F18 Wind Limits #244348
02/20/12 10:09 AM
02/20/12 10:09 AM
David Prince Offline OP
We are new to F18s and were out "training" on the water yesterday. The winds were 17 gusting to 28 and it was more than a handful. Sailing upwind wasn't an issue but turning off the wind was flat out exhilarating. When over powered while reaching, what are my options to depower? Keeping the main tight and steering down seemed to be the only thing that worked. The only problem was with the main in tight, best not steer down too far. I did this once with an immediate gybe. We both went swimming and practiced our righting technique. My crew was pretty much done "training" for the day after that. The steady 17-18 mph winds seemed ok but gusting to 28 seems beyond what we can control.
Re: F18 Wind Limits [Re: David Prince] #244398
02/21/12 09:27 AM
02/21/12 09:27 AM
Boston, Ma
Jeff.Dusek Offline
Jeff.Dusek  Offline
Boston, Ma
When you say reaching, what angle are you talking? Two sail-reaching usually demands a lot of sheet work by the crew to keep the boat flying a hull and going fast. When really powered, dropping the traveler helps a lot. Also, make sure to move your weight back- skipper an be in the footstrap if it is choppy.
If you have the kite up, and are forced to sail high, again dropping the traveler helps. You can also go to two-wires. In both cases, make sure you are pulling your boards up some, this will really make the boat feel better, and is faster. Like you mentioned sailing lower is the best way to calm things down a bit, the boat can recover from a lot when both hulls are in the water.
As far as general depowering upwind, make sure you have your cunningham led out to the crew's trapeze so you can play it constantly. If you find you are maxing the cunningham, rotate the mast back some-this makes a huge difference. Also make sure your diamond tension is correct for the breeze- we tend to adjust ours between most races. If it is really breeze, try switching the jib clew to the bottom most hole, and easing the jib traveller way out. You definitely still want to be able to foot and go fast, so depower early, especially if you are light!
USF18 Eastern Area Rep
Nacra Infusion USA 753
0 registered members (), 4,623 guests, and 532 spiders.
