Nacra 5.5 or P18.2 #240377
11/22/11 01:39 PM
11/22/11 01:39 PM
Santiago, Chile
Andinista Offline OP
Santiago, Chile
Hi, please help me decide among those two cats. I'm a recreational sailor, 180 lb, plus 110 lbs crew, sometimes more, sometimes just me. I have sailed N5.0 a lot and I'm not afraid of single handing a bigger boat. I'm not really too mucho into a very technical boat so I suspect the N5.5 is a nice option. But the centerboards v/s daggerboards I think compensate that that. Bottom line is which one is more fun, that's what I care actually....
Re: Nacra 5.5 or P18.2 [Re: Andinista] #240497
11/26/11 10:04 AM
11/26/11 10:04 AM
42.904444 N; 88.008586 W
Todd_Sails Offline
Todd_Sails  Offline
I sailed both, and I'm biased towards the the P18-2
F-18 Infusion
#626- SOLD it!
Re: Nacra 5.5 or P18.2 [Re: Andinista] #240501
11/26/11 01:22 PM
11/26/11 01:22 PM
catandahalf Offline
catandahalf  Offline
I must confess that, arguably, the NACRA 5.5 SL featured the finest hull design and sail plan available on the USA market in the mid - nineties.
Not only was the boat very well balanced, but the power to weight ratio was in accordance with the NACRA 5.2 so the boat could be really driven when the pressure was up in an angry sea state.
There are stories that tell of 5.5s beating 6.0s boat for boat along the Gulf Coast, but that's just bartalk smile
Re: Nacra 5.5 or P18.2 [Re: Andinista] #240740
12/02/11 06:28 AM
12/02/11 06:28 AM
Santiago, Chile
Santiago, Chile
Thanks for the replies. I was a bit more interested in the P18-2 initially, but the Nacra had been well loved and was in better shape. And I liked how it sailed, so tomorrow it'll be mine!
It will soon become part of the Star Fleet:
Re: Nacra 5.5 or P18.2 [Re: Andinista] #241816
12/23/11 11:04 AM
12/23/11 11:04 AM
Santiago, Chile
Santiago, Chile
The first report from Houston: Launch successful!
http://www.youtube.com/watch?v=nEam...KMwI2puSeyw&index=1&feature=plcp
Re: Nacra 5.5 or P18.2 [Re: Andinista] #241818
12/23/11 12:13 PM
12/23/11 12:13 PM
catandahalf Offline
catandahalf  Offline
Andinista,
May I offer a couple hints?
1. Tighten the rig - Use the mainsheet by traveling down to the end of the traveler track, sheeting hard to loosen the shroud then repin. Make sure the shrouds are in equal holes and the rig is in column. Tight is faster.
2. On all three mains I used, the traveler car on the mainsail wanted to be kept forward upwind for a tighter foot and better overall sail shape - avoid over rotating with a loose rig.. Be like a windsurfer and downhaul, downhaul, downhaul the mainsail & keep that jib luff tight especially in Force Five. Check the rake of your diamonds and the tension - go for aligned prebend. In - column is faster on both tacks and balances the helm.
That reminds me - ensure the main beam has prebend built in via the dolphin striker. Tighten the nut for the rod under the main beam until a slight prebend is present. This allows for more rig tension and saves the main beam.
... also, we found our mast would rotate better if we placed a thin plastic 'bearing' in the mast base to resist friction...
I wish I still had my boat now smile
Re: Nacra 5.5 or P18.2 [Re: catandahalf] #241820
12/23/11 01:35 PM
12/23/11 01:35 PM
Santiago, Chile
Santiago, Chile
Hey, thanks! Feedback and advice is exactly what I need.
Where did you note lack of rig tension? (or where do you think it hurts the most?) I was surprised to see the forestay curved upwind, I thouhgt the wind itself would keep it straight even if rig tension was a bit loose (per my previous experience), but apparently this jib is big enough to do that. (I am assuming that the jib halyard tension is not intended to take that much tension and help keeping forestay straight). The jib halyard system is currently 1:1, I will modify for more purchase, not sure yet if I'll rig the halyard throuhg the stay or through the mast, I'll try the ideas I have on my mind and see.
I didn't play too much with the traveler car on the mainsheet and not a lot with the downhaul, but I had in my mind that too forward and too tight, respectively, meant 100% de-powering. I hear your advice and will be testing.
Please explain what you mean by "In - column is faster .."
Please more details of the mast plastic bearing. I saw some plastic circles on ebay but never figure out if they were for what you are suggesting of for a diffent mast step.
Thanks again!
Andrés
Re: Nacra 5.5 or P18.2 [Re: Andinista] #241823
12/23/11 03:47 PM
12/23/11 03:47 PM
catandahalf Offline
catandahalf  Offline
Aloha Andres,
Headstay sag on the 5.5 or other high performance cats is NOT good. The Hobie 16 has a wire in the luff of the jib which becomes the 'new' headstay. Do not try and tension the rig with the 5.5 jib - tighten the shrouds to maximize tension under load. The sailcloth ain't gonna tighten the rig. I noticed that when your crew was white knuckling the weather shroud there was too much play (despite the fish eye effect).
Now let's begin at the front of the boat. The bridle foil is designed to maximize rig tension without pinching the bows in and losing hull/foil alignment. Since there is no way to raise and lower the mast with the required tension for sailing we used to always leave one side loose for stepping. Once the main was up we pulled the traveler car over and sheeted the main to re - set the 'loose' shroud. Before we dropped the main, we would loosen one side in the same fashion as stepping it (reverse order). Make sure the Enterprise is pointed into the wind. Bottom Line - a loose rig and under - trimmed main can result in sudden mast failure due to snapping inertia, and less importantly the helm falls out of balance - oops, crash and burn.
The spreaders should be raked in harmony with the sail cut and diamond tension adequate to keep the mast straight (in column). Bend is bad unless it is fore and aft.
NACRA used to produce thin delrin chips, but I do not believe that is the case nowdays. When we were in a pinch we would sacrifice the soft plastic lid of a food container and cut it to fit. This protected the mast ball from wear and tear as well since we raced with a super tight rig. I have seen NACRA 5.2s come in after a day of sailing with a lose rig at the end of the day. After lowering the mast the owners were discovering their mast balls splintered. Be aware of flat - topped mast balls. Delrin is much kinder to mast bases than stainless.
The tighter rig will balance the helm, improve sail shape, and improve the gps numbers smile
Go Sailing, and if you would like some coaching buy me a plane ticket and put me up for a few days smile Maybe we could get you ready for a shiny new Farrier 22 (one of those "Klingon" tri hulls).
Bert Rice
NACRA 5.5 Discovery (I miss it)
Corsair 24 Mark Twain
J 29 Rush
Viper F 16 Snake Bite
Re: Nacra 5.5 or P18.2 [Re: catandahalf] #241827
12/23/11 07:16 PM
12/23/11 07:16 PM
Santiago, Chile
Santiago, Chile
Cool, thanks! Let me know if you are a just a bit closer and I'll buy that ticket.. (unless I figure out how to make just a bit more money and I buy it before...). The warp speed system will be repaired by then for sure, anyway.. Live long and prosper!
Andrés Chianale
Re: Nacra 5.5 or P18.2 [Re: Andinista] #241837
12/24/11 11:19 AM
12/24/11 11:19 AM
On the Water
P.M. Offline
P.M.  Offline
On the Water
Are you missing a second daggerboard?
Philip
USA #1006
Re: Nacra 5.5 or P18.2 [Re: Andinista] #241839
12/24/11 04:53 PM
12/24/11 04:53 PM
Santiago, Chile
Santiago, Chile
Yes, i'm making a new one.
Re: Nacra 5.5 or P18.2 [Re: Andinista] #241841
12/24/11 05:03 PM
12/24/11 05:03 PM
Santiago, Chile
Santiago, Chile
The 4 way jib system is missing too, I made a simpler one that seems enough:
A line from side to side, instead of the wire, and short loops to attach the blocks, on each side, tied to the line with prussik knots. Slide easy and stays there. Much simpler and good enough so far. [Linked Image]
Re: Nacra 5.5 or P18.2 [Re: Andinista] #241847
12/24/11 11:05 PM
12/24/11 11:05 PM
Todd_Sails Offline
Todd_Sails  Offline
Was that at Tommy Grangers house on clear Lake- Houston?
F-18 Infusion
#626- SOLD it!
Re: Nacra 5.5 or P18.2 [Re: Andinista] #241849
12/25/11 06:27 AM
12/25/11 06:27 AM
Santiago, Chile
Santiago, Chile
Lake Rapel in Chile
Re: Nacra 5.5 or P18.2 [Re: Andinista] #241850
12/25/11 06:27 AM
12/25/11 06:27 AM
Santiago, Chile
Santiago, Chile
(I meant Houston Space Center...)
1 registered members (FredL), 446 guests, and 68 spiders.
