Question for Carbon 20 Owners/dealers #244290
02/18/12 05:26 AM
02/18/12 05:26 AM
Boston, Ma
Jeff.Dusek Offline OP
Boston, Ma
Question for the Carbon 20 owners: the 20 I was sailing on today in Singapore is missing the cap on the inner end of the spin pole that slots into the pin on the front beam. I'm thinking about 3D printing one for tomorrow, but don't have the dimensions. Does anyone know the outer diameter and wall thickness of the spin pole tube, as well as the diameter of the hole in the middle of that plug? Thanks!
USF18 Eastern Area Rep
Nacra Infusion USA 753
Re: Question for Carbon 20 Owners/dealers [Re: Jeff.Dusek] #244291
02/18/12 06:35 AM
02/18/12 06:35 AM
Brisveagas
Aido Offline
Aido  Offline
Brisveagas
Hi jeff
You should know better than to search for useful info on the internet.
I thought i heard somone that the infusion is 38mm OD. They look to be the same section on the few boats ive seen???? The pin has to be about 4mm.
Aido
Viper 288
Re: Question for Carbon 20 Owners/dealers [Re: Jeff.Dusek] #244292
02/18/12 06:41 AM
02/18/12 06:41 AM
Boston, Ma
Boston, Ma
Very true... I decided to make two, one for a 38mm OD and one for a 55mm OD. Used a 6.5mm hole for both... we'll see if they work!
Re: Question for Carbon 20 Owners/dealers [Re: Jeff.Dusek] #244293
02/18/12 06:46 AM
02/18/12 06:46 AM
Brisveagas
Aido Offline
Aido  Offline
Brisveagas
6.5 would probably be closer.
Aido
Viper 288
Re: Question for Carbon 20 Owners/dealers [Re: Aido] #244294
02/18/12 06:48 AM
02/18/12 06:48 AM
Brisveagas
Aido Offline
Aido  Offline
Brisveagas
Can the printer make a perfect hole in the middle?
Aido
Viper 288
Re: Question for Carbon 20 Owners/dealers [Re: Jeff.Dusek] #244296
02/18/12 06:56 AM
02/18/12 06:56 AM
Boston, Ma
Boston, Ma
It will be close, not perfect. I decided not to do the 55mm OD, it was clearly too big. I figure if the hole is a bit small it can be drilled out tomorrow. Figured I would give it a try as I am sitting next to the printer at work.
Re: Question for Carbon 20 Owners/dealers [Re: Jeff.Dusek] #244297
02/18/12 07:01 AM
02/18/12 07:01 AM
N
NacramanUK Offline
NacramanUK  Offline
N
Jeff, I have PM'd you.
Re: Question for Carbon 20 Owners/dealers [Re: Jeff.Dusek] #244298
02/18/12 07:14 AM
02/18/12 07:14 AM
Boston, Ma
Boston, Ma
Appreciate the quick help guys!
