| Re: Rules changes
[Re: Sloansailing]
#244471 02/22/12 02:01 AM 02/22/12 02:01 AM |
Posts: 108 | Painting a hull after its built is "the normal maintenance procedure"?
as non english native, I look for a dictionnary definition of routine (the word used in the rules) :
1.a customary or regular course of procedure. 2.commonplace tasks, chores, or duties as must be done regularly or at specified intervals; typical or everyday activity: the routine of an office. 3.regular, unvarying, habitual, unimaginative, or rote procedure. 4.an unvarying and constantly repeated formula, as of speech or action; convenient or predictable response: Don't give me that brotherly-love routine!
in this case:
I wash my hull, take-off the stickers organisation is routine maintenance. Repairing a hole is also routine maintenance every time you have to do it. Painting an entire hull just after its building is obviously not a routine.
But this is not a word issue. This rule (as other one) can be changed but with one year notice, in order to be fair. All the boat maker playing same game.
| | | Re: Rules changes
[Re: macca]
#244483 02/22/12 09:21 AM 02/22/12 09:21 AM |
Posts: 1,152 tampa, fl | Franck,
You can think what you like, but I have discussed he matter at length with ISAF and it's perfectly legal to paint the hulls after manufacture. But that does not appear to be what the intent of the rule is. According to the rule, boats are to be manufactured with a gelcoat finish, paint is to be used as a repair/maintenace solution, not as a means to refinish the boat to gain an perceived advantage. (if you are so insistant that the boats be painted instead of gelcoat, other than a performance advantage, what could your motivation be)?
If your havin girl problems i feel bad for you son I got 99 problems but my beautiful wife ain't one | | | Re: Rules changes
[Re: ksurfer2]
#244514 02/22/12 02:12 PM 02/22/12 02:12 PM |
Posts: 3,906 Clermont, FL, USA | Franck,
You can think what you like, but I have discussed he matter at length with ISAF and it's perfectly legal to paint the hulls after manufacture. But that does not appear to be what the intent of the rule is. According to the rule, boats are to be manufactured with a gelcoat finish, paint is to be used as a repair/maintenace solution, not as a means to refinish the boat to gain an perceived advantage. (if you are so insistant that the boats be painted instead of gelcoat, other than a performance advantage, what could your motivation be)? +1
| | | Re: Rules changes
[Re: macca]
#244527 02/22/12 04:25 PM 02/22/12 04:25 PM |
Posts: 1,152 tampa, fl | There have been painted F18's from the very inception of the class. Paintis not a new method to surface coat an F18. This is not an acceptable reason to not follow the intent of the rule. The rule says gelcoat, so why are you so insistant on paint.
[Re: macca]
#244547 02/22/12 09:42 PM 02/22/12 09:42 PM |
Posts: 71 | How could you use gelcoat to surface coat a wood-epoxy f18? Plywood-epoxy F18's are illegal unless they are made of balsa. | | | Re: Rules changes
[Re: F18_VB]
#244575 02/23/12 09:01 AM 02/23/12 09:01 AM |
Joined: Jun 2005 Posts: 302 Daytona Beach Florida orphan
Posts: 302 Daytona Beach Florida | How could you use gelcoat to surface coat a wood-epoxy f18? Plywood-epoxy F18's are illegal unless they are made of balsa. D.3.1 MATERIALS (a) The hull shells shall be built from polyester or vinylester resin, glass fibres, polyester gelcoat, a core of PVC, balsa or felt, the combination of wood-epoxy, injected plastic, which shall not be altered other than locally for fittings, and passage of equipment and normal reinforcement. Epoxy glue is permitted for joining components. Every material that is not expressly permitted is prohibited. Looks like wood-epoxy is allowed. | | | Re: Rules changes
[Re: macca]
#244580 02/23/12 09:51 AM 02/23/12 09:51 AM |
Posts: 1,152 tampa, fl | If, as you argue, paint is such a superior product to use to finish boats, why are the major players in the class (Hobie, AHPC, Nacra), not turning out painted boats instead of gelcoated boats? I am not trying to be argumentative here, there must be a reason and I am really interested to know what it is.
[Re: orphan]
#244585 02/23/12 10:32 AM 02/23/12 10:32 AM |
Posts: 71 | How could you use gelcoat to surface coat a wood-epoxy f18? Plywood-epoxy F18's are illegal unless they are made of balsa. D.3.1 MATERIALS (a) The hull shells shall be built from polyester or vinylester resin, glass fibres, polyester gelcoat, a core of PVC, balsa or felt, the combination of wood-epoxy, injected plastic, which shall not be altered other than locally for fittings, and passage of equipment and normal reinforcement. Epoxy glue is permitted for joining components. Every material that is not expressly permitted is prohibited. Looks like wood-epoxy is allowed. Wow, I have read that rule wrong for years. I thought it was trying to say that only a "wood" epoxy could be used. I even asked for a clarification once about what epoxy would count as "wood" epoxy. Yet another example of poorly worded rules. | | | Re: Rules changes
[Re: macca]
#244592 02/23/12 11:07 AM 02/23/12 11:07 AM |
Posts: 2,584 +31NL | Paint is not a new development in the class, its just an issue now because a painted boat is winning.
That seems a bit unfair Macca, so far it has only won one event and it was sailed by someone who could make a bathtub go fast.
| | | Re: Rules changes
[Re: macca]
#244599 02/23/12 12:14 PM 02/23/12 12:14 PM |
Posts: 108 |
Here is the origin of many wrong thinking. Indeed, a painted or gel-coated boat is not winning. Never. The sailors did. By their talent and work. The spirit of F18 is to have very close boat in order to have close fight in real time, where sailors skill and decision make the difference. What is the sport interest to win if the boat is faster ? F18 isn't Formula 1 racing. Though it is always a ordinary commercial interest to make people believe that new brand are faster. | | | Re: Rules changes
[Re: Karl Funk]
#244606 02/23/12 12:39 PM 02/23/12 12:39 PM |
Posts: 108 | I am with Macca. I do not see what the "intent" of the rule matters when it would have been perfectly easy to write them otherwise. If painting a boat after manufacture was not allowed there are various wordings that could have made this clear.
As far as I am concerned, ambiguity is laziness and when rules are written with ambiguity it can only be interpreted as intentional.
Cheers, Karl It's, of course not, a question of person. For me, to be with or against anybody isn't the path. On the paint question the very last TC (long and hard) work report show that there is not consensus between manufacturers. In the same time ISAF has confirmed the World Council (WC) decisions of november, that everybody can check by crossing the minutes of the WC and the last ISAF publication. ISAF is a big machine so they process step by step and in a very logical way: written interpretation (cleaning that what WC ask), amendments and then updating class rules. http://www.sailing.org/2129.phpIt is always possible to ask for interpretation of the interpretation done by ISAF, but I can't see why ISAF people would change their mind in a few days. There is no more ambiguity. By the way ISAF changed the chapter of the maintenance item in order to stress that "routine maintenance" is under sailor responsability and add polyester gel coat in the list of materials. ISAF is the third institution,in the process of decision: it is a team work. First step is the Technical comittee (TC), composed by boats and sails makers and collecting point of view from industry people: Goodall, Boulogne, Soldano, Lauriot-Prevost, Contreas, Rogers, Melvin, Jary... They give advices but it is the WC which decide and vote. WC, the second step, is composed mostly by F18 sailors and elected by F18 sailors. For the WC, nations aren't the key for the weight of vote. One French/Italian/Ned F18 member is not more important but not less than one US, Australian or Argentinian F18 members. That is important, because on one hand you have (respectable) commercial interest, on the other hand: class of F18 owner/members interest. Indeed, guys who paid their boat, do vote the rules. Please read the Don Finlay (TC Chairman) text which explain that better than I can do with my poor english: http://tinyurl.com/7vpfmz6 The main reason of the F18 success is that we're sailing F18 for fun. And only Champions win, not the boat. Franck Tiffon WC french representative -www.f18.fr- F18 sailor since october 1994 (White Hawk with gel coat ;-) Capricorn F18 FRA 327 | | | Re: Rules changes
[Re: ksurfer2]
#244661 02/23/12 03:37 PM 02/23/12 03:37 PM |
Posts: 606 Maryland | If, as you argue, paint is such a superior product to use to finish boats, why are the major players in the class (Hobie, AHPC, Nacra), not turning out painted boats instead of gelcoated boats? I am not trying to be argumentative here, there must be a reason and I am really interested to know what it is. The answer is clearly stated in the Nov 2011 WC minutes. "The view of the committee is that it is not desirable at this point to have boats supplied with an epoxy finish from the factory. It was discussed that epoxy coatings have some potential advantages for the class, particularly for maintenance. But it is felt that the current risk to the class of having boats marketed and sold with 'premium' epoxy coatings is undesirable, and a sufficient risk to the class right now to justify strict control." That statement in addition to Don Finlay's (TC Chairman) January article about preserving the value in the existing F-18 fleet makes it clear why the the action was taken. It presumes that the sailors do not see through the marketing spin and would cause an overnight devaluation in the existing inventory of boats. A by-product is that it protects the gel-coat based builders' market share. Unfortunately, the painted boats were in compliance with the rules before the recent revision. It smacks of protectionism and assumes that the racers are "lemmings" to the latest fad and that we need to be protected from ourselves. If the information was out that a gel-coat finish is no slower or faster than an epoxy finish, the percieved threat would be invalid.
Kris Hathaway | | | Re: Rules changes
[Re: Kris Hathaway]
#244663 02/23/12 03:42 PM 02/23/12 03:42 PM |
Posts: 1,152 tampa, fl | If, as you argue, paint is such a superior product to use to finish boats, why are the major players in the class (Hobie, AHPC, Nacra), not turning out painted boats instead of gelcoated boats? I am not trying to be argumentative here, there must be a reason and I am really interested to know what it is. The answer is clearly stated in the Nov 2011 WC minutes. "The view of the committee is that it is not desirable at this point to have boats supplied with an epoxy finish from the factory. It was discussed that epoxy coatings have some potential advantages for the class, particularly for maintenance. But it is felt that the current risk to the class of having boats marketed and sold with 'premium' epoxy coatings is undesirable, and a sufficient risk to the class right now to justify strict control." That statement in addition to Don Finlay's (TC Chairman) January article about preserving the value in the existing F-18 fleet makes it clear why the the action was taken. It presumes that the sailors do not see through the marketing spin and would cause an overnight devaluation in the existing inventory of boats. A by-product is that it protects the gel-coat based builders' market share. Unfortunately, the painted boats were in compliance with the rules before the recent revision. It smacks of protectionism and assumes that the racers are "lemmings" to the latest fad and that we need to be protected from ourselves. If the information was out that a gel-coat finish is no slower or faster than an epoxy finish, the percieved threat would be invalid. Please excuse my ignorance, but does "epoxy finish" or "Premium epoxy coating" equal paint?
2,929
guests, and 191
