mast rake #247081
04/17/12 08:40 AM
04/17/12 08:40 AM
pgp Offline OP
pgp  Offline OP
I've been using very little. Now it appears I'll often have crew.
How much rake do you guys use on a sloop rigged boat.
Pete Pollard
Blade 702
Re: mast rake [Re: pgp] #247087
04/17/12 10:21 AM
04/17/12 10:21 AM
Maryland
Kris Hathaway Offline
Maryland
Depends on wind strength and crew weight. Conventional wisdom is to rake more in higher winds and lighter crew. Conversely, rake less in light winds and/or heavier crew.
Just a rule of thumb and really it is up to the skipper to tryout the different settings. I try to adjust according to helm feel...just a tiny bit of weather helm unless it is blowing like stink.
Kris Hathaway
Re: mast rake [Re: pgp] #247101
04/17/12 04:09 PM
04/17/12 04:09 PM
Knokke-Heist - Belgium
Gilo Offline
Gilo  Offline
Pete,
If you had a comfortable setting for the single handling, start from that one for double, especially in heavier wind. When it is light you can move the mast forward about 7 cm using the trap wire method.
If in heavier wind you feel you are missing too much power you can start moving it forward a bit too, but mind it will affect your pointing ability too some extend when overdoing this and might give you too much power on the downwind.
Gill
Falcon F16 - BEL666
Boats: TheBoatShop.be
0 registered members (), 490 guests, and 44 spiders.
