| Re: Hate the steering on the Hobie Tiger - What's wrong?
[Re: I20sailor]
#237495 09/13/11 11:39 AM 09/13/11 11:39 AM |
Posts: 3,906 Clermont, FL, USA | Sounds like the rudders are raked too far forward. If you rake the rudders aft a bit your lee helm should go away. Lee helm sucks, but neutral helm... after double trapped spin reaching the neutral helm is what I miss the most about the 20.
[Re: David Ingram]
#237546 09/14/11 12:04 AM 09/14/11 12:04 AM |
Posts: 172 Anacortes | I've had the same problem with my Tiger. Shim the rudders back a little, I used a piece of stick on velcro between the rudder and the cassette and that was enough to make a big difference. Prior to that I raked them back to the extreme and while it felt great in light air, in any breeze at all the boat was uncontrollable. That was a lesson!
Anacortes Rigging.com Rigging and Yacht Services
[Re: I20sailor]
#238328 09/26/11 10:04 AM 09/26/11 10:04 AM |
Posts: 120 | Just go look at the top ten results from the NAs. 3 Infusion MKIIs, 7 C2s....
[Re: iMax]
#238521 10/03/11 09:04 AM 10/03/11 09:04 AM |
Posts: 932 Solomon's Island, MD | Mmm, crappy Hobie steering, alright, time to save up the dough for an Infusion or Capricorn.
Scorpion F18
[Re: maritimesailor]
#238525 10/03/11 09:25 AM 10/03/11 09:25 AM |
Posts: 3,293 Long Beach, California | Just go look at the top ten results from the NAs. 3 Infusion MKIIs, 7 C2s.... The Glasers sail the only Mk1.5 in existence - it isn't a Mk2.
[Re: samc99us]
#238532 10/03/11 11:10 AM 10/03/11 11:10 AM |
Posts: 3,906 Clermont, FL, USA | The Glaser's have an Infusion (not a Mk II) and WildCat boards. They plan to replace the WildCat boards with the Mark II boards and yes they have Glaser sails.
[Re: David Ingram]
#238555 10/03/11 05:28 PM 10/03/11 05:28 PM |
Posts: 3,293 Long Beach, California | On top of that, they have different spreaders and there were some "Pete the Schmeet" specials (in addition to the custom color). This boat was built for Pete Melvin. It isn't an out-of-the-box MkI and it predates the MkII... so the SoCal folks called it the 1.5.
[Re: Gav F18]
#238577 10/04/11 09:18 AM 10/04/11 09:18 AM |
Posts: 3,293 Long Beach, California | Hi Gav -
Regarding getting back on the boat; I first discovered that issue on a 2006 Capricorn. The trick is for the smaller of the two crew to ride the front beam down, either stepping or flipping around it to be on the tramp as the boat rights. It is pretty easy with some practice - while the heavier crew member keeps leaning back on the righting line and after the boat passes the tipping point, the smaller crew member can use the dolphin striker as a good handle to get back on the tramp before splashdown. For the crew member still in the water - don't waste time and energy trying to overcome the distance from the forward section of the trampoline unless the person is quite tall and fit. Go to the back of the boat. Quite easy and fast to get back aboard from there while the crew already on the tramp is keeping the boat parked and sorting out spaghetti.
Cheers -
j
[Re: John Williams]
#239535 10/31/11 10:12 AM 10/31/11 10:12 AM |
Posts: 297 | Hi Gav -
... smaller of the two crew to ride the front beam down, either stepping or flipping around it to be on the tramp as the boat rights.
...For the crew member still in the water - don't waste time and energy trying to overcome the distance from the forward section of the trampoline unless the person is quite tall and fit.
Cheers -
j That's the way to do it. I'd add that if the boat is moving forward, it's damn near impossible to pull yourself up on an infusion or cap from the front beam, whereas its actually not hard to do it from the back beam, even when it is moving. Getting on from the back also allows some improvised water based steering. As the boats usually have nearly neutral helm (i.e. they have been known to sail away quite a distance on their own...) one good idea is adding safety line under the tramp from the front beam to the back to hang onto when going to the back of the boat.
Nacra F18 #856
[Re: I20sailor]
#239735 11/03/11 11:19 PM 11/03/11 11:19 PM |
Posts: 3,293 Long Beach, California | Did it. I had a 2006 Goodall main with a Tina-shaped hole in it. My fault for flipping us. As with your experience, the only upside was the new window.
2,830
guests, and 456
