Page 2 of 3 1 2 3
Re: 7:1 to 8:1 conversion [Re: ] #244152
02/16/12 04:15 PM
02/16/12 04:15 PM
Solomon's Island, MD
samc99us Offline
samc99us  Offline
N20, but I suspect the leech loads are pretty similar these days on the F18 high aspect ratio mains.
Scorpion F18
Re: 7:1 to 8:1 conversion [Re: Andinista] #244303
02/18/12 11:11 AM
02/18/12 11:11 AM
Walls619 Offline
Walls619  Offline
Any diagram, for harken quad stack main block?
Re: 7:1 to 8:1 conversion [Re: Andinista] #244305
02/18/12 02:23 PM
02/18/12 02:23 PM
california
F-18 5150 Offline
F-18 5150  Offline
california
I have the 5 block on top with a triple and a double on a becket on bottom . Using a tapered main it works great for me.
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
[email protected]
Fairfield, Ca
F-18 5150
Re: 7:1 to 8:1 conversion [Re: Andinista] #244327
02/20/12 12:23 AM
02/20/12 12:23 AM
Walls619 Offline
Walls619  Offline
line route for 8-1 main block
Re: 7:1 to 8:1 conversion [Re: Walls619] #244339
02/20/12 09:16 AM
02/20/12 09:16 AM
M
MN3
MN3
M
Re: 7:1 to 8:1 conversion [Re: Andinista] #244345
02/20/12 09:58 AM
02/20/12 09:58 AM
Nice! Thanks for that picture, worth a thousand words. Now I've got to pull mine apart and re-do it right!
Re: 7:1 to 8:1 conversion [Re: Andinista] #244351
02/20/12 10:32 AM
02/20/12 10:32 AM
M
MN3
MN3
M
Y/w
Re: 7:1 to 8:1 conversion [Re: Andinista] #244383
02/20/12 08:39 PM
02/20/12 08:39 PM
Walls619 Offline
Walls619  Offline
thanks ,now on to nacra rudder system non pivmatic..pull down line to cam cleat on rear beam continuous line,,schock cord up through rudder control arm?Sound right any decent picture will help possable upgrade;;
Re: 7:1 to 8:1 conversion [Re: Andinista] #244412
02/21/12 11:56 AM
02/21/12 11:56 AM
SE Pa. or Chesapeak Bay
HMurphey Offline
HMurphey  Offline
Not so fast ....
Study that diagram closely on how to weave/thread the mainsheet line .... now, if you rotate the single block attached to the camcleat 90*, so that it is orientated ACROSS the axis of the triple and quad blocks, there is a way to weave/thread the mainsheat line w/ no crosses .... so it will operate cleanly ...
Can you fiqure it out??? (Hint: At one point, you will need to thread the mainsheat from the extreme outboard sheave on the Quad Block, down and through the Single Block, and then back up to the other outboard sheave on the Quad Block ...)
Try it ... it works really well, but you need to actually see it/play with-it ... to apprieciate how it works
Note: It works best if the Single Block is the same size sheave as the Triple and Quad Block's sheaves ....
Harry
H18Mag/P19MX
Re: 7:1 to 8:1 conversion [Re: samc99us] #244417
02/21/12 12:33 PM
02/21/12 12:33 PM
Santiago, Chile
Andinista Offline OP
Santiago, Chile
Originally Posted by samc99us
I don't suggest modifying an existing block system. "Upgraded" an 8:1 system to a 9:1, but the existing block hardware was not beefy enough to handle the loads, found out the hard way 3 days into Tybee.
This statement suggests that an increase in purchase means necessarily an increase in max load applied. Is that really true? Don't we want to actually lower the pull to acheive similar results? Therefore more pulleys should mean lower load and not higher, except at the connections in both ends, where the total load is applied.
That's assuming that the goal is to distribute the load rather than apply more total tension. Maybe I'm wrong there.. Still, we are talking about a 10 to 15% increase in purchase, which comes with a decrease in overall efficiency because of the higher friction, therefore, the total tension is increeased in less than that. Would that be enough of an increment to break the blocks? If not rearranging blocks too differently (like the single block suggested in the first post) I think it shoudn't
Re: 7:1 to 8:1 conversion [Re: Andinista] #244420
02/21/12 12:49 PM
02/21/12 12:49 PM
M
MN3
MN3
M
I agree with Andinista and have recently added another block to my 8:1(even after reading this thread).
Sure i can now probably apply more force, but i don't want to. my goal was to need less strength to sheet to the same amount (i have shoulder issues).
Also i have a hard time believing the sheeting forces are the same on an f18 and n20... but i am not an engineer
Re: 7:1 to 8:1 conversion [Re: Andinista] #244427
02/21/12 01:35 PM
02/21/12 01:35 PM
Santiago, Chile
Santiago, Chile
Did you notice the difference?
(I'm feeling guilty about spending that money in blocks rather than with my wife.. I need some reassurance..)
Re: 7:1 to 8:1 conversion [Re: Andinista] #244428
02/21/12 01:39 PM
02/21/12 01:39 PM
pgp Offline
pgp  Offline
I haven't actually tried mine but went to the 8:1 in the belief that I'm undersheeting while sailing alone.
I've little doubt the money is well spent.
Pete Pollard
Blade 702
Re: 7:1 to 8:1 conversion [Re: Andinista] #244429
02/21/12 01:44 PM
02/21/12 01:44 PM
Santiago, Chile
Santiago, Chile
I ordered the quad blocks by the way. The single block idea was probably good but was about half the price, not cheap enough for a probably compromised solution. (That's how I convinced myself anyway..)
Re: 7:1 to 8:1 conversion [Re: Andinista] #244430
02/21/12 01:47 PM
02/21/12 01:47 PM
pgp Offline
pgp  Offline
I did the same, for much the same reason. A lot of F16s are using the system and I wanted to keep the boat as current as reasonably possible.
Pete Pollard
Blade 702
Re: 7:1 to 8:1 conversion [Re: pgp] #244434
02/21/12 02:00 PM
02/21/12 02:00 PM
Santiago, Chile
Santiago, Chile
Here is how I intend to route the line, it seems to be the option with less crossings and with a more even distribution of the line segments speeds:
What do you think?
Re: 7:1 to 8:1 conversion [Re: Andinista] #244435
02/21/12 02:10 PM
02/21/12 02:10 PM
pgp Offline
pgp  Offline
http://www.catsailor.com/forums/ubbthreads.php?ubb=showflat&Number=244434&page=3
I ran mine like the other example, though I came up with it through trial and error.
I could not make fine adjustments with 7:1, to sheet hard I'd actually lift my butt off the hull, that resulted in steering all over the place.
Pete Pollard
Blade 702
Re: 7:1 to 8:1 conversion [Re: Andinista] #244440
02/21/12 02:20 PM
02/21/12 02:20 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
What do you think?
Whoa! cats cradle! The top block needs to be at 90 degrees to the triple
Re: 7:1 to 8:1 conversion [Re: Andinista] #244441
02/21/12 02:21 PM
02/21/12 02:21 PM
M
MN3
MN3
M
i can't say i felt much difference but my shoulders are less sore than usual.
Re: 7:1 to 8:1 conversion [Re: Andinista] #244449
02/21/12 05:00 PM
02/21/12 05:00 PM
ccat Offline
ccat  Offline
HM is right.
There is a much better way to reeve than the Harken diagram.
PM for a pic
Page 2 of 3 1 2 3
0 registered members (), 15,506 guests, and 807 spiders.
Most Online22,490
10 hours ago
