by Karl_Brogger. 12/29/24 05:14 PM
Tramp slugs on I-20 #246739
04/05/12 08:27 PM
04/05/12 08:27 PM
Arizona
AzCat Offline OP
AzCat  Offline OP
Arizona
I have a side lace tramp on my I20 . I used the tramp slugs recomended by Performance (from Murrays), as soon as I stepped on the tramp, about 8 of them pulled out of the slot. I thought maybe if I bent the wires at about a 20*angle downward it might help.When the tramp is installed it pulls downward on the slugs, and the slugs are pointed upward at about 10*. I think that the combined pressure of all of the slugs wedging the slot open is the problem. Anyone had to do this or had the same problem? Better way?. Suggestions?
Auscat MKV 444 A class
NACRA I-20- 440/CATHATKA
Re: Tramp slugs on I-20 [Re: AzCat] #246740
04/05/12 08:29 PM
04/05/12 08:29 PM
Arizona
AzCat Offline OP
AzCat  Offline OP
Arizona
Also, Has anyone routed out the bolt rope groove larger and used a larger bolt rope?
Re: Tramp slugs on I-20 [Re: AzCat] #246745
04/06/12 06:43 AM
04/06/12 06:43 AM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
azcat,
the slugs that murray's sells are too small. I made the same mistake of buying them and realizing that they're too small.
You don't want to use those hard slugs anyways. I've been told that they'll end up enlarging the slot over time and ultimately ruining the rail.
Here's what I use. If you call Nacra directly, they'll know what you want if you describe it properly.
Re: Tramp slugs on I-20 [Re: AzCat] #246746
04/06/12 07:38 AM
04/06/12 07:38 AM
Solomon's Island, MD
samc99us Offline
samc99us  Offline
Slugs made by Elliot Patterson work well. The rails shown above are superior to the slugs, I think EP can make those as well.
The time consuming option is to fill your rails with thickened epoxy and put the screws in like the factory did on new boats, but the 2 option above work just fine!
Scorpion F18
Re: Tramp slugs on I-20 [Re: AzCat] #246749
04/06/12 09:08 AM
04/06/12 09:08 AM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
The tabs/soft slugs on the rope that EP sell will also work excellent if you take the time to sand the edge of hull slot so it's not like a razor.Otherwise they cut through in no time. That worked on my boat and has held up through plenty of miles. You probably should do the sanding no matter what option you choose,it should've been done at the factory.
Isak Dinesen
E. B. White
Re: Tramp slugs on I-20 [Re: AzCat] #246751
04/06/12 09:29 AM
04/06/12 09:29 AM
Arizona
AzCat Offline OP
AzCat  Offline OP
Arizona
Thanks guys, Ill get hold of EP and see what they can do. Slugs go back to murrays.
Re: Tramp slugs on I-20 [Re: AzCat] #246756
04/06/12 12:01 PM
04/06/12 12:01 PM
Maryland
Kris Hathaway Offline
Maryland
If that doesn't work, try salt grin
Kris Hathaway
Re: Tramp slugs on I-20 [Re: Kris Hathaway] #246760
04/06/12 02:31 PM
04/06/12 02:31 PM
Arizona
AzCat Offline OP
AzCat  Offline OP
Arizona
Ahhh yes.
Re: Tramp slugs on I-20 [Re: AzCat] #246770
04/06/12 08:16 PM
04/06/12 08:16 PM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
I had my local awning maker make up over 200 of them, because my local fleet wanted them. With a "I’ll take 30. I’ll take 60…” and I paid for them in advance. Only one of my local fleet guys has paid for their 30. For you including shipping, $1.25/ea... for them $5 each delivered to the beach...IJS. I need to sand down the edge Todd mentioned...
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: Tramp slugs on I-20 [Re: AzCat] #246783
04/07/12 07:46 AM
04/07/12 07:46 AM
V
Ventucky Red Offline
V
You need to get the Aquabatten A018S Slug
Re: Tramp slugs on I-20 [Re: Chris9] #246806
04/08/12 10:42 PM
04/08/12 10:42 PM
Arizona
AzCat Offline OP
AzCat  Offline OP
Arizona
Do you have a pic of what your talking a out? I just ordered a set of the opt ropes from EP, $30. If they don't pan out, I'll definaty need another option. Skip seemed pretty confident that they would work. Send me a pm so I have your info. Thanks
Re: Tramp slugs on I-20 [Re: Ventucky Red] #246807
04/08/12 10:46 PM
04/08/12 10:46 PM
Arizona
AzCat Offline OP
AzCat  Offline OP
Arizona
[quote=Ventucky Red]You need to get the Aquabatten A018S Slug
[/quot
I tried these, worked for exactly 1 second.
Anyone out there have a set of tiller tendon and end cap?
Re: Tramp slugs on I-20 [Re: AzCat] #246834
04/09/12 02:50 PM
04/09/12 02:50 PM
V
V
There are two different sizes, there are AO17S which a 3/8" which are the ones that Murray's sells and there are the AO18S which are 1/2" the ones that I recommended here! BIG DIFFERENCE!
Re: Tramp slugs on I-20 [Re: AzCat] #246842
04/09/12 09:31 PM
04/09/12 09:31 PM
Arizona
AzCat Offline OP
AzCat  Offline OP
Arizona
I have boltropes coming, if they dont work, i know what to get, Thanks.
Re: Tramp slugs on I-20 [Re: AzCat] #246843
04/09/12 10:42 PM
04/09/12 10:42 PM
TeamChums Offline
TeamChums  Offline
Brett, the loops on the tramp may not match up with the straps you get from EP. I had that tramp modified by Tony Morrelli in Ventura and used it with the slugs that John posted the link for. They worked great. They take a little persuading to get in the track but they hold my fat butt without pulling out.
Lee
Re: Tramp slugs on I-20 [Re: AzCat] #246972
04/13/12 08:47 AM
04/13/12 08:47 AM
Arizona
AzCat Offline OP
AzCat  Offline OP
Arizona
Yea, I'm out here in sandiego, Brad Smith an I are doing Cat Fight if the winds chill from the 32 that windfinder is calling for. Took a look at his. Oat yesterday and he has the ones that you are referring to. The loops on the. Boltrope that EP is sending may also be too long to use with my tramp. Maybe I'll go ahead and order those solid slugs from Murray's. I don't want to. E put out another week. Time to get this I on the water.
Re: Tramp slugs on I-20 [Re: AzCat] #247007
04/14/12 08:23 AM
04/14/12 08:23 AM
V
V
I don't think Murray's sells them!
Re: Tramp slugs on I-20 [Re: AzCat] #247033
04/15/12 04:54 PM
04/15/12 04:54 PM
Newport, RI
wildtsail Offline
wildtsail  Offline
Newport, RI
I tried both slugs on my 20 and neither worked.
It varies from track to track.
Murrays should sell them, they have an account with my work and we own and distribute aquabatten.
If they don't they can get them. Or Rick bliss at new england catamarans can, that's where I got mine from.
Re: Tramp slugs on I-20 [Re: wildtsail] #247058
04/16/12 08:39 AM
04/16/12 08:39 AM
V
V
Murray's does not stock the A018S 1/2" slug..they stock the A017S 3/8" slug. They can order them for you.
Re: Tramp slugs on I-20 [Re: Chris9] #247069
04/16/12 09:54 PM
04/16/12 09:54 PM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
Did I order some from you? Gettin' old, can't remember. I'll pay, I'll pay...
0 registered members (), 126 guests, and 83 spiders.
Posts267,059
