Nacra 6.0 NA Bridal Foil #235212
07/26/11 05:21 AM
07/26/11 05:21 AM
H
Hullflyer1 Offline OP
H
I had a failure this past weekend that lead to my bridal foil failing. (the clip on the end of the bar broke and the foil bent beyond repair) Was wondering if anyone has a used one in good condition that they would sell. Thanks
Re: Nacra 6.0 NA Bridal Foil [Re: Hullflyer1] #235216
07/26/11 07:29 AM
07/26/11 07:29 AM
V
Ventucky Red Offline
V
Re: Nacra 6.0 NA Bridal Foil [Re: Hullflyer1] #235221
07/26/11 08:55 AM
07/26/11 08:55 AM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
You may want to check with your local dealer...there was a known problem with the attachment points for the rods in the bow foil and there was/is a replacement part for it. To late for your existing foil, but with your replacement foil you may want to check this part so it doesn't happen again...Rick Bliss could help you thru this if your local dealer cannot. Also, check you mast spreader adjustment screws. If the screw adjustment thread goes all the way to the slot, then you should replace them with newer ones and probably orientate them differently. I forget which way at the moment, this applies to N20 spreader screws as well.
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: Nacra 6.0 NA Bridal Foil [Re: Chris9] #235247
07/26/11 04:21 PM
07/26/11 04:21 PM
H
H
Thanks for the advice. I did call Performance and they did not have one, but Jack at Performance called Murrays and they had one in stock. It is on its way $308 including shipping. Maybe, with any luck, depending on UPS, I will be sailing this weekend.
0 registered members (), 382 guests, and 419 spiders.
