| polar graph #238953 10/12/11 02:51 PM 10/12/11 02:51 PM |
Posts: 5,525 | Does one exist for the F16?
Pete Pollard Blade 702
| | | Re: polar graph
[Re: Rolf_Nilsen]
#238956 10/12/11 02:57 PM 10/12/11 02:57 PM |
Posts: 5,525 | What does it take to make one?
| | | Re: polar graph
[Re: Rolf_Nilsen]
#238958 10/12/11 03:04 PM 10/12/11 03:04 PM |
Posts: 5,525 | Well, that ain't happenin'! Plan b: what does it take to get one from a sail maker?
| | | Re: polar graph
[Re: Rolf_Nilsen]
#238968 10/12/11 06:06 PM 10/12/11 06:06 PM |
Posts: 5,525 | Why North? Wouldn't one of the lofts making F16 sails be better?
| | | Re: polar graph
[Re: Rolf_Nilsen]
#238985 10/13/11 07:25 AM 10/13/11 07:25 AM |
Posts: 5,525 | Well, you're looking for a quality activity why not cobble one together?
What would a polar graph for the F16 look like? I'm guessing concensus from the group would provide a reasonably accurate graph.
| | | Re: polar graph
[Re: Tony_F18]
#238988 10/13/11 08:51 AM 10/13/11 08:51 AM |
Posts: 5,525 | I was thinking to put some points on a graph generator, purely out of conjecture, then talk it to death until we believe it is accurate.
With all the small, cheap gps units out there we should be able to get a huge amount of data.
| | | Re: polar graph
[Re: pgp]
#238990 10/13/11 09:42 AM 10/13/11 09:42 AM |
Posts: 5,590 Naples, FL | I think you need accurate TWD and TWS as well as cog and speed (to account for any current, right?).
Wire up your boat Pete and sail a lot. Post your data and someone can crunch the numbers...
| | | Re: polar graph
[Re: waterbug_wpb]
#238994 10/13/11 09:51 AM 10/13/11 09:51 AM |
Posts: 5,525 | Nope. On second thought, the graph generator isn't even necessary.
We just need someone to plot the points and keep the chart. If people would submit their gps tracks or individual data points, in time we'd have a very accurate graph. The bs data would fall far outside the norm leaving the rest as valid.
| | | Re: polar graph
[Re: Rolf_Nilsen]
#238996 10/13/11 10:00 AM 10/13/11 10:00 AM |
Posts: 5,525 | Processing the numbers is not hard. Getting accurate data is. To obtain accuracy can you not simply plot the raw data from a variety of sources and deduce best possible vmg? Example: plot the course of two boats to weather. The higher boat is likely to be going slower but not necessarily making the best vmg. The data can be obtained on different days on opposite points of the globe. With enough data points an accurate picture will emerge. http://forums.sailinganarchy.com/index.php?showtopic=127515&st=0#top
| | | Re: polar graph
[Re: Rolf_Nilsen]
#239001 10/13/11 10:28 AM 10/13/11 10:28 AM |
Posts: 5,525 | If two boats are going to weather and one is pinching waaay too high and another is footed off to a reach it is still possible to plot their data, yes?
Though neither represents the optimal course, the best vmg will lie between the two, correct?
If so, it is then only necessary to have the two alter course gradually towards each other. One or the other must then sail the optimal course if only by accident.
Plotting large numbers of isolated data will eventually demonstrate the optimal course.
| | | Re: polar graph
[Re: Rolf_Nilsen]
#239010 10/13/11 02:39 PM 10/13/11 02:39 PM |
Posts: 5,525 | Maybe polar is the wrong term for what I'm interested in. I'd just like to see what people of all skill levels are doing in the real world. It would be nice if everyone carried a Spot during regattas.
13,879
guests, and 670
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online16,046 5 hours ago | | |
