch along with some rusty pliers and some spare parts. For several years, the ghost of a big rust stain reminded me to always put it back and never leave wet sails laying on it. I asked the experts at work and they are now using polymer coatings for salt water. They have never tried it but they said there are do it yourself systems like DuraCoat. Does anyone have any experience with this? | | | Re: Stainless Tools
[Re: carlbohannon]
#235075 07/22/11 11:27 AM 07/22/11 11:27 AM |
Posts: 12,310 South Carolina | no experience with coatings - but I leave the tools in the trapoline pouch where they only have access to stain my righting line or an empty water bottle or two.
[Re: David Ingram]
#235079 07/22/11 01:03 PM 07/22/11 01:03 PM |
Joined: Mar 2002 Posts: 984 2017 F18 Americas Site Dan_Delave
Posts: 984 2017 F18 Americas Site | Do like Mr Lennard did for us - make a titanium 17mm set wrench, light and rust free Brilliant! I'll get that on my crew's todo list... that's crew work right? I would love to see a picture of it and know how he made it. I need one! Right now I use a Craftsman Pro 17mm which I drilled a hole in to attach a line. It is working but rusting. I would love to have a clean rust-free tool while out on the water. Dan | | | Re: Stainless Tools
[Re: Dan_Delave]
#235087 07/22/11 02:05 PM 07/22/11 02:05 PM |
Posts: 12,310 South Carolina | Do like Mr Lennard did for us - make a titanium 17mm set wrench, light and rust free Brilliant! I'll get that on my crew's todo list... that's crew work right? I would love to see a picture of it and know how he made it. I need one! Right now I use a Craftsman Pro 17mm which I drilled a hole in to attach a line. It is working but rusting. I would love to have a clean rust-free tool while out on the water. Dan a 2" x 12" titanium plate is something like $80.
Jake Kohl | | |
2,448
guests, and 420
