mid-Atlantic sailmaker recommendation #245384
03/09/12 12:22 PM
03/09/12 12:22 PM
Philadelphia PA
WetRat Offline OP
WetRat  Offline OP
Philadelphia PA
I need to find a sailmaker in the mid Atlantic region with experience with beachcats who can rework the luff curve of my sail. The reason I am looking for a reasonably local loft is my assumption it would be best for the sailmaker to see the sail on the mast. I think the sail has too much depth, particularly in the upper third. If I get the top working the leach tails on the lower part stall. The situation may be hopeless.
Can anyone recommend a sailmaker somewhere between Virginia and Connecticut?
Re: mid-Atlantic sailmaker recommendation [Re: WetRat] #245403
03/10/12 03:47 AM
03/10/12 03:47 AM
C
chakkochik Offline
chakkochik  Offline
C
I too would like to know the answer
Re: mid-Atlantic sailmaker recommendation [Re: WetRat] #245471
03/12/12 09:54 PM
03/12/12 09:54 PM
Will_R Offline
Will_R  Offline
I wouldn't limit yourself on sail makers like that. Any good sail maker should be able to work with bend numbers and not have to see the pair together. Also, pictures, LOTS of pictures.
Re: mid-Atlantic sailmaker recommendation [Re: Will_R] #245480
03/13/12 07:34 AM
03/13/12 07:34 AM
Maryland
Kris Hathaway Offline
Maryland
Tony Arends is affiliated with a major sail loft and building beach cat sails again, racerxsailing at comcast dot net, Annapolis, MD. If you are in the area, consider racing Tuesday evening, a one-design fleet regatta, and/or an open race this season.
Kris Hathaway
Re: mid-Atlantic sailmaker recommendation [Re: WetRat] #245494
03/13/12 03:30 PM
03/13/12 03:30 PM
ccat Offline
ccat  Offline
Re: mid-Atlantic sailmaker recommendation [Re: WetRat] #245499
03/13/12 06:18 PM
03/13/12 06:18 PM
Philadelphia PA
WetRat Offline OP
WetRat  Offline OP
Philadelphia PA
Kris - Tony Arends (aka Racerxsailing) is not doing sail work at this time. Oh well ...
Thanks for suggestion and the invitation to race at Annapolis.
0 registered members (), 568 guests, and 524 spiders.
