Shroud position question. #247108
04/17/12 07:11 PM
04/17/12 07:11 PM
Palm Harbor, FL
daniel_t Offline OP
daniel_t  Offline OP
Palm Harbor, FL
I was watching this new video on the Nacra F16 and I noticed that it seems like the shrouds on it are considerably further back than they are on my Taipan. That got me wondering, how do they compare to the Viper and Falcon?
Daniel T.
Taipan F16 - USA 213
Re: Shroud position question. [Re: daniel_t] #247114
04/17/12 09:51 PM
04/17/12 09:51 PM
Maybe a little bit. Hard to say. It looks like they're aft of the daggerboards though.
Re: Shroud position question. [Re: daniel_t] #247115
04/17/12 11:11 PM
04/17/12 11:11 PM
Brisveagas
Aido Offline
Aido  Offline
Brisveagas
Checked the N F16 out very closely in thailand. The chain plates are definetly further back than a viper or a taipan. The daggers are slightly further foward as well.
Not sure why the shrouds are further back but I guess it might take some compression out of the rig???
Aido
Viper 288
Re: Shroud position question. [Re: daniel_t] #247117
04/18/12 02:48 AM
04/18/12 02:48 AM
Hamburg
Smiths_Cat Offline
Smiths_Cat  Offline
Hamburg
With a spinnaker, there is no reason why the main should move out, hence the shrould can be more aft. This reduces also the main sheet tension when sailing downwind with spi, giving a new degree of freedom for main trimming.
On the other side, what happens, when the boat is sailing downwind without spi (in confined spaces like harbours) or with handling on the beach?
Re: Shroud position question. [Re: Smiths_Cat] #247123
04/18/12 06:12 AM
04/18/12 06:12 AM
waynemarlow Offline
waynemarlow  Offline
It was one of the " won't do that again " mistakes I made when building Bitsa, I moved the shrouds back about 100mm more than most A's of the time to try and reduce the loading from Spinny with the understanding that we seldom if ever have the boom right out. Works really well but that position is right where you want to sit upwind when hiking only as a single hander and it is just where the tiller bar and main sheet clash when going upwind out on the wire.
With two on board it would not be such a problem but as a single hander its a real pain. Presently rerigging the main sheet to give a foward sheet to use upwind ahead of the stay. Bit complicated but workible if I think about it.
0 registered members (), 2,600 guests, and 533 spiders.
Yesterday at 10:10 AM
