Tornado mast vs F20 mast (compatible?) #237239
09/07/11 03:04 AM
09/07/11 03:04 AM
Sweden, Gothenburg
patrik Offline OP
patrik  Offline OP
Sweden, Gothenburg
Hello,
Would a Tornado mainsail fly without major recutting on a F20 tube (of the correct length) or would differences in stiffness make this a horrible idea?
Kind regards
Patrik Elfving
Re: Tornado mast vs F20 mast (compatible?) [Re: patrik] #237240
09/07/11 03:19 AM
09/07/11 03:19 AM
The dynamic properties would not fit, so shape as the mast bends under gusts would be probably be bad.
Initial setup might also be a problem, depending on location of hounds, spreaders, pre-bend etc.
Doing a re-cut on the main is what I would look at.
Re: Tornado mast vs F20 mast (compatible?) [Re: Rolf_Nilsen] #237241
09/07/11 03:45 AM
09/07/11 03:45 AM
Sweden, Gothenburg
patrik Offline OP
patrik  Offline OP
Sweden, Gothenburg
OK,
thanks,
would a recut likely be able to sort that out?
BR
Patrik
0 registered members (), 521 guests, and 47 spiders.
