Epoxy pigment #240606
11/30/11 08:33 AM
11/30/11 08:33 AM
Atlanta
bvining Offline OP
bvining  Offline OP
Atlanta
I have a very small chip that I need to fix.
Can I add white paint to epoxy? The West Systems white pigment is expensive for a small repair.
Anyother white pigment ideas?
Re: Epoxy pigment [Re: bvining] #240607
11/30/11 08:37 AM
11/30/11 08:37 AM
tampa, fl
K
ksurfer2 Offline
ksurfer2  Offline
K
tampa, fl
I have used the gel coat repair kits that are available at West Marine with success for small chips. It comes in white that matches the gel coat on my infusion very well.
Re: Epoxy pigment [Re: bvining] #240608
11/30/11 09:00 AM
11/30/11 09:00 AM
I've used these in the past with success - but in dark colors. I've never tried the white...I would be a little concerned that the epoxy might still yellow after some time in the sun with a white pigment. However, I don't have any specific experience with that. Try here for cost effective resin pigments.
http://www.uscomposites.com/pigments.html
Re: Epoxy pigment [Re: Jake] #240650
11/30/11 08:43 PM
11/30/11 08:43 PM
rexdenton Offline
rexdenton  Offline
If it is a chip, just use gel coat. Takes some getting used to the process but if you learn how, you are way ahead in repair costs.
The down side of epoxy is, as mentioned, it will yellow in sunlight, and it can also be very cranky to cover that repair with polyester gelcoat (the amines in epoxy blush out, causing the gelcoat to not to polymerize evenly, or at all.) That said, with some prep, it can be made to polymerize okay.
FYI, It is also not advisable to use epoxy on a polyester-made boat where the repair is perpetually underwater (i.e. a cruiser repair under the waterline), as it will eventually blister. This is not a problem on a beach cat, though.
http://www.michiganfiberglass.com/products.html
This outfit sells a bright white, high quality gelcoat and pigments that can be blended in to match aging gelcoat. It's a bit of an art but if you do it right, you will have a great match. Their supplies are better than stuff available from 'other retailers' (trust me on this...).
Nacra F18 #856
Re: Epoxy pigment [Re: bvining] #240651
11/30/11 08:52 PM
11/30/11 08:52 PM
why hasn't anyone recommended Marine-Tex yet? It is, I guess, rather expensive, but it won't yellow. That's the first thing that came to my mind. Great stuff. easy to sand, easy to mold (use a glove, wet the finger with a little water when the stuff is putty)
Re: Epoxy pigment [Re: PTP] #240676
12/01/11 09:44 AM
12/01/11 09:44 AM
Atlanta
bvining Offline OP
bvining  Offline OP
Atlanta
Thanks for the replies guys, I forgot to mention that this boat is painted. Its carbon/epoxy/paint as an outer skin.
So, I dont think gel coat is the right answer, right?
Also, its two small chips on the bottom of the hull, so they wont see much if any sunlight, and its drysailed.
Re: Epoxy pigment [Re: bvining] #240680
12/01/11 10:04 AM
12/01/11 10:04 AM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
What paint? If it's just about anything but awlgrip you repair as normal Fill and paint. Are you just trying to save a step?
Gel coat is definitely NOT the answer.
PTP, Marine tex is more of a temporary patch not a permanent repair.
Isak Dinesen
E. B. White
Re: Epoxy pigment [Re: Team_Cat_Fever] #240681
12/01/11 10:10 AM
12/01/11 10:10 AM
Atlanta
bvining Offline OP
bvining  Offline OP
Atlanta
yes, trying to save a step. I wasnt planning on mixing up epoxy with pigment as the chip/ding is less than an 1/8th of an inch.
Re: Epoxy pigment [Re: bvining] #240697
12/01/11 02:01 PM
12/01/11 02:01 PM
catman Offline
catman  Offline
Any bondo type putty will work fine. You can use a single sided razor as the spreader for something that small.
I like evercoat glazing putty. It's almost white so it will be hard to see the repair.
If you have gel coat w/wax you can thicken that and use it like bondo. Pretty much all these bondo type putty's are polyester based.
Re: Epoxy pigment [Re: PTP] #240698
12/01/11 02:17 PM
12/01/11 02:17 PM
catman Offline
catman  Offline
It is easy to work with and will last as well as anything, however Gel coat will never cure over it.
Only West System can be Gel coated with no problems. My experience anyway.
Doesn't matter in this case as the boat is painted.
Re: Epoxy pigment [Re: bvining] #240716
12/01/11 07:29 PM
12/01/11 07:29 PM
If it's that small, why not just paint? Pool it up or lots of thinner coats and skip the epoxy.
I second catmans choice of fillers also. Love the evercoat glazing putty.
Isak Dinesen
E. B. White
Re: Epoxy pigment [Re: bvining] #240840
12/05/11 04:18 PM
12/05/11 04:18 PM
Palm Beach County
TheManShed Offline
TheManShed  Offline
Palm Beach County
I spoke to West System you can use unbound pigment. I has a been awhile since I spoke with them if you call their help line they can guide you in the correct pigment to buy. Sounds like you can go to any place that mixes house paint and get the pigment. Hopes that helps.
I ended up just buying their stuff because I needed a larger quantity.
Mike Shappell
www.themanshed.com
TMS-20 Builder
G-Cat 5.7 - Current Boat
NACRA 5.2 - early 70's
Re: Epoxy pigment [Re: bvining] #240924
12/07/11 01:22 PM
12/07/11 01:22 PM
Columbia South Carolina, USA
dave mosley Offline
dave mosley  Offline
Check these guys out for Poly resins and carbon stuff.
http://www.fiberglasssupply.com/Product_Catalog/Polyester_Resins/polyester_resins.html
Also an easy fix to small problems is Formula 27, marine Bondo. dries white and sands easy and is less H2O permeable. dont know about gelcoating over it...sorry!
Re: Epoxy pigment [Re: dave mosley] #240926
12/07/11 01:47 PM
12/07/11 01:47 PM
Clinton, Mississippi
rattlenhum Offline
rattlenhum  Offline
I've had good luck with these guys:
http://www.fgci.com/
I have used their white pigment in epoxy and it worked fine (is marketed as suitable for epoxies, polyester, etc.). Formula 27 is quite grey next to my boat's white gelcoat.
Jerome Vaughan
Hobie 16
Re: Epoxy pigment [Re: bvining] #240929
12/07/11 03:07 PM
12/07/11 03:07 PM
pgp Offline
pgp  Offline
Thanks.
Pete Pollard
Blade 702
0 registered members (), 5,361 guests, and 684 spiders.
Most Online7,274
4 hours ago
