Can I store jib on furler? Main on Boom??? #24741
10/02/03 11:45 PM
10/02/03 11:45 PM
Minneapolis, MN
duganderson Offline OP
Minneapolis, MN
I have a Hobie 21 Sport Cruiser. I will be storing it in indoor, unheated storage in Minnesota (temps below freezing).
Is it bad for the jib to store it on the furler? Should I take if off and roll it, fold it, etc???
Can I store the main on the boom? It's rolled around the boom and stored in a sail tube now.
Thanks, Doug
Re: Can I store jib on furler? Main on Boom??? [Re: duganderson] #24742
10/03/03 01:57 PM
10/03/03 01:57 PM
Maryland, USA
HoldenBeachin Offline
Maryland, USA
Hey Doug...
Just my 2 cents, my boat has Dacron sails, so I remove them, clean and complete any repairs to them, thoroughly dry them then store them in a heated area (mine are in my basement). The previous owner of my boat usually rolled his main around the boom and it picked up several rust / mold stains and some tearing along the lower part of the sail.
If I had to store them as you described, I would make absolutely sure that the sails were 100% dry, that they would not be exposed to too much humidity when stored (yes, there is humidity even in the middle of winter), that no metal parts were in contact with the sail cloth, and they were covered in a water-repellant but breathable cloth.
If your sails are mylar or some other fabric, then I don't even have 2 cents to give you!
My boat has its original 27 year old sails and they are in surprizingly good shape--it used to be sailed on a lake.
Good luck!
Mark Owens
1976 H16 sail # 19857
0 registered members (), 361 guests, and 45 spiders.
