| Re: What are your expectations?
[Re: Rolf_Nilsen]
#238239 09/23/11 10:59 AM 09/23/11 10:59 AM |
Posts: 5,525 | +1 But I sail mine accordingly. I've never seen the point of pitchpoling just to show you have a pair.
Pete Pollard Blade 702
[Re: bobcat]
#238241 09/23/11 11:05 AM 09/23/11 11:05 AM |
Posts: 9,582 North-West Europe | At least 10 year, but more with same attenion to maintenance.
I don't think it has much to do with the overall weight of the boat and more with the skill level and quality control of the guy and company actually building the boat at a given weight.
I've seen rather new 182 kg F18's split on the hull during normal sailing and i've seen 102 kg taipan 4,9's survive many years of hard use.
I think your problem has alot more to do with the batch your boat came from then the specs of the F16 boats in general. Mine F16 is the same weight as yours and doesn't have a single problem since 2004 when it first sailed. And things do get rough overhere on the north sea.
[Re: Rolf_Nilsen]
#238244 09/23/11 11:16 AM 09/23/11 11:16 AM |
Posts: 5,525 | Finding the limits of performance demands a few rather abrupt stops you know  But boats should be handle pitchpoles and capsizes without major trauma. Bowsprit, snuffers, sails and other accessories might be damaged, but the platform itself should handle this in my opinion. I'm satisfied with my downwind and can only recall one pitch pole from driving too hard. Sailing to weather is a whole different story...
[Re: Rolf_Nilsen]
#238247 09/23/11 11:54 AM 09/23/11 11:54 AM |
Joined: Dec 2005 Posts: 443 Edmonton, Alberta, Canada bobcat OP
Posts: 443 Edmonton, Alberta, Canada | The question as I understand it is not how long the boat is top competitive but how long you can sail it if usage is "normal". I totally expect this to be 20+ years. Exactly. Sure the Laser guys buy a new sail every regatta, a new mast a couple times a year, and a new boat every season, but none of the "old" stuff goes into the trash. I am fairly isolated here. I was not aware that knees, elbows, ankle bones, etc could dimple a boat. A bit of any eye opener. I had a dimple on my boat before it ever got on the water. There were no other boats around me that were this tender. So I was wondering if I was being introduced to another fact of life. | | | Re: What are your expectations?
[Re: bobcat]
#238262 09/23/11 01:52 PM 09/23/11 01:52 PM | MarkMT
| MarkMT
Unregistered | I was not aware that knees, elbows, ankle bones, etc could dimple a boat. A bit of any eye opener. I had a dimple on my boat before it ever got on the water. There were no other boats around me that were this tender. So I was wondering if I was being introduced to another fact of life. Pretty common I think across classes and builders. I've heard similar complaints about some F18s. Obviously lighter boats present greater challenges. Another reason to treat boats with care. | | | Re: What are your expectations?
[Re: Smiths_Cat]
#238264 09/23/11 02:58 PM 09/23/11 02:58 PM |
Posts: 443 Edmonton, Alberta, Canada | My boat is even 10kg below F16 min weight and I will rather dimple my knee than my boat. That is the Bimare Javelin? If you really think that from the other Laser "stuff" nothing goes to the trash, than you live in a parallel world... Perhaps you misunderstood. I was trying to separate out the difference between top level competitiveness and ready for the bin. I doubt that Olympic level Laser sailors throw out their hulls regularly due to slightly worn mast steps. They sell them down the fleet. | | | Re: What are your expectations?
[Re: bobcat]
#238271 09/23/11 05:57 PM 09/23/11 05:57 PM |
Joined: Jun 2006 Posts: 98 Santa Fe, New Mexico, USA WillLints
Posts: 98 Santa Fe, New Mexico, USA | "I was not aware that knees, elbows, ankle bones, etc could dimple a boat."
BobCat, are your hulls kevlar skinned? I think Kevlar gives way easier but is not as likely to fracture as glass.
Will_Lints one-up, Blade 706, epoxy bottoms
[Re: bobcat]
#238293 09/24/11 02:25 PM 09/24/11 02:25 PM |
Posts: 98 Santa Fe, New Mexico, USA | I wonder if you could have wound up with the up-grade even though you didn’t pay for it? Maybe, because they were so behind on shipping their orders they decided to send you the Kevlars just to keep you happy?
[Re: Rolf_Nilsen]
#238539 10/03/11 12:32 PM 10/03/11 12:32 PM |
Posts: 5,590 Naples, FL | The question as I understand it is not how long the boat is top competitive but how long you can sail it if usage is "normal". Interesting comment, Rolf. What, in your opinion, would make a well-built boat lose it's competitive stature - assuming no major changes in design within that product line? Let's propose a hypothetical situation: Two identical F-16 boats, one 10 years old and one new. Both with new sails and rigging. What would make the older one less competitive?
[Re: waterbug_wpb]
#238549 10/03/11 02:22 PM 10/03/11 02:22 PM |
Posts: 1,382 Essex, UK | I'm sure Rolf will answer with his views - and they're always worth listening to - but I'd like to suggest a few....
The older boat can be expected to be less rigid (stiff), have some scuffs and scrapes, possibly be less watertight, have wear in the plate cases and rudder fittings etc.
All of these factors will impact on boatspeed - energy is 'lost' and not transferred into driving the boat forward efficiently. Of course ALL of these can also be addressed and the boat returned to 'good as new' condition and be on a par with, or better than, the newer boat.
Finally, the older boat may, if it has suffered from leaks or damage and repair, be heavier than the newer boat - assuming both were built to the same weight. This disadvantage cannot be readily dealt with and is something that any buyer of a used boat should be aware of when seeking out new (to them) ride.
John Alani ___________ Stealth F16s GBR527 and GBR538 | | | Re: What are your expectations?
[Re: waterbug_wpb]
#238551 10/03/11 04:27 PM 10/03/11 04:27 PM |
Posts: 4,451 West coast of Norway |
The sailor! Changes in hullform/rig Construction methods Seriously though, while listening to the wind, rain and enjoying that our current +5degC temperature stays outdoors.. A well built boat will be competitive at 10 years of age. A boat not designed for a 10+ year competitive life will be more flexible loosing speed. Pretty much all structures will flex and over time loose stiffness. If the flex becomes pronounced, you can even experience material fatigue and material failure. Repairs will over time add weight and more flexibility. Humidity goes into the sandwich, adding weight. Store outdoors in wet weather, add weight. Mount beams improperly and add flex. Basically it can be summed up with increased flex, increased weight and design changes in hullform/rig/appendages/fittings/lines etc. But the most important performance factor on all boats is the sailor anyway.. | | |
1 registered members (vasil),
453
guests, and 46
