Dolphin striker #24279
09/16/03 08:34 PM
09/16/03 08:34 PM
yankyfan2000 Offline OP
Is the dolphin striker the part that comes does right underneth the mast from the crossbar and a caable run through it to each side of the frame?
Anthony-----H14
Re: Dolphin striker [Re: yankyfan2000] #24280
09/16/03 08:42 PM
09/16/03 08:42 PM
PSAILOR Offline
PSAILOR  Offline
Yep
Re: Dolphin striker [Re: PSAILOR] #24281
09/17/03 03:08 PM
09/17/03 03:08 PM
oh cool, that means i got one on my boat then, did they come standered on a h14?
Anthony-----H14
Re: Dolphin striker [Re: yankyfan2000] #24282
09/17/03 04:46 PM
09/17/03 04:46 PM
PSAILOR Offline
PSAILOR  Offline
nope
only used with the H14 turbo, or any H14 with trap wires
Re: Dolphin striker [Re: PSAILOR] #24283
09/18/03 04:49 PM
09/18/03 04:49 PM
Miami, Fl
southsail_ricky Offline
Miami, Fl
whats the dolphin striker for? other than k/oing flipper..
Ricky Matos Marine Surveyor, Alpha Marine Miami, FL 305/324/1555
Re: Dolphin striker [Re: southsail_ricky] #24284
10/16/03 03:15 PM
10/16/03 03:15 PM
Houston Texas
prindlesnark Offline
Houston Texas
just a little extra brace, for turbo or trap. think of all the pressure on that one spot
Jason Snark the Prindle sailing thunderchicken [email protected]
Re: Dolphin striker [Re: prindlesnark] #24285
10/17/03 02:24 PM
10/17/03 02:24 PM
Norfolk, VA
Dan Berger Offline
Dan Berger  Offline
Norfolk, VA
The dolphin striker keeps the front frame from collapsing when under load. You really need one if you plan on hiking out on your 14. With all the added load on the mast step, it makes the front frame bow down and could break it. Also, the dolphin striker keeps the hulls from spreading apart as the frame bows. Don't over-tighten the striker--to adjust it, make it snug while the mast is down. That should keep your hulls in line so they won't get out of whack when you put the mast up.
Dan Berger
Norfolk, VA
A Cat USA139
Supercat 15
