Sailboat with no traveller #236442
08/18/11 11:25 AM
08/18/11 11:25 AM
Hawaii, USA
barrylay Offline OP
barrylay  Offline OP
Hawaii, USA
I recently bought an International 14 monohull (I also have a Prindle 18-2). I haven't sailed it yet, but have had it rigged a couple of times in my front yard. What strikes me most, apart from the mass of lines compared to a cat, is that it doesn't have a traveller. Instead it has a line that fixes the mainsheet at dead center.
What do you do to set the main, for example on a reach when I would have let out the traveller and flatten the main with the mainsheet?
Thanks
Re: Sailboat with no traveller [Re: barrylay] #236443
08/18/11 11:44 AM
08/18/11 11:44 AM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
You use the boom vang to keep the leach tight as you ease the main.
http://en.wikipedia.org/wiki/Boom_vang
http://www.sailingusa.info/sail_shape.htm
F18 USA 242
http://www.solarwind.solar
Re: Sailboat with no traveller [Re: barrylay] #236479
08/18/11 08:16 PM
08/18/11 08:16 PM
Hawaii, USA
barrylay Offline OP
barrylay  Offline OP
Hawaii, USA
Oh, OK. I guess that's why cats don't have vangs until they become big cats.
Thanks
Re: Sailboat with no traveller [Re: barrylay] #236506
08/19/11 06:26 AM
08/19/11 06:26 AM
H
Hullflyer1 Offline
Hullflyer1  Offline
H
Hobie 14s and 16s had vang attachments on the boom, but I have rarely ever seen the used
Re: Sailboat with no traveller [Re: Hullflyer1] #236516
08/19/11 08:45 AM
08/19/11 08:45 AM
Dunedin Causeway, FL
hobiephil Offline
hobiephil  Offline
Works great until you gybe without releasing the vang. (Don't ask me how I know)
Re: Sailboat with no traveller [Re: hobiephil] #236518
08/19/11 09:00 AM
08/19/11 09:00 AM
Punta Gorda, FL
jkkartz1 Offline
jkkartz1  Offline
Punta Gorda, FL
Been there done that!
We had a no yelling rule on the boat, it got real quiet after the failed gybe.
Re: Sailboat with no traveller [Re: jkkartz1] #236524
08/19/11 11:13 AM
08/19/11 11:13 AM
srm Offline
srm  Offline
As other's have said, you use the vang to control leech tension on a mono. I had an I-14 for a while that was built in the early/mid '90s - full carbon hull and spars and huge assymetrical spin. Very cool boats, but a lot different from cats. If you have minimal or no dinghy sailing experience, get ready for a steep learning curve and be prepared to get wet a lot. I enjoyed sailing the boat the few times I had it out, but the problem was always finding someone with enough experience to crew on it. The boats are a blast though when you get them dialed in.
You may want to check out the forum at international14.org.
sm
0 registered members (), 2,081 guests, and 264 spiders.
