| Re: sail shape help
[Re: Headhunter]
#242988 01/25/12 11:30 AM 01/25/12 11:30 AM |
Joined: Jun 2005 Posts: 302 Daytona Beach Florida orphan
Posts: 302 Daytona Beach Florida | I would try taking some of the prebend out of the mast before I would touch the battens. Do it with the spreader adjustments. The diamonds should be very tight. Like violin tight. Check with Mike. He should have some sugestions.
| | | Re: sail shape help
[Re: Headhunter]
#243003 01/25/12 01:29 PM 01/25/12 01:29 PM |
Posts: 12,310 South Carolina | If your mast is at 90 degrees upwind, that could be taking a lot of shape out of the main. Try rotating the mast back so the limiter (or luff track) points somewhere between the daggerboard trunk and the rear beam...this is a more typical upwind setting and may give you some more shape.
Working/shaving your battens worked well on stretchy dacron sails - but isn't going to make a significant difference on pentex/mylar sails. The difference between the two shapes you have has more to do with how much curve was shaped into the luff of the sail...also remember that flatter doesn't necessarily mean slower. Sail shapes have evolved a little flatter over the last several years so it may just require some different tuning.
Jake Kohl | | | Re: sail shape help
#243010 01/25/12 01:55 PM 01/25/12 01:55 PM |
Posts: 3,224 Roanoke Island ,N.C. | If your mast is at 90 degrees upwind, that could be taking a lot of shape out of the main. Try rotating the mast back so the limiter (or luff track) points somewhere between the daggerboard trunk and the rear beam...this is a more typical upwind setting and may give you some more shape.
Working/shaving your battens worked well on stretchy dacron sails - but isn't going to make a significant difference on pentex/mylar sails. The difference between the two shapes you have has more to do with how much curve was shaped into the luff of the sail...also remember that flatter doesn't necessarily mean slower. Sail shapes have evolved a little flatter over the last several years so it may just require some different tuning. I think he was referring to mast rake ,not rotation as far as the perpendicular thing. Like the second post said try less spreader rake to get more shape in the luff.
| | | Re: sail shape help
[Re: Headhunter]
#243014 01/25/12 02:36 PM 01/25/12 02:36 PM |
Posts: 1,203 uk | loosen the battens and unroll the sail flat on the ground the sail will then be board flat string a line from head to tack and you will see the luff curve. when your mast bends/prebends this much - you will have a flat sail. your mast needs to be straighter than this luff curve to have shape.
| | | Re: sail shape help
[Re: TEAMVMG]
#243015 01/25/12 02:49 PM 01/25/12 02:49 PM |
Posts: 91 Dunedin, FL | loosen the battens and unroll the sail flat on the ground the sail will then be board flat string a line from head to tack and you will see the luff curve. when your mast bends/prebends this much - you will have a flat sail. your mast needs to be straighter than this luff curve to have shape. Great explanation, thanks all for the suggestions. | | | Re: sail shape help
[Re: Team_Cat_Fever]
#243109 01/27/12 06:53 AM 01/27/12 06:53 AM |
Posts: 246 Kiel, Germany | Like the second post said try less spreader rake to get more shape in the luff.
Does this have an influence even if you don't pull the cunningham?
F18: C2 / A-Cat: Minelli
| | | Re: sail shape help
[Re: Headhunter]
#243168 01/27/12 03:39 PM 01/27/12 03:39 PM |
Posts: 297 | I agree with all the posts here and would add some of my experience in this regard. When I got my first 2-up performance catamaran (an N5.5) it came with some really old rags, and the sail was very blown out. The result of this shape was that the sail was extremely full chord and powerful in light air, fast on the reach, but hopelessly uncontrollable and would not point. Old sails are powerful, but not tunable. The compensation for me was to add much more pre-bend to the mast, which served to flatten the old worn out sail. Obviously, if new rags were to be run up the mast, the effect would have been to flatten the new sail drastically, and it would have been similarly de-powered as in your case. ( In my case I bought an f18...)
The A cat guys do something to check the tune which is kind of a handy trick-they rig the main out of the track, rig the sail with the boat on its side and honk the mainsheet and downhaul on maximally. They then see if the luff curve of the main matches the mast prebend, moving mast rotation accordingly. A very good match of the curve to the mast would then logically represent the maximum flattening of the sail, and a good match of the curves of the luff and mast representing the ideal maximum adjustment to take advantage of the dynamic range of the luff curve in the sail. They then adjust the spreaders to get it as even as they can as a starting point for their sail tuning. Then they let it all slack and note the chord depth of the sail and adjust a bit either way. Try it. It's easy and very interesting to see how the luff curve works for sail shape, and gets you thinking about the sail at the least.
Nacra F18 #856
2,801
guests, and 682
