| Re: Basic sailing techniques
[Re: pgp]
#240021 11/12/11 10:26 AM 11/12/11 10:26 AM |
Posts: 5,525 | I guess I can try increasing my main sheet to 8:1. Now, when I try to sheet hard my butt comes unattached to the deck and I slide all over.
Rick, I think I've been trying to find one magic slot to weather whick doesn't work. Finer adjustments seem to be in order.
Pete Pollard Blade 702
[Re: pgp]
#240032 11/12/11 01:16 PM 11/12/11 01:16 PM |
Posts: 571 Hamburg | I guess I can try increasing my main sheet to 8:1. Now, when I try to sheet hard my butt comes unattached to the deck and I slide all over.
Are you saying that you don't trap upwind but the sheet loads are strong enough to pull you in? Sounds like you either oversheet or you should go in the trapez... or you are significantly heavier than me  . Cheers, Klaus | | | Re: Basic sailing techniques
[Re: pgp]
#240034 11/12/11 01:23 PM 11/12/11 01:23 PM |
Posts: 5,525 | I'm a lot heavier than you! 105 kg.
I think that if I pinched less I'd be able to trap more.
[Re: davefarmer]
#240037 11/12/11 05:48 PM 11/12/11 05:48 PM |
Posts: 217 Palm Harbor, FL | I usually sail with one foot under the hiking strap, and with the other I catch the strap with my heel so I have something to push against when sheeting, or the hull rises. I sail a Wave and I do something similar. My forward food is under the hiking strap, but I keep my aft foot out and work the mainsheet cam cleat with my toes. If I have to hike hard, I will hook my aft foot under the aft beam. When one of the more experienced guys saw how I was working the cleat, at first he started laughing, but after thinking about it, he said he was going to try it next time.
Daniel T. Taipan F16 - USA 213 | | | Re: Basic sailing techniques
[Re: pgp]
#240038 11/12/11 06:00 PM 11/12/11 06:00 PM |
Posts: 4,119 Northfield Mn | On a Wave I'd set the cleat angle so you can't cleat it.
[Re: Karl_Brogger]
#240042 11/12/11 11:25 PM 11/12/11 11:25 PM |
Posts: 217 Palm Harbor, FL | On a Wave I'd set the cleat angle so you can't cleat it. I'm too wimpy for that I guess. It only has a 4:1 purchase with no ratchet and I'm using a fat headed sail.
[Re: pgp]
#240045 11/13/11 06:32 AM 11/13/11 06:32 AM |
Posts: 4,119 Northfield Mn | Ah, yeah...... ratchet would be key.
[Re: Karl_Brogger]
#240050 11/13/11 09:42 AM 11/13/11 09:42 AM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | On the Wave I use a small Harken Fiddle Ratchet with a becket. In light air, switch it off, and in heavy use the ratchet. Also use 1/4" Salsa (great sheet line, no core, non stretch, won't kink, runs throught the blocks with ease). Can't imagine not cleating the Wave -- Ouch!
Pete, You could go 8:1 and use smaller sheet, i.e., Salsa, as it will still go through the blocks easily. That way the sheet will feed out when eased. Also, you might think about the Ratchamatic. Wish I could get one for the Wave, but they don't make one that will work on the boat.
[Re: pgp]
#240064 11/13/11 09:36 PM 11/13/11 09:36 PM |
Posts: 12,310 South Carolina | I'm a lot heavier than you! 105 kg.
I think that if I pinched less I'd be able to trap more. Also err on the side of trapping when you shouldn't. Ive seen the euros trap much earlier and the thought is that keeping the boat flat and the mast perpendicular is more of a performance advantage that desperately trying to get a hull flying. I've been taking that approach and it hasn't hurt me yet...and I usually sail heavy.
Jake Kohl | | | Re: Basic sailing techniques
[Re: Karl_Brogger]
#240079 11/14/11 10:08 AM 11/14/11 10:08 AM |
Posts: 5,590 Naples, FL | In conditions with constant wind direction and speed? Yeah.
Like you said, very little on the boat is "static" even in relatively consistent conditions. I'd opt for sail adjustments before rudder changes, but indeed some rudder will usually be necessary
#240086 11/14/11 02:13 PM 11/14/11 02:13 PM |
Posts: 6,049 Sebring, Florida. | I'm a lot heavier than you! 105 kg.
I think that if I pinched less I'd be able to trap more. Also err on the side of trapping when you shouldn't. Ive seen the euros trap much earlier and the thought is that keeping the boat flat and the mast perpendicular is more of a performance advantage that desperately trying to get a hull flying. I've been taking that approach and it hasn't hurt me yet...and I usually sail heavy. You bring up a good point here Jake, and something I had forgotten all about since making the switch from mono-dinghy racing to cats. In somehting like a Laser or 470, the experts will tell you to keep the boat as flat as possible going upwind, as you said, to keep the mast straight up and the blades straight down, giving you maximum lift from both sails and blades. We don't talk too much about that in Cats, because we all love to trap, of course, and as soon as you can get one hull up out of the water you have cut your drag in half, but when the wind is "Medium" and you have to decide to trap or not, is it better to keep the boat flatter and get all you can out of the blades/sails, or better to keep your weight inboard, try to fly that hull and reduce the drag? There has to be a "Changeover Point" somewhere in there, where it pays to stay flat, or pays more to get the hull up...finding that point is why I hate racing in light air! When it's blowing, you don't have to worry about "IF" you should trap or not, you have to, period. But when it gets light...well...? My biggest problem may, or may not be, indecision. ;^)
Blade F16 #777
[Re: mikekrantz]
#240097 11/14/11 03:48 PM 11/14/11 03:48 PM |
Posts: 571 Hamburg | On the A-cat, it's faster to go on the wire first and hold it down for acceleration in the puffs versus sitting in, flying the hull, and pinching up. Not talking about puffs, it is faster to keep one hull out of the water but still keep it flat, just kiss the top of the waves. On all cats I sailed so far I could feel the slow down if the hull flies high upwind. In light winds it helps to make the trap short and crouch. Ones the boat picks speed and want to fly the hull, you can stretch and translate the power in even more speed instead of heal. | | |
2,571
guests, and 422
