| Re: Epoxy pigment
[Re: bvining]
#240607 11/30/11 08:37 AM 11/30/11 08:37 AM |
Posts: 1,152 tampa, fl | I have used the gel coat repair kits that are available at West Marine with success for small chips. It comes in white that matches the gel coat on my infusion very well.
If your havin girl problems i feel bad for you son I got 99 problems but my beautiful wife ain't one | | | Re: Epoxy pigment
[Re: bvining]
#240608 11/30/11 09:00 AM 11/30/11 09:00 AM |
Posts: 12,310 South Carolina | I have a very small chip that I need to fix.
Can I add white paint to epoxy? The West Systems white pigment is expensive for a small repair.
Anyother white pigment ideas? I've used these in the past with success - but in dark colors. I've never tried the white...I would be a little concerned that the epoxy might still yellow after some time in the sun with a white pigment. However, I don't have any specific experience with that. Try here for cost effective resin pigments. http://www.uscomposites.com/pigments.html
Jake Kohl | | | Re: Epoxy pigment
#240650 11/30/11 08:43 PM 11/30/11 08:43 PM |
Posts: 297 | If it is a chip, just use gel coat. Takes some getting used to the process but if you learn how, you are way ahead in repair costs. The down side of epoxy is, as mentioned, it will yellow in sunlight, and it can also be very cranky to cover that repair with polyester gelcoat (the amines in epoxy blush out, causing the gelcoat to not to polymerize evenly, or at all.) That said, with some prep, it can be made to polymerize okay. FYI, It is also not advisable to use epoxy on a polyester-made boat where the repair is perpetually underwater (i.e. a cruiser repair under the waterline), as it will eventually blister. This is not a problem on a beach cat, though. http://www.michiganfiberglass.com/products.html This outfit sells a bright white, high quality gelcoat and pigments that can be blended in to match aging gelcoat. It's a bit of an art but if you do it right, you will have a great match. Their supplies are better than stuff available from 'other retailers' (trust me on this...).
Nacra F18 #856
| | | Re: Epoxy pigment
[Re: bvining]
#240651 11/30/11 08:52 PM 11/30/11 08:52 PM |
Posts: 2,921 Michigan | why hasn't anyone recommended Marine-Tex yet? It is, I guess, rather expensive, but it won't yellow. That's the first thing that came to my mind. Great stuff. easy to sand, easy to mold (use a glove, wet the finger with a little water when the stuff is putty)
| | | Re: Epoxy pigment
[Re: bvining]
#240680 12/01/11 10:04 AM 12/01/11 10:04 AM |
Posts: 3,224 Roanoke Island ,N.C. | What paint? If it's just about anything but awlgrip you repair as normal Fill and paint. Are you just trying to save a step?
Gel coat is definitely NOT the answer. PTP, Marine tex is more of a temporary patch not a permanent repair.
| | | Re: Epoxy pigment
[Re: bvining]
#240697 12/01/11 02:01 PM 12/01/11 02:01 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | Any bondo type putty will work fine. You can use a single sided razor as the spreader for something that small.
I like evercoat glazing putty. It's almost white so it will be hard to see the repair.
If you have gel coat w/wax you can thicken that and use it like bondo. Pretty much all these bondo type putty's are polyester based.
| | | Re: Epoxy pigment
[Re: PTP]
#240698 12/01/11 02:17 PM 12/01/11 02:17 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | It is easy to work with and will last as well as anything, however Gel coat will never cure over it.
Only West System can be Gel coated with no problems. My experience anyway.
Doesn't matter in this case as the boat is painted.
| | | Re: Epoxy pigment
[Re: bvining]
#240716 12/01/11 07:29 PM 12/01/11 07:29 PM |
Posts: 3,224 Roanoke Island ,N.C. | yes, trying to save a step. I wasnt planning on mixing up epoxy with pigment as the chip/ding is less than an 1/8th of an inch. If it's that small, why not just paint? Pool it up or lots of thinner coats and skip the epoxy. I second catmans choice of fillers also. Love the evercoat glazing putty.
| | | Re: Epoxy pigment
[Re: bvining]
#240840 12/05/11 04:18 PM 12/05/11 04:18 PM |
Joined: Feb 2009 Posts: 678 Palm Beach County TheManShed
Posts: 678 Palm Beach County | I spoke to West System you can use unbound pigment. I has a been awhile since I spoke with them if you call their help line they can guide you in the correct pigment to buy. Sounds like you can go to any place that mixes house paint and get the pigment. Hopes that helps.
I ended up just buying their stuff because I needed a larger quantity.
Mike Shappell www.themanshed.comTMS-20 Builder G-Cat 5.7 - Current Boat NACRA 5.2 - early 70's | | | Re: Epoxy pigment
[Re: dave mosley]
#240926 12/07/11 01:47 PM 12/07/11 01:47 PM |
Joined: Jul 2004 Posts: 125 Clinton, Mississippi rattlenhum
Posts: 125 Clinton, Mississippi | I've had good luck with these guys: http://www.fgci.com/I have used their white pigment in epoxy and it worked fine (is marketed as suitable for epoxies, polyester, etc.). Formula 27 is quite grey next to my boat's white gelcoat.
Jerome Vaughan Hobie 16 Clinton, Mississippi
4,249
guests, and 644
