| Sailboat with no traveller #236442 08/18/11 11:25 AM 08/18/11 11:25 AM |
Posts: 7 Hawaii, USA | I recently bought an International 14 monohull (I also have a Prindle 18-2). I haven't sailed it yet, but have had it rigged a couple of times in my front yard. What strikes me most, apart from the mass of lines compared to a cat, is that it doesn't have a traveller. Instead it has a line that fixes the mainsheet at dead center. What do you do to set the main, for example on a reach when I would have let out the traveller and flatten the main with the mainsheet? Thanks
| | | Re: Sailboat with no traveller
[Re: barrylay]
#236443 08/18/11 11:44 AM 08/18/11 11:44 AM |
Posts: 3,906 Clermont, FL, USA |
[Re: Hullflyer1]
#236516 08/19/11 08:45 AM 08/19/11 08:45 AM |
Joined: Jun 2001 Posts: 162 Dunedin Causeway, FL hobiephil
Posts: 162 Dunedin Causeway, FL | Hobie 14s and 16s had vang attachments on the boom, but I have rarely ever seen the used Works great until you gybe without releasing the vang. (Don't ask me how I know) | | | Re: Sailboat with no traveller
[Re: hobiephil]
#236518 08/19/11 09:00 AM 08/19/11 09:00 AM |
Posts: 402 Punta Gorda, FL | Hobie 14s and 16s had vang attachments on the boom, but I have rarely ever seen the used Works great until you gybe without releasing the vang. (Don't ask me how I know) Been there done that! We had a no yelling rule on the boat, it got real quiet after the failed gybe. | | | Re: Sailboat with no traveller
[Re: jkkartz1]
#236524 08/19/11 11:13 AM 08/19/11 11:13 AM |
Posts: 330 | As other's have said, you use the vang to control leech tension on a mono. I had an I-14 for a while that was built in the early/mid '90s - full carbon hull and spars and huge assymetrical spin. Very cool boats, but a lot different from cats. If you have minimal or no dinghy sailing experience, get ready for a steep learning curve and be prepared to get wet a lot. I enjoyed sailing the boat the few times I had it out, but the problem was always finding someone with enough experience to crew on it. The boats are a blast though when you get them dialed in.
You may want to check out the forum at international14.org.
sm
490
guests, and 38
