| Question for Carbon 20 Owners/dealers #244290 02/18/12 05:26 AM 02/18/12 05:26 AM |
Posts: 554 Boston, Ma | Question for the Carbon 20 owners: the 20 I was sailing on today in Singapore is missing the cap on the inner end of the spin pole that slots into the pin on the front beam. I'm thinking about 3D printing one for tomorrow, but don't have the dimensions. Does anyone know the outer diameter and wall thickness of the spin pole tube, as well as the diameter of the hole in the middle of that plug? Thanks!
USF18 Eastern Area Rep Nacra Infusion USA 753
| | | Re: Question for Carbon 20 Owners/dealers
[Re: Jeff.Dusek]
#244291 02/18/12 06:35 AM 02/18/12 06:35 AM |
Posts: 242 Brisveagas | Hi jeff
You should know better than to search for useful info on the internet.
I thought i heard somone that the infusion is 38mm OD. They look to be the same section on the few boats ive seen???? The pin has to be about 4mm.
Aido Viper 288
[Re: Jeff.Dusek]
#244292 02/18/12 06:41 AM 02/18/12 06:41 AM |
Posts: 554 Boston, Ma | Very true... I decided to make two, one for a 38mm OD and one for a 55mm OD. Used a 6.5mm hole for both... we'll see if they work!
[Re: Jeff.Dusek]
#244293 02/18/12 06:46 AM 02/18/12 06:46 AM |
Posts: 242 Brisveagas | 6.5 would probably be closer.
Aido Viper 288
[Re: Aido]
#244294 02/18/12 06:48 AM 02/18/12 06:48 AM |
Posts: 242 Brisveagas | Can the printer make a perfect hole in the middle?
Aido Viper 288
[Re: Jeff.Dusek]
#244296 02/18/12 06:56 AM 02/18/12 06:56 AM |
Posts: 554 Boston, Ma | It will be close, not perfect. I decided not to do the 55mm OD, it was clearly too big. I figure if the hole is a bit small it can be drilled out tomorrow. Figured I would give it a try as I am sitting next to the printer at work.
[Re: Jeff.Dusek]
#244297 02/18/12 07:01 AM 02/18/12 07:01 AM |
Posts: 98 | Jeff, I have PM'd you.
[Re: Jeff.Dusek]
#244298 02/18/12 07:14 AM 02/18/12 07:14 AM |
Posts: 554 Boston, Ma | Appreciate the quick help guys!
869
guests, and 39
Mod | | Forums26 Topics22,406 Posts267,061 Members8,150 | Most Online2,167 Dec 19th, 2022 | | | |
