Unknown rigging #24690
09/30/03 06:43 PM
09/30/03 06:43 PM
yankyfan2000 Offline OP
Along with a bunch of other stuff that came with my boat, A piece of rigging that is about 20 feet long, came with it. Pretty much half is rope, and the other half is cable. Where the cable meets the rope , there is a series of beeds on the cable spaced out about 2 inches. And there is a pully on the cable, that i think catches on the beads. Does anyone have any idea what it is? I also have another one but it is broken.
Thank you
Anthony-----H14
Re: Unknown rigging [Re: yankyfan2000] #24691
09/30/03 11:08 PM
09/30/03 11:08 PM
Fort Loramie, Ohio
jmhoying Offline
jmhoying  Offline
Fort Loramie, Ohio
Sounds like it might be a discard from another boat, or maybe someones custom rigging?? I've never seen anything like that in the Hobie catalog.
Jack
Re: Unknown rigging [Re: jmhoying] #24692
10/01/03 03:07 PM
10/01/03 03:07 PM
ya it must be, I also have a pully set up that had what i think is called a fiddle block on the bottom with a jam cleat, o dont see what it can be used for becuase it is rigged differently then the one on my boat. Any idea what its for?
Anthony-----H14
Re: Unknown rigging [Re: yankyfan2000] #24693
10/06/03 08:37 PM
10/06/03 08:37 PM
Christchurch, New Zealand
NZhobie Offline
NZhobie  Offline
Hi, I recently bought a H14 turbo with a similar line with it. I worked out that it was to help step the mast single-handed and actually replaced the standard front rigging. Mine has a long rope with a block pulley attached and if you pin the mast with the mast stepping set-up, in therory you should be able to raise the mast yourself, while standing at the front of the boat. I tried it on a still day and it did not go too well as you have no control over the mast from swinging from side to side! I don't step the mast that way now!!
The rope is attached to the top of the jib via a pulley.
Well, thats what my one has got... a consideration for you as to what it maybe anyway.
Geoff B - NZ hobie
Re: Unknown rigging [Re: NZhobie] #24694
10/16/03 03:03 PM
10/16/03 03:03 PM
Houston Texas
prindlesnark Offline
Houston Texas
Yes I have seen those aftermarket to "help" to step the mast solo. Good luck
Jason Snark the Prindle sailing thunderchicken [email protected]
0 registered members (), 2,981 guests, and 191 spiders.
