| Re: Sealing the hullsa
[Re: Mark Milam]
#245883 03/21/12 08:36 AM 03/21/12 08:36 AM |
Joined: Jun 2001 Posts: 890 Dunedin Causeway, FL David Parker
Posts: 890 Dunedin Causeway, FL | I have a 2009 and have sealed the Back port under the Blue Pad....Does anyone know if there is a front port under the Front pad???... A while back I posted some photos from when I sealed my ports. Search this Wave forum for a thread called "Leaky boat". I have had no leaks since then. Apparently mine was from rain pooling on the seats and getting in through those ports. | | | Re: Sealing the hullsa
[Re: Mark Milam]
#245886 03/21/12 09:14 AM 03/21/12 09:14 AM |
Posts: 778 Houston | To answer your question about Trim Adhesive: My tube is old they now call it 3M 08001 Yellow Super Weatherstrip and Gasket Adhesive http://www.amazon.com/3M-08001-Yell...p;ie=UTF8&qid=1332337891&sr=1-10Most auto parts store carry it. You want the nasty looking yellow stuff. 3M makes a whole line of similar products. For example, is also a spray called 3M 77, that does not dry. It's always sticky. 3M replied quickly. 5200 does not stick to HPDE, it just provides a gasket. The yellow gasket adhesive provides a mechanical bond. However they do list a adhesive that will bond to HDPE but, it will be a weak bond It has possibilities for fairing scratches and such. It is in the professional line so it will be expensive and hard to buy. | | | Re: Sealing the hullsa
[Re: carlbohannon]
#245996 03/23/12 12:10 AM 03/23/12 12:10 AM |
Posts: 921 Alachua, FL | To answer your question about Trim Adhesive:
3M replied quickly. 5200 does not stick to HPDE, 3M is wrong....5200 sticks very well to a Wave skin. We have made a number of remarkable repairs including gluing on two wooden replacement keels that you would be hard pressed to tell, and a transom that was partially ripped loose. I would fear that it would be too aggressive to install the underseat port covers if you EVER wanted to get them loose again.
Jack Woehrle Hobie Wave #100, Tiger Shark III HCA-NA 5022-1 USSailing 654799E Alachua FL/Put-In-Bay | | | Re: Sealing the hulls and other repairs
[Re: Mugrace72]
#248840 05/24/12 12:06 PM 05/24/12 12:06 PM |
Posts: 917 Issaquah, WA, USA | Just repaired one of our Waves that had holes at the skegs. Filled with 5200, then formed 18 gage aluminum sheet over skeg, and secured with 3/16in rivets. We will see how it works. After several years of hard use, the skegs was wearing through. Also, had problems with 2004 models, weak transoms. Fixed by putting 3/4 in plywood brace inside hulls, and bolting with upper rudder pintle bolts, and additional bolts, with fender washers. After several years of service they are doing fine. Also added access ports on hulls. Another fix for shroud chain plates. Added backing plate, and thru bolts on chain plates. You can access thru ports under the forward hull pads. We have seven Waves at Sail Sand Point in Seattle, that get severe use. | | | Re: Sealing the hulls and other repairs
[Re: H17cat]
#248849 05/24/12 03:12 PM 05/24/12 03:12 PM |
Posts: 3,969 | Just repaired one of our Waves that had holes at the skegs. Filled with 5200, then formed 18 gage aluminum sheet over skeg, and secured with 3/16in rivets. We will see how it works. After several years of hard use, the skegs was wearing through. Also, had problems with 2004 models, weak transoms. Fixed by putting 3/4 in plywood brace inside hulls, and bolting with upper rudder pintle bolts, and additional bolts, with fender washers. After several years of service they are doing fine. Also added access ports on hulls. Another fix for shroud chain plates. Added backing plate, and thru bolts on chain plates. You can access thru ports under the forward hull pads. We have seven Waves at Sail Sand Point in Seattle, that get severe use. WOW!!! As if anyone thought there has never been a good enough reason to NOT beach your boat every time you come in, this is it for sure!!! Mike | | | Re: Sealing the hulls and other repairs
[Re: brucat]
#248880 05/25/12 11:29 AM 05/25/12 11:29 AM |
Mike [/quote]
True, but our Waves at Sail Sand Point are sailed by kids, and adults, up to 12 hours a day. Some of the Waves are 12 years old. I can not think of any boat that can take that use, and still be sailed. So, a little repair is not a problem. Also, we just rotated, sold, two Waves, and replaced with two new Waves. Sold them for about one half the cost of a new Wave. Try that return with any used sail boat. | | |
510
guests, and 40
