Car to toe the boat around. #24115
09/12/03 12:29 AM
09/12/03 12:29 AM
Australia
Jules_topcat Offline OP
Australia
Ok im after a new car because my ford isn't looking the best at the moment and since im buying a new boat i thougt the car may as well come to. I was wondering can you toe a hobie 16 behind a 4 cylinder with say a turbo in it?? I have heard not to get anything smaller than a V6 but im curious if a 4 turbo will do the trick.
Jules_topcat
Re: Car to toe the boat around. [Re: Jules_topcat] #24116
09/12/03 01:26 AM
09/12/03 01:26 AM
St. Louis, MO
nova Offline
nova  Offline
St. Louis, MO
I use to tow a 16' ski boat with a 75 hp motor. I had no problem with my 4 cyl, manual transmission, front wheel drive car. The trailer had tantem axles so there was no weight on the car. So in my opinion there wouldn't be a problem. Not sure how an automatic would fair.
Be sure you get a car the you WILL be able to put a hitch on. There are some cars that you can't.
Re: Car to toe the boat around. [Re: nova] #24117
09/12/03 08:53 AM
09/12/03 08:53 AM
Roanoke, VA
mattp Offline
mattp  Offline
Roanoke, VA
I think if you live in an area that is relatively flat and take it kind of easy, you should be all right. Beach cats are pretty light. Sometimes I forget that I am pulling one.
(Insert Witty Signature Here) 1988 H16
Re: Car to toe the boat around. [Re: Jules_topcat] #24118
09/12/03 10:42 AM
09/12/03 10:42 AM
Pennsylvania
mrw1 Offline
mrw1  Offline
Pennsylvania
I'm towing my H16 with a VW Jetta Turbo Diesel. 90hp/50mpg without the trailer/40mpg with the Hobie in tow. Can't beat it.
Re: Car to toe the boat around. [Re: mrw1] #24119
09/13/03 09:55 AM
09/13/03 09:55 AM
Australia
Australia
Well i own a 1989 model Ford fairmont and well even with a straight 6 the car strugles up hils when i give it abit but then again the car is abit sick.
Jules_topcat
Re: Car to toe the boat around. [Re: Jules_topcat] #24120
09/13/03 01:16 PM
09/13/03 01:16 PM
Queensland, Australia
Philthy Offline
Philthy  Offline
G'day Julian,
my last 16 got towed to every event in NSW with a little Honda Accord, they were only 1.6L engines back then. You don't really need much to tow though I will say there's possibly some advantage in the small 4wds if you can get beach access. Though Canberra I assume has no real 'beach'.
Cheers Phil
Re: Car to toe the boat around. [Re: Philthy] #24121
10/16/03 03:24 PM
10/16/03 03:24 PM
Houston Texas
prindlesnark Offline
Houston Texas
you can do it, however you also run the risk of burning up your turbo. Depends in the grade of ramp you are pulling the boat and so on. A turbo is not for pulling unless it is a diesel. A turbo is to "rap up" the engine faster, a supercharger is for pulling
Jason Snark the Prindle sailing thunderchicken [email protected]
Re: Car to toe the boat around. [Re: Jules_topcat] #24122
10/17/03 07:10 AM
10/17/03 07:10 AM
ms/fl
fuzzy Offline
fuzzy  Offline
ms/fl
I have pulled Na 6.0, H20s, etc with a 1989 mazda 4 cyl pickup truck with no problem for years. The only 2 things I notice is my gas mileage drops, and I have to drop from 5th to 4th gear goin up hill. Of course, now I drive a Jeep Grand Cherokee (6 cyl)--nicer ride than the mazda...t
A-class #19
Re: Car to toe the boat around. [Re: Jules_topcat] #24123
10/19/03 10:48 AM
10/19/03 10:48 AM
swampy Offline
swampy  Offline
I've towed my H16 with a VW Golf 2.0 and never had a problem, even with the fairly steep ramp I use to put the boat in the water. Highway and hill driving has never presented any kind of problem whatsoever. My advise is don't worry about it. andrew
Re: Car to toe the boat around. [Re: swampy] #24124
10/20/03 11:07 AM
10/20/03 11:07 AM
Australia
Australia
Ok if you can tow a boat with a small V4 how much effect does it have on the petrol and power and speed. I know alot of guys who toe with a v4 but they say they dont drive them very fast because they cant.
Jules_topcat
Re: Car to toe the boat around. [Re: Jules_topcat] #24125
10/27/03 09:13 PM
10/27/03 09:13 PM
Bayonet Point, FL
naishman Offline
naishman  Offline
Bayonet Point, FL
I tow two H14s with a 4 cylinder Volvo-as weak as they come. Used to tow a TheMightyHobie18 with a VW Microbus, circa 1967. Just didn't go that fast
Re: Car to toe the boat around. [Re: naishman] #24126
10/28/03 09:14 PM
10/28/03 09:14 PM
Australia
Australia
Thanks for that every one and i have just bought a VL which is super charged so i wont ever have to worry. Thanks again
Jules_topcat
0 registered members (), 2,582 guests, and 492 spiders.
Yesterday at 10:10 AM
