| Re: Foils
[Re: sail7seas]
#23534 08/29/03 10:55 AM 08/29/03 10:55 AM |
Posts: 1,307 Asuncion, Paraguay | The last report I received came from the owner of the first prototype, now sailing in Sweden. He told me the following:
QUOTE
...talked to the Catri folks in San Fransisco, they have new topspeed of 30.7 knots and continious runs at 28-29 knots for more than 5 minutes, with no reefing...
UNQUOTE
Luiz
| | | Re: Foils
[Re: DanWard]
#23535 08/29/03 11:20 AM 08/29/03 11:20 AM |
Posts: 1,307 Asuncion, Paraguay | Dan,
Bill tested a planing hull once and as a result he decided not to use this feature in his designs.
In his post he described his test, noted that it was limited and that the idea could be put to work, pending further development and tests. He even offered suggestions on how to develop it. He is not bashing a feature only because it didn't work once.
Compare this to the other designer who tested foils once and now says that he doesn't use them because they didn't work at that time.
This is true, but not the whole truth. He tried only once, had limited experience with foils, probably did not have the resources for further experimenting, was not aware about relevant ressearches on the subject, etc. - all this is ommited.
The difference is that Bill told the truth with great simplicity, without fear of this affecting the sales of his designs, with genuine interest in the development of faster boats.
The other designer simply skiped those details, in my opinion only because it could hurt business.
Bill's posts on theoretical issues tend to be those of a scientist: totally unbiased. The other guy's are those of an educated salesman: correct but partial or biased.
That's why I affirm that Bill's post says a lot about his credibility (no dictionary now).
Cheers,
Luiz
| | | Re: Foils
[Re: BRoberts]
#23536 08/29/03 12:00 PM 08/29/03 12:00 PM |
Posts: 1,307 Asuncion, Paraguay | Bill,
The moto of my previous post was your disposition to discuss and question features and ideas with objetivity, without omissions aimed to leverage sales. In my opinion this means that you are self-confident and honest.
Your sales-oriented posts are usually focused in "new ideas" which are actually your inventions or were already present in your designs 20 years ago. You fundament the claims with scientific objectivity but simple sentences, helping people understand the toys and tricks of our sport.
There are very few people who can claim to have invented and put in practice so many relevant solutions, improvements, inventions and ideas in sailing. Of those, even less are available for open discussion (and questioning!) of their ideas. I admire your work and your atitude.
Cheers,
Luiz
| | | Re: Boat Design: Boat Width, Sail Area vs. Pitch Pole
[Re: BRoberts]
#23539 09/01/03 12:40 PM 09/01/03 12:40 PM |
Joined: Jun 2002 Posts: 806 Toronto, Ontario pitchpoledave
Posts: 806 Toronto, Ontario | I don't know if this has been mentioned before, but these wider boats (10',12', and up) have an important disadvantage. This is the fact that it takes more wind to get them up on one hull. And in most parts of the US/Canada in the summer the wind is quite light. So, a standard width (8.5') boat will walk away on all points of sail, everything else being equal, in light wind, say 12 knots or less.
Bill, can you tell us how much wind was required to get your 20x20' beast flying a hull? | | | Re: Boat Design: Boat Width, Sail Area vs. Pitch Pole
[Re: BRoberts]
#23540 09/01/03 06:02 PM 09/01/03 06:02 PM |
Posts: 545 Brighton, UK | Bill, I think I may have the invention you talk about, I am building a four hulled "catamaran" this has the advantage that if the boat is built longer and wider it does not really increase in weight too much i.e the hull weight is the same in a 16ft version as a 20ft version. Just the gap between the hulls get bigger. My calculations indicate that a 16ft boat has 15% higher for and aft stability (pitching moment) than a conventional cat, because the volume is in the four corners. It is designed to go on a car roof rack, and because of the way it folds it can be made almost any width without any trailer width restrictions. See the link for a drawing of one of my designs. http://www.fourhulls.com/xcatdrawing.pdfI would be interested to hear your thoughts on this design? All the best Gareth www.fourhulls.com | | |
1,113
guests, and 36
