| Re: long board experience C2
[Re: iMax]
#238376 09/27/11 01:59 PM 09/27/11 01:59 PM |
Posts: 120 | After 4 days in Hyannis, all I can say is the board didn't slow us down, and we felt that they had advantages to pointing upwind in lighter air, and made it easier to fly a hull downwind. Again, speculation due to only a short amount of time with them, and a lot of it spent in lumpy and/or breezy conditions.
As for holding them up, you guys should have asked around at Hyannis, we solved this issue (mostly because the boards are heavier then the shorter ones) via a bit of non skid tape just above where the strap is connected and/or (we did both) the addition of "fuzzy side of velcro" added to the carpet in the middle of the trunk on the inboard side. I'm sure other remedies will be found as well.
Only real issue we found is you have to make sure the trailing back bottom edge of your dagger board trunk is "clean". Take a small square file and make sure that that no gelcoat / gunk is down there. It should look like a nice square space with no imperfections. We had a bit of gelcoat in there and it started to chip the trailing edge (very very minor).
Look forward to hearing other people's experience with them, but we were pleasantly surprised that we didn't need to pull them up as much as we thought we would have to, and that they felt like they made driving upwind a bit easier to get into "pinch mode" when needed in the light stuff.
My 4 cents, Can 12 | | | Re: long board experience C2
[Re: maritimesailor]
#238405 09/28/11 04:04 PM 09/28/11 04:04 PM |
Posts: 129 Austin, TX | Only real issue we found is you have to make sure the trailing back bottom edge of your dagger board trunk is "clean". Take a small square file and make sure that that no gelcoat / gunk is down there. It should look like a nice square space with no imperfections. We had a bit of gelcoat in there and it started to chip the trailing edge (very very minor).
Chris, Thanks for the tip on the dagger board wells. I've been chipping my short boards for a long time and never had the presence of mind to check that.... Cheers!
Bo Kersey Corsair 31-1D 276 | | | Re: long board experience C2
[Re: BoK]
#238431 09/29/11 01:16 PM 09/29/11 01:16 PM |
Posts: 246 Kiel, Germany | For the time being, the C2 is factory-supplied with short boards, correct? Where do you get the longer boards from, are they available from AHPC?
F18: C2 / A-Cat: Minelli
#238763 10/07/11 11:10 AM 10/07/11 11:10 AM |
Posts: 172 Anacortes | What is the length of the longer boards?
Anacortes Rigging.com Rigging and Yacht Services
[Re: CatSailingHu]
#242277 01/11/12 08:53 AM 01/11/12 08:53 AM |
Posts: 606 Maryland | Should: Total Board Length - Trunk Length = Projection Below Hull Amount? Is it the equation, data, or arithmetic that is off? In a addition to the price increase, the longer boards create a potential hazard by the back side of the raised boards which is more common/prominent with a longer dagger. BTW, former C2 boards are finding their way onto Vipers.
Kris Hathaway | | | Re: long board experience C2
[Re: Kris Hathaway]
#242289 01/11/12 12:47 PM 01/11/12 12:47 PM |
Posts: 5,590 Naples, FL | In a addition to the price increase, the longer boards create a potential hazard by the back side of the raised boards which is more common/prominent with a longer dagger.
BTW, former C2 boards are finding their way onto Vipers. Are the trailing edges of the boards rounded on that portion that (when fully down) would be sitting in the daggarboard case? That might help reduce lacerations when boards are partially raised... might increase the strength a bit, too, although I would suspect the highest load point would be that first mm or two past the bottom of the daggarboard well.
2,523
guests, and 702
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online7,715 2 hours ago | | |
